Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
Stuck on 2H
Light display stuck on 2H
  • brooke3 Nov 20, 2008
    my Bosch does the 2 hr thing too. Before the cycle would be 93 minutes or 88 minutes. But a few weeks ago I noticed that it ALWAYS started at 2 hrs and it really takes over two hours to complete the cycle. I've tried turning on the hot water before starting it. I've tried changing the settings around. I'm just not sure why this would suddenly happen.
My wife got our Bosch diswasher "unstuck" from the 2H position by pressing buttons randomly. Sorry this sounds so serendipitous! Good luck!
Posted on Apr 02, 2008
MODEL DWF31 START PROGRAMME DISPLAY SHOWS 2H AND STAYS ON 2H ANY IDEAS
Hello. First, try to reset the control board. There are 2 buttons with arrows underneath. Press and hold them both for several seconds, maybe a little longer--this will perform a reset on the control board. See if that clears up the problem. Also, are there any lights blinking? Dishwashers will flash error codes(in binary format) by blinking certain lights in a pattern(i.e. The "sensing" light will blink 2 or 3 times, then the "cycle complete" light will blink 2-3-4 times--something like that) It could be any combination of lights depending on the component that has failed or has a problem. Components can be the drain pump, main wash motor, float switch(if present), heater circuit, inlet water valve, flood switch(if present), etc...
Sep 26, 2015 | Hotpoint Dishwashers
Bosch Dishwasher, SHU 5300 - Cycle stuck on 2H cycle
yes it needs a new control and its pretty easy to replace..
Dec 13, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Stuck in 4 wheel drive low
this is not AWD, so what are the tires touching? do tell.
by what indication.?
  1. just the silly light.
  2. the lever is stuck
  3. or all 4 tires spin on ice.? in 2H?
are you on ice. or dirt. if not better read the operators guide,
as that is wrong. if driving on dry pavement. move to dirt or gravel area and shift back to 2H
cured now. next time dont drive on non iced roads in 4wd or 4Lo
or it will bind up. need a suzuki TSB warning you?
have it.
http://www.fixkick.com/part-time-test.html
solution, i think is stop doing that.
the TSB solves the after you messed up .
Mar 28, 2015 | 2005 Suzuki Jimny Classic
Check 4wd light on
just found this worked a trick..mine stuck for two weeks in 2wd
A mere 2,400km into the life of my 07 Rodeo TD 4WD, I used 4L for about 2km of medium-steep/slippery track. After stopping and selecting 2WD the 'Check 4WD' light appeared, meaning I was stuck in 2WD for the rest of that trip. Luckily I was able to complete the trip in 2WD without incident.
The dealer blamed me for 'not following the instructions in the manual' (utter codswallop), 'fixed' it, and very reluctantly gave me a scribbled set of instructions on resetting the system, which I've included below.
When I suggested that these instructions should be included in the manual, the response was 'not necessary if owners use the system correctly'. More cods.
Here's how to reset it:
1. Ignition off, hold all 3 buttons (2H, 4H & 4L) in together
2. Switch ignition on to 'reds' position (last position before start)
3. Hold in this state for 30 seconds
Hope this may be of use !!
Dec 12, 2009 | 2004 Isuzu Rodeo
2000 Chevy Blazer stuck in 4L
try putting in neutral then try shifting in to 2h
Aug 17, 2009 | 1999 Chevrolet Blazer
2H displayed and pump runs nothing else happens
I would check the buttons on the control they may stuck. check the delay button..
Dec 21, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Error code 2H
The control panel needs to be replaced (indicated by the "2H" error code displayed at the start of the cycle).
BTW - The number 1 displayed at the end of the cycle indicates the cycle has timed out (i.e., it doesn't mean 1 minute remaining). Hence the continued running of the unit. Until you replace the control panel, you'll have to manually cancel the cycle at this point.
Oct 08, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
427 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
