Question about Dell Precision Workstation 670 PC Desktop
Dell precision 670 workstation
I just go some new 4gig ECC registered dual channel kit ram. I put them in with my other 4gig that i already have, once i turned on my computer, it said that it needs one more fan or something in order to work or something! wat does that mean?
  • pamborionos May 11, 2010
    Hi oombas, 1. does the Corsair CMXAF1 support 8+ GB of RAM? 2. What modification is necessary to get the CMXAF1 to work with the Dell Precision 670 I have? thanks! P.
The W5620 is (identical to) the WC417. The BIOS detects the amount of memory and the presence of a fan in case of >4G. An alternative is a Corsair Dominator memory fan CMXAF1. It sells for about $30, a small modification is necessary. See: http://cgi.ebay.nl/Dell-PowerEdge-SC1420-Memory-fan-WC417_W0QQitemZ160341269510QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2555159c06&_trksid=p3286.m63.l1177&_trkparms=240%3A1318|301%3A1|293%3A1|294%3A50
Posted on Jun 10, 2009
Hi oombas,
thanks! P.
Posted on Sep 02, 2009
You need to buy a memory fan, see
http://support.dell.com/support/edocs/systems/ws670/en/ug_en/before.htm#wp1131665
and
http://forum.us.dell.com/supportforums/board/message?board.id=pw_other&message.id=4036
the part number is W5620, but good look finding it on Dell's website. I had better luck calling them, but the part is on back order and I couldn't actually place an order until they get confirmation from the warehouse. I'm told I have to wait at least 24 hrs.
Posted on Mar 28, 2008
    Problem Solver:
  • 5 Answers
The part number is W5620
You can buy one by contacting Dell Sales Support at 1-800-624-9897 (Home/Office) or by ordering online. Make sure to have your service tag number handy. For Small Business, it is 1-877-773-3355, and for Medium & Large Business, it is 1-877-671-3355.
Good luck finding the part online at Dell's site, I couldn't. I called the parts order number and was told the item is backordered and they needed confirmation from the warehouse before placing an order. Said confirmation is said to take ~24 hours.
this answer adapted from: http://forum.us.dell.com/supportforums/board/message?board.id=pw_other&message.id=4036
  • matt wilkie
    matt wilkie Mar 28, 2008
    whups, the guest post was mine too. I got a login screen when I tried to post, so thought it didn't go through.
    Oh well.
    Problem Solver:
  • 16 Answers
That means your PC prefers NOT to burn. Many of the later model motherboards have chipsets on them that automatically respond when temperatures get to levels that are higher than normal. Or the case may be that the prompt comes to you even before the rise in temperature.
Temperature configuration is usually available in your BIOS. Just hit Del or F2 on the first screen of boot up. But before you get to changing those settings, read your manuals first. Go to the official website of your device's manufacturer for details and documentation because you may be at risk of irreperable hardware damage.
Posted on Mar 05, 2008
Can an old HP Workstation xw8000 Computer that is currently using 512 RAM (PC2100 registered 184 PIN ECC DDR SDRAM DIMMs) be upgrade using 4GB Kit (2 X 2GB) PC2100 Registered 266MHz 184 pin DDR SDRA
According to a couple of people I have conferred with, that RAM should work.
Take a stick of the old ram out and make sure the the cut out, in the new RAM, is in the exact place as the old sticks. It cannot be off by a micron, or it will not fit.
Understanding Identifying and Upgrading the RAM in your PC
Dont click on any of the ads in that article, just read it and you will be able to judge for yourself.
Mar 11, 2014 | Dell W4201C 42 in. Plasma HDTV
I have a Precision 670 that I put two 512MB DDR CL3 ECC REG ram sticks in and it will start up but when it reboots, it beeps two slow, two fast, two slow and stops. lights on front turn: AC are...
The issue seems to be that your PC can not handle the supported memory. After review of your system specs on dell's website, I see that you're computer would require DDR2 Memory. This seems to be what is causing the beeping. Please check to ensure you are using the correct memory stick. I hope this has helped
Jul 05, 2011 | Dell Precision Workstation 670 PC Desktop
I want to add memory up to 4GB. I have 2 x 1 GBs modules. can I add 2 x 2 GB's and remove the 2 x1 GBs? Also willing to move to Windows 7 64bit in order to move above the 4GB limit. Could I then mix the...
The memory specification for your workstation is here:
http://www.crucial.com/store/listparts.aspx?model=Precision%20Workstation%20T3400
You can remove the 1GB modules and replace with 2*2GB modules to give 4GB and you are correct in that you will need to use a 64-bit operating system to fully utilise 4GB or more.
Hope this helps,
Please rate my answer,
Chris
Mar 09, 2011 | Dell Precision T3400 375W 32bit Computer...
Dell precision 670. Adding 8 gb total memory. Using Kingston KX1563-NAB; DDR2 2gb 2Rx4 PC3200 EEC, registered. Accepts 4 gb in dimms 1 and 2 (2 gb modules) and boots fine. Adding 4 more gb in dimms 3...
glenn_mullin
From what I can tell the Dell Precision Workstation 670 does support over 4GB of RAM. However when you have over 4GB of RAM installed in the system you have to have the Memory Cooling Shroud connected to keep the memory cool. Also this is only shipped out when the system is ordered with over 4GB of RAM originally. If you do not have this part you can order it from Dell buy calling 877-671-3355.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Jan 27, 2011 | Dell Precision Workstation 670 PC Desktop
How can i fix my 4 gb DDR 2 ECC RAM in dell 470 work station
You can't fix RAM. You didn't say what the problem is.
If the RAM is bad, you replace it.
If your computer doesn't see the total of 4GB, it's the BIOS of the motherboard.
If Windows doesn't see the full 4GB, then you are not running the 64-bit version.
Oct 19, 2010 | Dell Precision Workstation 670 PC Desktop
Computer beeps six times after installing new game. Precision workstation 670. Ram sticks are a 1GB each. My old ram works fine with the computer.
You need the EXACT speed rated RAM.
Your support page states it needs.....
400-MHz DDR2 SDRAM
NOTE: Your computer supports only registered memory
Memory capacities
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC modules to a max of 16GB
more info here
http://support.dell.com/support/edocs/systems/ws470/en/ug_en/about.htm
Jul 26, 2010 | Dell Precision Workstation 670 PC Desktop
DELL Precision Workstation 670 second processor not working
Did you change BIOS settings or does your BIOS supports dual processors?
Jul 19, 2010 | Dell 3.8 GHz Second Processor for...
An online search for other providers says price is $225 - $380 (sheesh!).
Mar 27, 2008 | Computers & Internet
Dell Precision Workstation 670 has no video on screen.
Support for ISV-certified PCI Express graphics cards up to 150 watts and with up to 512MB graphics memory including: nVIDIA® Quadro® FX 4500;
nVIDIA Quadro FX 3450; Quadro FX 1400; ATI™ FireGL™ V3100; nVIDIA Quadro NVS 280; All graphics cards support dual monitor configurations
Although it may not be your video card thats the problem. when youre computers posts, it beeps once. If it is beeping more then once youll want to check with the board manufacturer to see what the code its giving means.
Jan 15, 2008 | Dell Precision Workstation 670 PC Desktop
Dell Precision Workstation 670 PC Desktop Logo
4,272 people viewed this question
Alun Cox
