Question about RCA P60920BL 60" Rear Projection Television
Thank you for responding
Well, I'm not sure how to check the fuses. And I don't really hear anything back there when someone tries to turn it on.
What are the chances it is a blown fuse, and how much generally do those cost to have replaced? I've had the color tubes fixed/replaced in this before, and I feel comfortable going back to the same people, but it costs good money to have them come look at it and I wanna get a general idea before I call them.
Can't thank you enough for taking the time to respond to me.
  • RCA Master
  • 8,617 Answers
You can check the fuses with an ohms meter if the needle moves the fuses are good, if not the fuses are bad.
Posted on Mar 05, 2008
Samsung galaxy s4 has no audio sound. When I make a phone call, the person can hear me, but I cannaot hear anything. Also when I restart the phone or turn the power off, it does not respond right away....
Hello
Sound problems: Check your settings to be sure they are all correct, i.e. volume, mute button. Listen to a music file and record something with sound to ensure that all other speakers in/out are working correctly. Locate the speakers and be sure that they are clean and not obstructed by a case or foil. Try the above again with headphones on. Also, check you battery power to be sure that it is fully charged. If you locate a speaker that does not work or you cannot replay a recorded video, then your phone may need to be serviced. Before you decide this though, ensure that you have a backup of your data and then restore it to factory settings. Then use your phone without the backup to see if it is functioning normal; have someone call you and retry anything else (video, music) that didn't work before, if it still doesn't work, then it will definitely need to be repaired.
Aug 02, 2017 | Samsung Galaxy S 4G Cell Phone
How do I make sure its the fuel pump? I dont hear it and I dont have a pressure gauge anything I can do?
Check your owners manual & then the fuse for the fuel pump
Have someone turn the key on & off,while you put a long
screw driver to your ear & fuel tank
Next tell us what is really going on,in some detail
Jun 01, 2012 | 2004 Chevrolet Blazer
Ii'm trying to figure out which fuse is for the air conditioner/heat. when i try to turn it on, i don't hear of feel anything at all. i don't know which fuse to check for this problem. i d
okay, look at the fuse box and look for ones that are black or the little wire is broken. You can remove then to check them, just make sure you put the m back where you got them. the voltage should match the one burnt out when replacing it
May 07, 2012 | 2003 Mercury Sable
I have a 2000 chevy silverado 1500. 3 nights ago, my truck started up just fine with no problems and has never had a problem starting up. The next morning, I tried to start it and the dash lights and radio...
do you have remote start on that truck? if you do, it has a hood safety switch that will keep it from starting if hood is open. That hood switch is quite easily identifyable. Look for it on the drivers side, either close to the firewall or right at the front of the fuse box.itsa worth taking a look
Aug 12, 2011 | Chevrolet Silverado 1500 Cars & Trucks
On boot up I can hear the hard drive responding but I dont hear the computer posting and the screen is black.. no errors or anything. Any suggestions?
Reseat the memory and try it again. If it still doesn't work, what do you hear for the hard drive? Does it just whir to a full spin up, or does it chunk n klunk?
Jul 06, 2011 | Toshiba Satellite L305D Notebook
I have a sony ls25e the computer was working fine and the screen just went white I shut it off and turned it back on you can hear it boot up to windows. I pulled it apart looking for bad fuse's but I...
There are NO fuses in your computer.
Try connecting a known working monitor and see if you can see the display.
If you still don't see the display the video is defective and you will have to replace it, you will need to find out what type of video card your pc takes, either AGP, PCI Express or PCI.
If you are not sure how to do this, take your pc to your nearewst computer repair shop.
I hope this helped.
Good luck and have a pleasent day.
Jun 20, 2011 | Sony VAIO VGC-LS25E PC Desktop
I place a vhs tape into my player and the engine died, Now it wont start turns over good but thats all it does. What to do?
I really don't think that the VHS tape had anything to do with the vehicle not starting. I think that this might just be a fluke. If the vehicle is turning over then I would look at the fuel pump and the fuel pump relay to make sure that they are working correctly. You will be able to hear your fuel pump making noise for about 2 seconds. If all of that checks out ok then I would start looking at the fuses and making sure that nothing did actually pop.
Jun 16, 2011 | 2001 Pontiac Montana
Where is the fuel filter on 1992 dodge ram 150 ? someone was working on my truck '' the tank'' and the truck was working good .Now there is no gas going to the engine at all .He says maybe its the fuel...
Hi. Every time you turn ignition on you should hear your fuel pump working for few second. (Priming) if you can't hear it turning on check fuse or fuses and relay first before you check the pump.
Apr 27, 2017 | 1992 Dodge Ram 150 Club Cab
2000 chevy silverado-is there another way to check if fuel pump is bad,before changing it
Have someone help you, stand back at the fuel tank while you turn the key on. You should be able to hear the fuel pump come on. If you don't hear anything, pull the fuel line off just before the filter. Turn the key on and see how good the gas pressure is (be careful not to get gas on anything that may cause a fire). It should have a good amount of pressure.
Dec 27, 2009 | 2000 Chevrolet Silverado
Replaced fuel pump failure
If you can't hear the pump over the door chime, when checking, roll down the window instead of opening the door, or have someone else listen outside the vehicle! To get the relay out, spray some wd 40 or other solvent around the base... it will seep into plug and make it easier to remove. (if it's bad, it will have to come out sooner or later!!)
Did you replace the filter when you did the pump???
Feb 06, 2009 | 2000 Chevrolet Blazer
Televison & Video Logo
21 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
