Question about Proview PRO576 15 in. Flat Panel LCD Monitor
Proview PRO576 error message "mode not supported" and will show nothing else
The computer was on and working well but was idle for a time - then I noticed the monitor error box saying" Mode not supported" . I rebooted with computer button but it would not even show the screens during the booting process - it was black during this time except a couple of times it quickly flashed on (too fast to see anything but could tell it was white letters).
Hooked up a different monitor and it would boot up although it was a very old monitor and showed me double split screen images. Can the Proview problem be corrected or has it gone out completely? It is 4 1/2 years old.
  • 1 more comment
  • Anonymous Mar 19, 2008
    I have been having this problem for a long time. I get VGA not supported and the screen is black. This just happens everytime I start up or shut down??? Now I am experienceing a long delay in getting a picture on the screen. Sometimes I have to turn it off and back on to get a picture??? i don't know what is wrong.
  • Anonymous Sep 28, 2008
    Hello I have a problem bij by computer. everytime if i start a game I get flashes with The messege Mode Not Supported.
  • Anonymous Mar 20, 2009
    hook up monitor to tower and booting up get to see windows xp screen then goes black with box saying mode not supported
Okay, we got a fix by having another monitor hooked up to our computer and going in to display and changing the display settings to a lower setting. The screen resolution - turn it to lower - I guess somehow - the setting was too high for our monitor. Don't know how it changed itself though. Anyway, change it to a lower resolution then re-hook up your monitor and see if it works. The reslution can be pushed back up until you notice the problem again.
Posted on Apr 01, 2008
My monitor does not work right. it says vga not support.. its a proview 17" flatscreen..active matrix tft lcd
I suspect your Computers Display settings need adjustments and or a Driver from Proview installed...therefor if you can get on the net, I would look at FAQ's on Proviews Website, i.e:
http://www.proview.net/Support/FAQ_Question.aspx?pi=2026
hope that helps,
Bastian
Jun 02, 2009 | Proview PL713S 17" Flat Panel LCD Monitor
No shutter release
It turns out that supporting the camera while taking a shot can impart a slight twist on the seated lens. This twist is just enough to cause the camera to think that there is no lens installed .. hence the error message. Solution (provided my Henry's Camera experts) was to reseat the lens by reversing the twist. It has since happenned twice and each time recovery was effective .... Keith
May 25, 2009 | Nikon D80 Digital Camera with 18-135mm...
Over range message on monitor
switch on the computer then press F8 F8 contineusly then highlight on safe mode press enter then display will see if you want to work on high resolution then attatch external display card and best will be AGP card then you can watch movie much clear also 3D games
Nov 25, 2008 | Proview PL926WBi 19" LCD Monitor
Olevia Monitor
Restart your computer and tap the F8 key until you get the Windows Advanced Options Screen. Use the arrow keys on your keyboard highlight Enable VGA Mode (Low Resolution Mode for Vista). Press Enter. Then Enter again.
Windows will boot up in a low resolution which will make things look large. Raise your resolution to a normal level in Windows' Display Properties (in the Control Panel)
The next time you restart the computer, it will boot normally.
Jul 04, 2008 | Proview PL926WBi 19" LCD Monitor
PROVIEW FLAT SCREEN TFT 17" MONITOR
the vga mode not suppopt is on and not working
May 07, 2008 | Proview PL713S 17" Flat Panel LCD Monitor
Error Message
in windows display you need to set the display refresh rate to 60. you will find it "right click on desk top, select properties, select settings, the select advanced, selects monitor and change the refresh rate to 60 hz
Mar 06, 2008 | Proview PL576Ws 15.4" Widescreen LCD...
Blank screen with message "mode not supported"
Hi
How have you connected the monitor to the computer?
Is it through the vga or the dvi port?
Pls press the monitor menu button and change the mode to vga or dvi depending on the connection that you have now.
You might also get a vga to dvi adapter and connect the monitor to the computer.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Mode not supported
this only for a temporary.. if the monitor is new its like the monitor try to get in touch with (get use) with your cpu.. :)
Dec 12, 2007 | Proview PL913B 19" Flat Panel LCD Monitor
Over rang
on crt monitor adjust screen referesh mde to 75Hz
or go to windows safe mod e
You can see your monitor ranges ;
right click desktop -> properties -> settings -> monitor
You'll see Screen refresh rate here
under the that there is a box "Hide modes that this monitor cannot display" click that.
Now computer shows your monitor range in list. When you select bigger value different than list , gives error " OUT OF RANGE "
Dec 03, 2007 | Proview PT 15.1" LCD Monitor
Proview PRO576 15 in. Flat Panel LCD Monitor Logo
863 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
