I have a 42 AKAI " Rear projection HDTV. As I was watching it, it suddenly went similar to a 3d picture, with a doube immage. It is also a little bowed in the centre of the picture now, and appeared to have no yellow colour. Has one of the colour bulbs gone? Thanks, Trevor.
  • trev-n-tina Mar 07, 2008
    I tryed moveing the heat sink as you suggested, but nothing happened.
    Anyway I decided then to call in a TV repair man. He said that the modules needed replacing, and also a chip on another board. He is getting the parts and said that the bill will be $300.
    Is this exspensive, as he was only here 20 mins, but has to come back and fit them yet?
    PS the pins on the modules did not stick through the board, but are bent over 90 deg, and soildered to the top of the board.
    TP
  • 579 Answers
You have a problem with the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conducting piece of wood to push the heat sink when doing tests.
If soldering doesn't help, then the modules have died and need replacing. Don't buy the $10 cheap ones. Most of them have an upgraded version that is stronger. Also look for any burned resistors in the vicinity of the modules.
Best of luck, hope ya fix it.
Posted on Mar 05, 2008
Samsung rear projector tv Model SP42Q2HL HDTV ready 1080i Looks like i should b wearing 3D glasses when watching tv, Is it game over?
No,is it not.It a repairable tv.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 12, 2010 | Samsung HCP4252W 42" Rear Projection...
Samsung HCN4226W "image pinching"
The convergence IC has gone out and is located on the Main bd or the Power supply bd depending on the specific model and must be replaced and a Full convergence alignment must be performed to return your tv to a watchable condition. Only a Samsung trained tech can do this.
Jul 16, 2009 | Samsung HCN4226W 42" Rear Projection...
The red is forming a doube image on the picture
You mean red ghosting
easy , replace both cnvergance chip
if you have a repair shop fix it don't pay
more then 175.00 . It's an 1 hour job
and the part cost about 30.00
Jun 30, 2009 | Samsung HC-P4241W 42" Rear Projection...
Picture almost looks like it is in 3D on RCA 52" rear projection
there are 3 brown fuses by the flyback the 1 in the middle is bad
Jun 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture do have sound
i think you have a blown tube.if theres no pic but sound youve got a blown tube
Nov 03, 2008 | Akai PT5598HD 55" Rear Projection...
42" Rear Projection color issue
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 22, 2008 | Toshiba 42HDX82 42" Rear Projection...
Akai PT5598HDX/SMS won't turn on
Just a thaught, I could be wrong, maybe a problem with the power button on the remote ? It might shut the TV off, and when you do keep pressing the remote button, the red light on the TV will keep flashing like that also. Ive seen this prob on a few other blogs, so seems to be pretty common. I know I like to keep the remote pointed at the TV all the time, maybe try pointing it away for a while, just to see.
Dec 30, 2007 | Akai PT5598HD 55" Rear Projection...
AKAI 1080i HDTV 42"
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Aug 27, 2007 | Akai PTH5498 54" Rear Projection...
Rear Projection TV
high humidity could be a cause i have a similar problem with a sony rear projection. on some warm rainy days /try cleaning lenses with a photographic anti fog cloth.but be very carefull not to scratch or leave dust on lens.
May 08, 2007 | Mitsubishi WS48511 48" Rear Projection...
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
