Question about Philips 60P8341 60" Rear Projection Television
60" 60P8341A TV NO SOUND NO PICTURE-CAN IT BE FIXED? (INEXPENSIVE)
Power button lights up when turned on and blinks when pushing buttons on remote. Remote will also turn off and on but either way has no picture and no sound at all. Is this something I can fix relatively cheap or is it better to buy a new one? I am handy and can find my way around electronics so Im not squeemish with do it yourself type things.
  • 2 more comments
  • BJINFLORIDA Mar 05, 2008
    please leave the link
    THANKS SO MUCH
  • howiedb Apr 25, 2008
    I am having a similar problem but when I press the power button, the picture appears breifly before shutting off.
    I am having a similar problem, but when I hit the power switch on the tv or remote, the picture appears just as it is shutting down.
    Scholar:
  • 52 Answers
If you are lucky, it's only a blown fuse. Some tv's this large have more than one fuse, so look real hard and find all fuses. If fuses are good, then about 95% of the time, when you have no picture/no sound, the problem is a bad H.O.T. This is a large transistor with three pins soldered into the main board and is very easy to find because it is connected to a metal "heat sink". Look for a large red or black wire coming from the pic tube down to the main circuit board (sometimes it's blue, but it's the only wire coming from the GLASS part of the tube to the board. This wire goes to about the largest component on the board called the "flyback transformer". It is usually black and is about 3 or 4 inches tall, 2 inches wide, and 2 inches thick. The h.o.t. will usually be located in the area of the "flyback". The h.o.t. will be screwed with one screw or clamped onto a large piece of metal (usually silver). This piece of metal is usually about 2 inces square and is about 1/8 of an inch thick and is mounted perpendicular to the main board. Imagine a slice of bread standing on one side rather than lying flat and this is what the heat sink looks like. Sometimes you will see several heat sinks with transistors screwed into them, but the one you are looking for will always be the largest transistor with three pins. Don't forget to unplug the tv before you begin and stay away from the large wire coming out of the tube going to the "flyback". Do NOT unplug this wire from the tube. It can shock you very badly EVEN WITH THE TV OFF FOR SEVERAL DAYS. Just be careful and go ahead and give this a try. You can do it, and this is probably going to fix your set. If not, then replace the flyback transformer. The H.O.T. is about $10 or $15 and the flyback can be from $30 to $80. It is possible that none of this will fix your set, but you have about a 95% chance that it will and with such a big and nice and relatively new set, I would give it a shot. Keever
Posted on Mar 05, 2008
  • Philips Master
  • 8,617 Answers
Should be able ti fix it if you can solder and do basic troubleshooting. If you would like to get the service manual let me know and i will post a link.
  • Sonny Berry
    Sonny Berry Mar 05, 2008
    Heres the link its 199 pages the full factory service manual. Its 15.99 and they will email it within minutes of your ordering it. I have used them many times, they even provide free unlimited support to help you with your repair. That is free with the purchase of the manuals.
    http://servicemanuals.vstore.ca/
  • Sonny Berry
    youre welcome. Check that link out, you'll be glad you did they have great free support.
Sony KV32FS120 Trinitron TV No picture or sound when power button on remote is turned off. Red light at front of TV blinks nine times per cycle.
Once your television blinks about 9 times then it means there is a problem somewhere most likely the lamp of the television. Another source of this problem is also a bad capacitor from either the main panel or the power panel.
If your remote turns off actually it is because there is nothing to operate on the television, so once your television starts the blinking light, the remote will not be able to operate the television, once you unplug the television and plug it back then press the power button, the remote will do the same.
Until the television is fixed is when the remote will work normally.
Take care and good luck
Dec 31, 2010 | Televison & Video
Tv doesn't turn on.
Does this have a replacable lamp? If so it will do exactly this. If it does it's probably fried.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Setting up 42lg3000 with sky and lg home cinema dvd system.picture and sound from dvd.poor picture and sound from tv speakers only from sky .please advise on correct wiring connections for this set up.TV...
i have same tv, this i was i did on mine. on the sky+ remote push tv and then press select + red button at the same time, the red light blinks twice, then push 1174 then power button.
Nov 29, 2008 | Televison & Video
Blinking red light standby/timer
It seems to respond to power supply, send it to a nearby technician. The problem might be it fused the picture power supply fuse. make sure the installation is at you presence.
Sep 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Blinking green reset light
Can you please supply us with the make and model as well as the blink count of the green light. That count should be indicating the problem circuit. Once that info is posted, we should be able to give you more details and possible solutions.
Dan
Jun 19, 2008 | Televison & Video
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
No picture or sound
Classic power supply or horizontal output problem. Take it to a servicer.
Oct 18, 2007 | RCA F32450 32" TV
Philips 60P8341 60" Rear Projection Television Logo
532 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
