Question about GE GSH25JFR Side by Side Refrigerator
Fa does ot work replaced fan motor fa still does not come on
Evaporator fan does not work replaced fan motor fan still does not come on. Help!!!!
  • 1 more comment
  • 313131 Mar 23, 2008
    replaced condenser fan, still does not run
  • Anonymous Apr 10, 2008
    I have the same problem and I replace the motor and put a jumper on the sensor and the motor does not work
  • Anonymous Mar 20, 2014
    fan motor noisy
It's probably the board in behind the cover in back of refrig.it powers the fan. it's a good idea to replace white sensor on evap coil also if your fan didn't come with one
Posted on Mar 06, 2008
Samsung RB31F Fridge/Freezer - fridge temperature too high, freezer OK
1-The condenser coils are usually located under the refrigerator. They dissipate heat as refrigerant passes through them. If the condenser coils are dirty, they won't dissipate the heat effectively. As debris builds up on the coils, the refrigerator becomes less efficient, causing the refrigerator to work harder to cool down. If the coils are significantly dirty, the refrigerator will not be able to maintain the proper temperature. Check the condenser coils to determine if they are dirty-if the condenser coils are dirty, clean them.
2-The evaporator fan motor draws air over the evaporator (cooling) coils and circulates it throughout the refrigerator and freezer compartments. Some refrigerators have more than one evaporator fan motor. On refrigerators with only one evaporator, the evaporator is located in the freezer compartment. If the evaporator fan is not working, it will not circulate the cold air to the refrigerator compartment. If this occurs, the freezer may still get cold, while the refrigerator will not get cold. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor.
Oct 29, 2017 | Samsung Refrigerators
I have a side by side whirlpool fridge and the freezer is fine but the fridge is now freezing everything. It's about 11 years old.
Since you stand to loose all the food I would call a service tech ASAP. But here are the most common reasons for the problem you have.
Cause 1
The Evaporator Coils are Frosted Over The defrost heater assembly turns on a few times throughout the day to melt away any frost that may have accumulated on the evaporator coils. If the defrost heater assembly is defective, frost will continue to accumulate on the evaporator coils, and the coils will become plugged with frost. If the evaporator coils are frosted over, the airflow through the coils will be restricted, causing the refrigerator not to cool. Check the evaporator coils to determine if they are frosted over. If the evaporator coils are frosted over, test each component of the defrost system.
Cause 2
Evaporator Fan Motor The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor..
Cause 3
Damper Control Assembly The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won't let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed.
Nov 19, 2016 | Whirlpool Refrigerators
Evaporator fan not working ge profile pss26mgpa ww
Try spinning the evaporator fan motor with your fingers. If the freezer door was left closd it may have rusted on its shaft and be stuck. We need to test the voltage going to fan if oiling its bearing and spinning byhand does not get it moving. Click Here for a service manual=> HERE and here=> GE Artica Test Sheet The fan motor or a relay on the motherboad may also be defective. You should get 12-13 volts DC at the fan motor, Thanks Sea Breeze
WR60X10185 Evaporator Fan Motor
Dec 10, 2012 | GE Profile Arctica 25.4 Cubic Feet...
Side-by-side refrigerator - freezer is working just fine, but the refrigerator is not cooling.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
I have a GE Profile GSL251FRF BS. For the past week a high pitched squeal/sqeak is heard when the motor is running. What is that and what's the fix?
This is likely one of the fan motors. If it is coming from the lower back it would be the condenser fan and if it is coming from the frezzer compartment it is the evaporator fan. Both are inexpensive and easy to check and replace. Here are a couple links that should help
Condenser fan replacement
Evaporator fan replacement
Dec 21, 2010 | GE Refrigerators
Compressor in fridge not working. Freezer is working fine. Is there a reset button? What steps can I take to see if this is a simple issue?
There is one compressor that serves both the freezer and refridgerator compartments. You need to confirm if the evaporator fan in the freezer compartment is working. When you open the door to the freezer, you should see and hear the evaporator fan in the freezer compartment running. Particularly if there is a demand on the unit through the thermostat setting. If the evaporator fan is not operating, you can check the evaporator fan motor with a volt meter to see if it's getting power. If its getting voltage, but not operating, you need to replace the evaporator fan motor in the freezer compartment. There are 3 wires that attach to the evaporator fan motor. One hot wire, one neutral wire and one ground wire. The ground wire is usually marked green, the voltage wire is usually marked black and the common wire is usually marked white. You should get a reading on your volt meter of a voltage from the hot post to the neutral or from the hot to the ground. If it is getting power but will not operate, then it is definitely a bad fan motor that would need to be replaced.
Oct 04, 2009 | Refrigerators
FREEZER WORKS, REFRIGERATOR DOES'T
Oct 03, 2009 | Refrigerators
I worked on an old delfield freezer hat had r12 in it and the condensor fan and compressor would turn on when I plugged it in but the evaporator fan motor would not come on. I ran 120 vac to it and it ran,...
some older models ran power throughthe door/ light switches, for the evaporator fan, or perhaps even ewired through the defrost thermostat( reason for that is if evap is warm no need to run a fan and circulate hot air through the cabinet did you try letting run for a while mighttake 20-30 min to get cold enough to trip the defrost thermo.I usuallly hit it with a shot of the freon just ot freeze it shut real quick
Apr 02, 2008 | Refrigerators
GE GSH25JFR Side by Side Refrigerator Logo
150 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Joe Lamb
Joe Lamb
