Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
No 110 volt to icemaker
My Kenmore 106.56542400 is not making ice, wont start harvest cycle when jumpering T and H.
Tried removing ice maker and plugging to 110 and tuns OK.
Measuring voltage to ice maker and won´t get any.
Why could be the reason to not having 110V to the ice maker??
thanks
  • Ron Coons
    Ron Coons May 11, 2010
    curiostiy here, do you have a metal arm to turn on/off ice amker or is it electrical senssor on either side of freezer wall?
Additional info:
it has an infrared beam, so on both side walls has an eye. Also on the right side there is an on/off switch.
Apparently the eyes work Ok because pilot light blinks when the door is open and is solid when I move the plastic arm that cuts the beam.
Posted on Mar 05, 2008
Maytag MFI2067AES Icemaker is frozen and cannot be used. It is now a solid block of ice. Please don't suggest using a hairdryer. It does it all the time. Also a hairdryer is useless without dismantling the...
is the fill tube clog? the ice maker is not going to harvest mode. Take the ice maker cover off and put a jumper on T and H hole the dial will turn and wait until you hear the click remove the jumper. make sure you have gloves on. Do this at your own risk, if you are not sure call a servicer. If the dial won't turn you have a bad ice maker (if you have a 115 volts to the ice maker).
Nov 22, 2017 | Maytag MFI2067AES Stainless Steel Bottom...
Kenmore elite in door ice maker is not working... 106.5770*701 water dispensor in door works, infrared sensor and on switch seem to be working properly and bin was removed defrosted and replaced and...
Hi and welcome to FixYa, I am Kelly.
Often the reason ice makers slow or stop ice production is because the freezer compartment has gradually warmed up above 17 Deg F and the ice maker thermostat will not start an ice harvest cycle. What causes this gradual warming is usually the result of either an evaporator fan running slow or an automatic defrost circuit problem caused by a fault defrost timer/control defrost heating element or defrost thermostat / thermistor.
You can use this manual to troubleshoot the ice maker:
http://applianceassistant.com/pdf/inDoorIceSystem.pdf
or
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Note that jumpering T to H requires the ice maker thermostat to sense a termp of 14 - 16 Deg F for the ice harvest cycle to start. If by jumpering T - H under the ice maker front cover the ice maker does not cycle then either the freezer compartment is too warm or the ice maker thermostat is bad.
If it cycles and does not add water... then the inlet water valve solenoid has failed or the ice maker module is not supplying power to the inlet water valve.
Thanks for choosing FixYa,
Kelly
Apr 16, 2011 | Kenmore Refrigerators
My icemaker will get cold but wont make ice.
Here is what the manual says:
3. Icer-ette freezes but water does not come into mold; no ice production.
_____________________________________________________________
3A. Nonfunctioning water valve assembly. 3A. Clean or replace solenoid valve assembly.
3B. Mold heater assembly. 3B. Contact Raritan Technical Support.
3C. Water supply turned off. 3C. Provide pressurized water.
3D. Icemaker module. 3D. Replace icemaker module.
3E. Cold control. 3E. Replace cold control.
3F. Bad wiring harness plug contacts. 3F. Contact Raritan Technical Support.*
Although this is for troubleshooting non optical sensor refrigerators:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
The troubleshooting procedures for cycling the unit are exactly the same,
The ice maker module part number for the 120V unit is PN 628366 (do a net search for this part number and save yourslef a bumch of money if you fetermine your moduleis bad) You start the harvest cycle by removing the front cover and then jumpering test points T to H. The white dial will begin to move if there is power to the module. Remove the jumper when the sweep arm reaches 5" o'clock and let the ice maker automatically cycle. It should harvest, and fill in on complete turn of the white dial. If it does not fill you probably have a water supply or water valve problem. There is an inline input power fuse for the ice maker. Power should come in via the red wire.
Mind you the ice maker has an internal thermostat behind the module assy that has to reach 15 deg F to start the harvest cycle. When you jumper T to H you are bypassing the thermostat. If the thermostat fails or the unit does not reach 15 deg F then the harvest cycle will never begin.
Kelly
Nov 25, 2010 | Raritan Icer-ette Ice Cube Maker
I have a kitchen aide side by side. Icemaker not working. Purchased new icemaker (Whirlpool 4322658A) and new optics. Old optics were bad, old icemaker mold heater burned out. New optics check out fine....
Good day,
Well your savvy, so, let's do it backwards.
Pull the power plug off of the water valve, and insert both prongs from a vom meter set at 150 Ac or higher.
Cycle the ice maker. You have time, fill is at the end of the cycle.
Just before the end of the cycle you should see 120 volts for approx. 7 seconds. Don't blink.
If you do get power, replace the valve. Jumping them will not always do the trick.
If no luck, then it has to be an ice maker issue. I've installed more than one that never worked from the time of installation.
P.S. You said the water line was not frozen. It's the fill tube that runs from the back of the machine into the ice maker that freezes and is a common problem.
If you can, remove the plastic tube from the bottom of the ice maker (it's the 1/4" inch smaller of the two if you have water in the door). You should be able to blow thru it freely. If not it's iced, problem with a filter ect.
This should be done first.
Thanks for using FixYa.
Dec 19, 2009 | Refrigerators
Ice maker doesn't work . It appears the timer no longer running. There is ice in the unit, but the shaft does turn to eject the ice.
What brand...? Pull off the white cover, make a short jumper wire, stripped about a half inch and stick the ends in the "T" and "H" holes. This should start the harvest cycle. (Make sure the feeler arm is down! Duh...)
If this doesn't do it, check for 110 volts between the black and white wires. That white blob on the black wire is a fuse. If it's blown, you likely need a new icemaker.
You, of course, didn't specify make or model, so these recommendations are generic. If you have a Whirlpool SxS with the sideways I-mkr with dispenser in the door, all bets are off! There is a poop-sheet about how to troubleshoot the i-mkr and electric eye computer **** stuffed in the grill plate under the doors.
Oct 25, 2009 | Refrigerators
Icemaker diagnostics
Use an insulated piece of wire , with both ends stripped about 1/2 " . Insert on end into the T hole , and the other into the H hole . This will start the cycling process for the ice maker (bypasses the thermostat) and makes the motor run . Only need to start the motor and then remove the wire and let it go on its own . Do not keep the wire in the test holes .
Sep 25, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Replaced water valve to ice maker -used jumper method on the ice maker to test - worked once then not again. checked the voltage coming in and it was 33 volts the ice maker also won't cycle with the jumper...
You need to replace the icemaker . Pt # 2198597 . When you open the freezer door . the laser flash 2 times , then pause , then 2 more times continually (normal) ? If the laser does not light at all , then icemaker is in the harvest mode ( may be stuck , replace icemaker ) . If in harvest mode , even slightly , jumper will not work .
Aug 29, 2009 | Refrigerators
Ice maker
remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
May 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kemore coldspot no ice?
no you ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Mar 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Icemaker won´t work
if you got 110 volts to ice maker. try jumping out the T & H ( a small insulated copperwire) . this will cause the ice maker cycle, if this does nothing replace the ice maker.(entire assy cheaper then the parts). remeber you might have to shut the door switch to get the 110v. some machines run the power through light switch
Mar 04, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
126 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
