L need the wiring diagram for an GE washing machine motor model #5kh4zdt74s it has 5 wires colored ( black, white, yellow, orange and blue ) the orange goes to a bi-metal circuit breaker either for over-load or more likely for disconnecting the start winding? then to one side of the start winding. the white also goes to the same side of the start winding. black to the other side of start winding. blue and yellow both connect to separate run winding ends?
  • Synnott Marcel
    Synnott Marcel Oct 30, 2016
    Thank-you very much, very appreciate
  • 113 Answers
I was unable to find your model but maybe there are some other clues to the model's number you can use on this web site.
http://www.geappliances.com/service_and_support/literature/
Also all washing machines include a wiring diagram underneath the control panel at the top. Unscrew from behind and the sides and remove, be careful of the wiring. You don't want to pull a connection out.
Posted on Mar 05, 2008
I HAVE A LG PUNCHMASTER, AND THE MACHINE NEEDS TO BE RESET, HOW DO WE DO THAT?
Posted on Jun 28, 2010
Looking for wiring diagram for door locks on a 2005 f250
PASSIVE ANTI-THEFT YES TRANSPONDER SEE NOTES 12 VOLTS Yellow Ignition harness IGNITION RED / green Ignition harness IGNITION 2 Blue/green This wire is only required on the V-10 Gas engine. ACCESSORY RED / black Ignition harness ACCESSORY 2 Gray / YELLOW Ignition harness STARTER Dk.green Ignition harness KEY SENSE BLACK/ pink In airbag plug on right side of st. column TACH SIGNAL Use an injector DIESEL TACH SIGNAL GREEN / WHITE SEE NOTES Look below the relay box under the dash for a large loomed harness. There are some wires taped to the harness terminated with heat shrink tubing. You will find the GREEN / WHITE among these wires. LOCK WHITE/ red In harness above gas pedal On 4 door models, these wire are negative trigger. Vehicles with no keyless entry, colors are Pink / YELLOW for lock and Pink/green for unlock in 5-wire reverse polarity. They will be found in either kickpanel. UNLOCK BLACK/ white In harness above gas pedal On 4 door models, these wire are negative trigger. Vehicles with no keyless entry, colors are Pink / YELLOW for lock and Pink/green for unlock in 5-wire reverse polarity. They will be found in either kickpanel. DRIVER LOCK MOTOR Pink/black In harness above gas pedal DRIVER UNLOCK MOTOR RED / orange In harness above gas pedal PASSENGER UNLOCK MOTOR Pink/orange In harness above gas pedal GLO-PLUG SIGNAL DATA ONLY USE DELAY TIMER DOORPIN BLACK/ blue Above parking brake in DKP The vehicle's computer sends out diagnostic pulses on this wire every 15-20 minutes. This may cause an after-market alarm to false. It is suggested that you add a relay to this wire when connecting to an alarm system. See the appropriate diagram for exact wiring instructions. FACTORY ARM Yellow/black Above parking brake in DKP This is the driver's doorpin wire. Pulse this wire at the same time as lock to arm the factory alarm. FACTORY DISARM Dk.GREEN/ purple In harness above gas pedal BRAKESWITCH Green At switch above brake pedal PARKLIGHTS Brown At light switch harness HAND BRAKE Lt.GREEN/ red At plug above handbrake lever HORN Dk.blue In airbag plug on right side of st. column
Dec 25, 2017 | Cars & Trucks
Need to change a broken blower motor in RUUD central air unit. Old central air blower motor (GE electric) was connected with brown and orange wire to 15 MHD capacitor. Another orange wire from central air...
on the motor should be a diagram detailing the wires. brown white goes to either side of the capacitor and brown wire to other side of capacitor. hi speed goes to normally open contact on the indoor fan relay and the wire designated common on the motor goes to the other side of power from the relay contacts.
Oct 03, 2012 | Heating & Cooling
Were can i find a color coded wiring diagram for a radio in a 1999 ford explorer
For 1999 Ford Explorer Car Stereo Radio Wiring Diagram check this...
Car Radio Constant 12V+ Wire: Light Green
Car Radio Switched 12V+ Wire: Yellow/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Blue/Red
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: Blue
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 5 x 7
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): Dark Green/Orange
Right Front Speaker Wire (-): White/Light Green
Rear Speakers Size: 5 x 7
Rear Speakers Location: Rear Door
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Hope helps (remember to rating this free answer).
Oct 03, 2011 | 1999 Ford Explorer
Factory stereo system color diagram for 92 ford f150 5.0l 8cyl. truck
1992 Ford F150 Truck Car Stereo Wire Diagram
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Blue/Red
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Aug 19, 2011 | Ford F-150 Cars & Trucks
I've lost the wiring diagram
I couldn't find a manual or wiring diagram for this model, but I am fairly sure this is it:
Yellow - Constant +12v (for memory retention)
Red - +12v Switched (ACC)
Black - Ground
Blue - Power Antenna
Orange - Illumination
Green - Left Speaker
White - Left Speaker
Purple - Right Speaker
Gray - Right Speaker
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 19, 2010 | Pyramid 100S Cassette Player
Color diagram for a clarion radio
If this is a factory radio - the year would be required.
However just before 2000 model year... and for a couple years after - the following wiring colors are prettymuch constant....
Constant 12V+ Red/White Switched 12V+ Red/Yellow Ground Black Illumination Green/Red Dimmer Red/Yellow Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Blue Left Front (-) Yellow Right Front (+) Green Right Front (-) Gray Rear Speakers 4" Roof Mount Left Rear (+) Orange Left Rear (-) White Right Rear (+) Orange/Blue Right Rear (-) Orange/White
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 07, 2010 | Clarion Car Audio & Video
Need a wiring diagram for a radio on a 93 Explorer. The speaker wires in my truck are Green, Purple with white stripe, yellow, blue w/white stripe, Lt. Blue , Orange w/white strip, brown, and red w/white...
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black
Illumination Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 5" x 7" Doors
Left Front (+) Orange/Green
Left Front (-) Blue/White
Right Front (+) White/Green
Right Front (-) Green/Orange
Rear Speakers 5" x 7" Rear Doors
Left Rear (+) Pink/Green
Left Rear (-) Brown/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Black/White
THanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 08, 2009 | JVC KD-G210 CD Player
I need a wiring diagram for this stereo
FOR 16-PIN HARNESS
Pin Number Wire Color Function 1 White Left Front (+) 2 Green Left Rear (+) 3 Violet Right Rear (+) 4 Grey Right Front (+) 5 Blue/White Amplifier Remote 6 Blue Antenna Remote 7 Red Accessory 12 Volts 8 Black Ground 9 White/Black Left Front (-) 10 Green/Black Left Rear (-) 11 Violet/Black Right Rear (-) 12 Grey/Black Right Front (-) 13 Sky Blue Telephone Mute 14 Orange/White Illumination 15 Not Used Not Used 16 Yellow Constant 12 Volts
FOR 9-PIN HARNESS
Pin Number Wire Color Function 1 Not Used Not Used 2 Black Ground 3 Grey Right Positive 4 Grey/Black Right Negative 5 Blue/White Amplifier Remote 6 Red 12 Volt Switched 7 Yellow 12 Volt Constant 8 White Left Positive 9 White/Black Left Negative
MAY THIS HELP YOU
Jul 04, 2009 | Sony CDX-GT210 CD Player
I need the wiring diagram for the radio on a 1994 nissian quest gxe
Constant 12V+ Brown/White
Switched 12V+ Orange
Ground Black/Light Green
Illumination Pink/Black
Dimmer Pink
Left Front (+) Gray/Blue
Left Front (-) Yellow/Blue
Right Front (+) Blue
Right Front (-) Yellow
Rear Speakers 5" x 7" Side Panels
Left Rear (+) Blue/White
Left Rear (-) Blue/White
Right Rear (+) Blue/Black
Right Rear (-) Red/Blue
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 13, 2009 | 1994 Nissan Quest
Car stereo wiring (1993 Ford Taurus GL)
My guess is that ford did not change that much in a year.
1994 Ford Taurus Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Yellow
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Dimmer Wire: Light Blue/Red
Radio Antenna Trigger Wire: Orange/Blue
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Right Front Speaker Wire (+): White/Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Pink/Light Green
Left Rear Speaker Wire (-): Dark Blue/Orange
Right Rear Speaker Wire (+): Pink/Light Blue
Right Rear Speaker Wire (-): Tan/White
Jan 13, 2008 | Car Audio & Video
Washing Machines Logo
314 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
