Question about Jenn-Air JCD2295HES Side by Side Refrigerator
JCD2295HES side by side not working correctly
About a month ago, our 3 yr old Jenn-Air froze up and the water container cracked. I replaced the container and the fridge worked fine until 2 days ago. Then the unit froze up again, but the water container didn't crack this time. I left it unplugged for a day to see if the evaporator would thaw out, but no luck. The fan in the fridge compartment wasn't running when I plugged it back in. Does this sound like a thermostat problem or a fan problem?
  • 3 more comments
  • hank vera Mar 05, 2008
    Correct. What I meant what was that the fan in the freezer compartment is not blowing at all and there was frost on the evaporator.
    In the meantime, I pulled the sheet metal off the back of the freezer compartment. The fan is running, but making an odd sound and it doesn't push the air very forcibly. When I felt the vent on the fridge side to see if air was being pushed through, there was none. Any suggestions?
    Also, when I plugged it back in, the evaporator was getting plenty cold, but frost was building up on it. Could this be a thermostat problem and how difficult is it to replace the fan motor?
  • hank vera Mar 18, 2008
    Even though the motor had technically been working, I replaced it and it and that solved the problem. So far, so good. Pretty sad when something like that goes out after only 3 + years. Doesn't say much for Jenn-Air.
  • Ron Coons
    Ron Coons May 11, 2010
    the fan is in freeze rcompartmrnt not refrig correct?aside from water container, is foodfreezing in refrig section?? evaporator section should have frost on it was it solid ice???
    President:
  • Jenn-Air Master
  • 2,651 Answers
Yes that does sound like a bad evap fan motor then unable to circulate air aorund and off hte evap thus building up frost.you can pull the wire leads of the fan motor and ck for 110v. to confirm that you are indeed getting power to the motor.
Posted on Mar 05, 2008
  • Ron Coons
    Ron Coons Mar 06, 2008
    does sound like a defrost issue, the fact the fan blows means its good. looks like the control / display board controls the defrosting, take a look behind the kickplate under the right side to a techsheet, shloud be able to "force a defrost cycle",
Not cold.
There is a good chance that the heater in the freezer is not working. If it is not working the coils in the freezer do not defrost and you won't be cooling either side. [cooling coils are froze up and the air fan cannot deliver cold air to either side and air fan cannot remove warm air from either side]. You might also want to check the defrost timer switch.
Mar 25, 2013 | Jenn-Air JCD2295HES Side by Side...
Jenn-air JFC2089HES french door
Check the water hose and make sure is not kinked.
The hose might be frozen as well.
Mar 31, 2008 | Jenn-Air JCD2295HES Side by Side...
I have a Jenn-Air side by side refrigerator. JRSD209T. Water fills up the ice shute and runs into the floor. What stays in the freezer freezes in the chute. What do I need to change to fix this problem
From your description I'll gather you're not getting ice cubes either and need to replace the ice maker
Part # D7824706Q on the diagram labeled "Lights and Ice maker" it's item 1
This is from Sears so you can order and have it delivered to the house
http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Refrigerator-Parts/Model-JCD2295HES/1266/0165000?pathTaken=
Jan 01, 2011 | Jenn-Air JCD2295HES Side by Side...
Jenn Air freezer does not 'automatically defrost-side by side
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem
Nov 29, 2009 | Jenn-Air JCD2295HES Side by Side...
4 year old jenn-air refrigerator not making ice
first please check you water delivery chanel behiend icemaker, it may freeze up... second you water valve on bottom part on the back is duel( one valve for water dispencer and another one for ice maker) you have to check if it is a power going to that icemaker valve, unplug icemaker inside freezer and plug back now check for power but you have acting fast, ask somebody for help... and third it could be icemaker it self... good luck for additional questions please totalcarefl@yahoo.com
Sep 09, 2009 | Jenn-Air JCD2295HES Side by Side...
Jenn-Air refrigerator is not making ice but it's dispensing water
It can take up to 24 hours for a new ice maker to make ice.  Check it tomorrow.
May 31, 2009 | Jenn-Air JCD2295HES Side by Side...
Fridge keeps freezing
Chances are, they replaced the wrong parts, or didn't replace all the parts, assuming they replaced an electric motor kit. I would need to know the P/N of the electric motor kit to confirm what was replaced.
Based on the fact that it froze the drinking water tank, and if they replaced the electric motor kit, the problem is more likely the temperature sensor or the control board.
Let me know what the P/N is of what they replaced and we can be more precise.
Jan 01, 2009 | Jenn-Air JCD2295HES Side by Side...
Jenn Air (french door freezer on bottom) icemaker - 2 years old
the water supply in the unit may be blocked or frozen up at some stage, i would try a full defrost for 36 hours and then try it out.
Jun 06, 2007 | Jenn-Air JCD2295HES Side by Side...
Jenn-Air JCD2295HES Side by Side Refrigerator Logo
145 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
