Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Ice maker isn't making ice...
I noticed a few weeks ago that our ice maker wasn't producing much ice. When I tried to get ice a few days ago, I noticed there were only like 3 pieces of ice in the compartment. I checked to make sure it was switched on and the little overflow flap was down and it is. Does anyone know why it's not producing ice?
  • 3 more comments
  • tandknix Mar 05, 2008
    I noticed that their isn't a overflow flap to turn it off it is full, but the little white thing that is on the side is down. Don't know if that means anything.
  • dentguy Apr 18, 2008
    Ice maker is not producing any ice. Water is working fine, but no ice.
  • Anonymous May 05, 2008
    Second major problem with this POS fridge, First the dreaded and common circuit board failure now no ice. Water but no ice.
    Have checked the on off switch, made sure that unit is pushed all the way in and checked the white lever switch in side.
    Any one want a great deal on a slightly used fridge?
  • emsephs Jun 10, 2008
    I am having the same problem but the overflow arm is in the down position and there is no ice 20 hours after emptying the ice out to fill a cooler. The water is working fine.
  • ben-penn Oct 03, 2008
    Recent move with the fridge. Ice bin was full when we packed it up. New location, water is fine, no ice. Lever down, switch on, unit clicked in. Has made about a cup of ice in a week.
Check the white plastic lever inside the ice box. it needs to be in the down position to make ice and is probably stuck.
Posted on May 04, 2008
2 Suggested Answers
tborn6
  • 700 Answers
SOURCE: Ice maker isn't making ice...
there appears to be a problem with 1. the temperature needs to be turned down to produce Ice. also is the fill tube frozen where the water goes into the ice maker sometime you have to thaw it to get the ice out of it and the reset the maker too. Let me know if this helped and if it did not don't rate and ask another question from me and I'll be galad to help. If it did would you please rate this solution please. Thanks for using FixYa.
Posted on Jan 01, 2009
U Line Ice Maker not working at all
if your drain pump is the one you plug your ice maker into and then the pump into the wall plug the pump is full and will not let the ice maker run. must be something wrong with pump
Nov 14, 2013 | U-Line Icemaker
We had a water main break down the road a few days ago. Since then, my Series 600 ice machine hasn't produced ice very well. I tripped the breaker to try to reset it but no improvement. Suggestions,...
when the main broke ,sediment collected in pipes. were you asked to flush youre pipes before drinking the water? it is possible youre supply line to the ice maker is clogged with sediment. take off the supply line and make sure water is reaching the ice maker. if it is ,youre filter or inlet may be clogged. hope this is the fix.
Apr 14, 2011 | Refrigerators
Ice maker stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
jkkjffkj
Jun 27, 2010 | LG LFX25960ST Stainless Steel French Door...
Ice maker not making ice
Try changing the filter; our refrigerator did the same thing.
Jul 17, 2009 | Frigidaire FRS6R5EMB Side by Side...
Jan 01, 2009 | Refrigerators
10 yr old Frigidaire ice maker stopped making ice
try forcing the cycle by manually triggering the cycle a few times. Sometimes you can detach the trip arm or turn the tray by hand by disconnecting it from the gear. There may have been a switch bumped to turn it off or the switch somehow jammed. Maybe check for freeze-up. If there is water in it, it's going somewhere.
Sep 27, 2008 | Frigidaire FRS26R4A Side by Side...
Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Sep 19, 2008 | LG LSC26905TT Side by Side Refrigerator
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
Oct 30, 2007 | Frigidaire FRS3R5EMB Side by Side...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
435 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
