Question about Dryers
How can I clean my dryer's hose - Dryers
    President:
  • Dryers Master
  • 2,651 Answers
What material is it made from.???
if white vinyl hose, i would recommend replacing not cleaning.Manufactures consider that a potential fire hazard and do no suggest using any longer.
they make a cleaning tool for metal vents. inserted into one and and pulled through scraping walls as they go removing lint build up( i purchased mine at the home depot(it was made for cleaning 4in. chimney pipes. but that only works on solid piping, you'll rip any other. beyond that there are companies out there that specialize in vent cleaning
Posted on Mar 05, 2008
A burning smell inside the drum when I use the gas dryer
The burning smell is usually one of two things. If it smells like burning rubber the dryer belt is on its last leg and is slipping or stuck. If you are a diy'er the replacement of the belt is more time consuming than difficult. If it just a burning smell, then it is most likely lint built up inside the exhaust. You'll need to scoot the dryer out and get behind it to take off the dryer hose that vents from the dryer to the outside. Take off both ends for the most convenient and thorough cleaning. You'll need to blow out the hose with an air compressor and/or push a cylindrical brush through the hose or a rag on the end of a long stick. Be care not to puncture the hose! Once done, you are not finished cleaning. The back panel of the dryer needs to be removed to access the exhaust's internal pathway. You can try to clean it from the lint trap and the place in the rear where the dryer hose attaches, but be aware that cleaning cannot remove all the lint stuck to the exhaust pathway lining. At Home Depot, Lowe's or Menard's they sell brushes on wire, etc to clean the dryer's inside exhaust pathway.
Hope this helps!!
Jun 13, 2016 | Dryers
Electric dryer duct fire
I think this question must have been misclassified, as it states that this is regarding a Problem with Whirlpool Cabrio WTW6600SBT Top Load Washer. I will assume this is about your dryer. Dryer fires are not as uncommon as most would believe. It sounds like you were utilizing the nylon or plastic dryer vent hose. The lint in your dryer that accumulates can catch fire after years of use. A good dryer vent cleaning will cover your vent duct from the wall to the vent exit outside the home. You should have this cleaned by a professional and have an internal dryer cleaning conducted. If funds are tight, you can do this yourself by pulling the dryer out and running the vacuum cleaner extension into the dryer vent opening after you remove the melted hose. Just be careful when pushing the hose extension up the exhaust as some models will have a heating element in line. If you feel any resistance, that is when you stop pushing the hose in and just suck any lint you can from that point. This is a good start, but a good full internal cleaning of your dryer is warranted. Make sure you unplug the dryer before attempting any cleaning or servicing. Safety first!
Feb 19, 2014 | Dryers
Originsal problem - dryer would stay on for a half a day on medium heat. Worked fine on regular. Then I cleaned the dryer and vent. I may have possibly tore the vent when cleaning it, but can't find...
Did you also clean the exhaust hose of your dryer, a build of lint in the hose will really hurt the dryers ability to dr your clothes.
A pin hole tear in the dryer vert screen shouldn't have that big effect on the operation of the machine.
Jul 01, 2011 | Dryers
The tumble dryer is working perfectly and is vented through the external wall with a plastic hose , however the dryer is producing high moisture levels we have checked the connection fro the dryer to the...
Your problem is probably a heavy lint build up in the Dryer or Hose.
Check your blower system on the dryer for a heavy lint build up, also remove to clean or vaccum or whatever is necessary to clean the plastic tubing because they will still flow some air, but be really plugged up with lint and could cause a dryer fire.
This is a free answer, Please rate me
Apr 11, 2011 | Dryers
Dryer takes too long to dry clothes. Heating element is working because clothes are hot but it takes almost 2 dry cycles to dry clothes.
It sounds like you're lacking air flow. I'm sure you're cleaning the lint trap / filter - but have you clean the VENT HOSE / PIPE?
The 4 in vent hose is supposed to be cleaned annually. If you have the flexible vinyl hose, replace it with either steel, aluminum or flexible aluminum tubing instead. Once you've removed the vinyl hose, it will collect a lot less dust and can be cleaned without worry of puncture.
A typical dryer vent brush.
Make sure there's no obstruction to the flap outside, too. Once cleaned the dryer operation should be restored to new again.
I hope this helps & good luck! Please rate my reply - thank you.
Mar 09, 2011 | Dryers
My dryer is heating fine but there is no air blowing out of the vent. Therefore, clothes are not drying properly. I have cleaned the lent filter, checked the outside and and inside vent for clogs or...
run the dryer with the vent hose off, if it drys correctly then it is in the vent tube. The best way to clean the vent hose is with a leaf blower, now if it is not drying with the vent hose off then you will need to disassemble the dryer, and clean from the bottom of the lint trap back to the back of the dryer with a brush(paint) and a vacuum:
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
Feb 16, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My hotpoint dryer takes hours and hours to dry clothes?
clean the vents as it is an air restriction, first take off the vent house run dryer and feel for hot air, if no or little hot air then then inside of the dryer needs to be cleaned, now if you run the dryer with the hose off and it drys like it should then the vent hose needs cleaned/unrestricted. Hope this helps Tim
Nov 07, 2010 | Hotpoint Dryers
I have lint all over dark clothes EVERY time I wash. This problem is getting worse. What can I do?
If you have cleaned the lint trap, unplug the dryer and you should remove the exhaust hose in the back of the dryer, you should clean out as much of the dryer as you can inside the hole where the hose attaches,
using a duster with a round head, one that is round with bristles all oner it is perfect for cleaning out the hose.
I do not know how long it is and where it goes to the outside vent, but if it is not right there, you can either replace the hose, or take a shop vacuum and put it on reverse so it blows out air, put the vac hose in the dryer hose and fill in the space with some cloth or a towel so that the lint does not cover you, and blow out the hose.
If you can take a ladies stocking and place it on the back of the dryer
a take the ring that holds on the hose to hold on the stocking and plug in the dryer, then set it to cool or no heat and run the dryer for a minute or so, this will blow out all the lose lint from you cleaning it.
The stocking should fill with air, and there should be a strong amount of air coming out of the dryer, if not it is still clogged.
Feb 11, 2010 | Maytag PAV2300 Top Load Washer
May tag it heat up but no air is comming of the hose that leads out side
Your vent is propably restricted with lint. Have entire dryer vent system cleaned. Make sure first that the dryer is blowing ok by taking hose off back of dryer. If air comes out dryer without hose attached but no air out vent when hose is attached then the vent hose or duct work in house is clogged.
Feb 02, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer does heat but takes 3 hours to dry a medium size load of clothes
Sounds like the moist air is not being properly vented. Your dryer has a fan that pulls in dry air and expells the moist air. This is vented thru your dryer hose and should be vented to the outside of your home. Sometimes the hose will get either a blockage or a partial blockage that will make it either not dry your clothes or take longer than it should. I have seen hoses that have a sag collect water much the way your trap will under a sink. You can either throughly clean the hose, and check for a blockage in the hose or the dryer itself, or you may, as a test, disconnect the hose temporarily and vent your dryer into an old pair of panty hose. When you turn the dryer on, the panty hose should inflate. Also make sure you keep your lint trap clean...EVERY LOAD.
Oct 02, 2009 | Amana DLE330RAW Electric Dryer
Dryers Logo
62 people viewed this question
Top Dryers Experts
