Problem for Projection Televisions
Generic problem for all Projection Televisions
TV trouble shooting
No power when power is turned on
Clarification Request
Posted by Terryfic on Mar 05, 2008
Please provide Make,Model,Chassis numbers from back of set and Mo / Yr built if it is there......also, is there a power indicator blinking on front of set ?.....................T.
Same Problem
Apr 03, 2009
i have the same issue that this individual has...what is the most likely problem.
Posted by
rbtjr2005 on Oct 14, 2008
i have power to the
tv however when i press the power button on front of the tv all i have is a click sound from the back. the red power light will not come on. please help!!!!! -
luckey777 Dec 06, 2008
-   The set won't power up,the red light blinks. Had trouble with double images and picture would sag, before it stopped powering up. At first you could get it fixed using perfect focus. Replaced the convergence board and still no power. Any one have any ideas?-
gsouers Nov 19, 2008
-   PT61G63W-set does not turn on with remote or manual control on front of set. No power on light-   Guest Oct 14, 2008
-   i have power to the tv however when i press the power button on front
rbtjr2005 Jun 01, 2008
-   Before getting this problem last 3-4 month I was getting FINAL WORNING REPLACE LAMP Every time when I was trying to torn on my TV
,Starting yesterday No power when power is turned on-   Guest
Popular Solutions for Projection Televisions
RCA D52W20 52 in. Rear Projection HDTV-Ready Television
1 Solution
Mitsubishi WD-52725 52 in. Rear Projection HDTV Television
1 Solution
Mitsubishi WD-52525 52 in. Rear Projection HDTV Television
1 Solution
Toshiba 42H81 42 in. Rear Projection Television
1 Solution
Questions and Unsolved Problems for Projection Televisions
i HAVE A 47" PANASONIC REAR PROJECTION TV. pURCHASED NEW FROM CIRCUIT CITY DEC 2001. wORKS...
(More)
i HAVE A 47" PANASONIC REAR PROJECTION TV. pURCHASED NEW FROM CIRCUIT CITY DEC 2001. wORKS EXCELLECNTLY NEVER HAD A PROBLEM WITH IT. NOT USED AS MUCH AS A FAMILY ROOM TV, WHICH ARE ON CONTANTLY. WE WERE TOLD THAT THESE WERE NOT OPTIMUM FOR GAMING THAT WAS FINE FOR NOW. WE ARE LOOKING TO REPLACE IT WITH A LCD. WHAT WOULD BE A GOOD SELLING PRICE FOR THIS OLD UNIT.
my insignia lcd tv color tv dvd video player cuts off afther 10 mins how to fix
where is the f850 and f 852 fuse and where can i buy them
I have a panasonic projection t.v. which I got information from a SD Tech who answered my question....
(More)
I have a panasonic projection t.v. which I got information from a SD Tech who answered my question. I replaced the two convergence chips with STK392-150's but he said to check and replace the light blue resistors in front and around them. My problem is where can I get these because the ones at Radio Shack are different. He also said they are marked 2.2. Some are 2.2 OHM and some are 120 OHM and some are 82 OHM. Do I only need to replace the 2.2's? I also have five light blue ones on other side of board labeled 33K OHM J, they look like they have been pretty hot should I replace these also? If you could please get back to me at jdmeek@netins.net
im geesha ihave 43g9uxe projection t.vthe problom is hear the sound colour guns are does not...
(More)
im geesha ihave 43g9uxe projection t.vthe problom is hear the sound colour guns are does not work.what can i do now?
7 Other Users Have The Same Problem - Continued
Comment by D_Mill, posted on Mar 30, 2008
I replaced my Samsung HCM4215W (AA95-02002A) about two years ago. While watching the Rose bowl the green color bowed then the red coler bowed then the power went out all at the same time and the set will not power on not even the red standby light comes on. I took the back off and plugged it in and I hear a high pitch wind up then nothing happens. I am an aircraft mechanic but not a tv repair man. I'm sure there are a couple fuses blown or resistors fried maybe. What can I do?
Comment by gate3, posted on Mar 05, 2008
d52w20 rca no power no light at the front check the fuse inside and its ok now any input would be nice gate
