Question about Reddy Heater-170,000 BTU Kerosene Deluxe
110,000 kerosene heater wont work
Its always worked then i pluged it in today and it just buzzed for a sec and then stoped. i on plug it and try it again and does the same thing please help if you can
  • Anonymous Jan 22, 2009
    I plug my 110000 BTU heater in, and nothing happens
  • Todd Gibb May 11, 2010
    Need a model # to look at electrical diagram to try and help.
    Problem Solver:
  • 6 Answers
All of this model heater use a triac to turn on the motor. The buzzing you hear is because the triac is only turned on half the time due to a component defect on the control.
Replace the control.
If you are good with a soldering iron, replace the component labeled "OC2" on the circuit board. This is the optical isolator that caused the triac to "half-wave". Component is a MOC3023
Posted on Jan 07, 2009
My Dayton 110,000 btu kerosene torpedo heater... The fan kicks on for a couple secs then kicks off it seems as it's not getting any fuel what should I do
Could be the Flame out sensor cutting the power to the electrics and therefore the forced air fan. It forces the heater to shut off should the flame extinguish. It might also be the temperature limit control which also turns the heater off if the internal temperature rises to an unsafe level. If either of these two possibilities the unit may need a service.
Dec 09, 2014 | Heating & Cooling
My Master 110,000 btu heater won't start after plugging it in. The tank is full of fuel. Any recommendations .
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
Dec 18, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Heater used once 3 yrs ago. Now wont start.
When the heater hums is the fan turning. If it is I would add more Kerosene. There is no shut off but the Kerosene is sucked out a tube from the top of the tank. This tube does not reach quite all the way to the bottom of the tank. Your heater should hold about 9 gallons if it is empty. A couple of gallons would give it plenty to run though. Let me know.
Jan 02, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
My 110,000 reddy heater flames up then after a minute or two just blows cold smoke???
Time for a Full tune-up, plug--fuel filter- 2-air filters -vanes in the pump.
Dec 13, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Wont start
It sounds like it may be a thermocouple. I suggest calling Master Parts at 800-446-1446. You can find them online at I hope this helps...
Mar 22, 2009 | Reddy Heater-40,000 BTU Kerosene w/T'stat
110,000 btu all-pro heater 2years old ,runs 2 mins and cut off ,cleaned filter,didnt help
take off rear plastic filter end cover. check very close for hair line cracks and make sure that plastic rib that seats around cork portion of gasket is not warped
Feb 20, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Reddy Heater will not ignite flame
Please answer the following questions. There are several folks on the board that can help but we need to know some vital information so we can get started. Answer these, if you can:
  1. Which Pro 110 do you have. We need the exact model number. Pro 110 is a series of heaters.
  2. Does the heater have a spark plug or a glowbar (HSI)?
  3. When the motor runs is it pumping fuel?
  4. When the motor runs is the spark plug firing (or glowbar glowing)?
Nov 13, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater 110,000 btu forced air portable kerosene
try this, take off the top cover. plug in the heater and when the humming starts, rotate the fan sharply with a screwdriver. keep your fingers away from the fan. if the fan spins under power your start winding is shot. get a new motor. www dot desatech dot com
Dec 06, 2007 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
268 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
