Question about Siemens SpeedStream 2624 (SS2624) Wireless Router
Password I have already installed the wireless router and it works but I can't figure out how to put on a password.
  • 89 Answers
Hello, If you haven't changed anything from default, in address window type this should be default address for router. It will then prompt for a ID and Password..enter admin for ID and if needed the same for password. This will let you into the router settings and where you can change SSID and Enable Firewall, WEP or WPA..Hope this helps, thanks
Posted on Mar 05, 2008
Hi l have a problem at the moment my netgear works but need to no if mine has a password on it have to install another laptop can you let me no thanks. can you let me no dont no if the technicion has put...
If you need the password to access the router's interface, by default the username is admin and the password is password.
If you need the password to your wireless network, you will need to access it's interface, using a computer already connected (wireless or by ethernet) to the router.
In your web browser, type the address and enter the username and password above to access the router's interface. If the address is not valid, try
Once in the interface, click on "wireless settings" in the menu on the left. There, you should see the type of security used by the router and the password (or key) should be clearly visible at the bottom of the page,
May 13, 2011 | NetGear WGR614 Router
I have a nieghbor who has somehow found out my password. How can I change my password so he can't use it anymore.
you can change your wireless encryption password by going to internet explorer or
the default login/pass
  • Username = admin
  • Password = password
    • For older devices, password = 1234
if this does not work you will need to reset your router by holding the reset button for 30 seconds or more when you power it on.
  1. Use an Ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. In a web browser, enter the router's IP address - either or by default.
  3. When prompted for a Username and Password, enter the default username and password (admin;password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
    For Steps 4-9, refer to Figure A below.
  4. Select Wireless Settings from the Setup menu in the left-hand navigation bar.
  5. Under Wireless Network, enter your desired network name in the Name (SSID) box.
  6. Under Security Options, select WPA-PSK [TKIP] + WPA2-PSK [AES].
  7. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into thePassphrase box.
    • WRITE DOWN or KEEP NOTE of your network name, security option and passphrase - you will require them to connect wireless computers and devices to your network.
  8. Click Apply to save the settings.
Mar 29, 2011 | NetGear MR814 Wireless Router
Hello, i have a ipod touch everytime i go into my wifii it's say belkin54g i click on there and it ask for a password i do no have a password i have already looked at the back of my interent box there it...
its the same password for the wireless account it wouldnt be on the router. when you installed the router to your computer you needed a password whatever you put in for the password its the same thing
Feb 01, 2011 | Computers & Internet
Pasword protect my router how?
There are two kinds of password protection for your ROUTER;
(1) The Web Interface can be password protected by changing the default password
(2) The Wireless connection password (encryption)
Which one do you want enabled to protect your router?
Jul 27, 2010 | NetGear WGR614 Wireless Router
I have a Linksys Wireless-G WRT54G Router. during the installation, i get to a password stage. there are already numbers filled in. I click on next and the installation does not progress. I get sent...
Just to put it out there I am a network specialist so my advise is something to consider
Try this..
1. Look on the back on the Router and while its plugged in press and hold the Reset button for a least 10 sec. You should see the lights on the front change or blink. After that let it sit for a few min. Then try to run the cd installation again. When it comes to the username and password .. Not enter a username just put admin for the password. That should let you finish your setup.
Now there is 2 ways to set up your router.
Use CD (For New Users That Are Not Familiar With Routers)
Login manually by opening your web browser and typing
Do not enter a username and for the password put admin.
That will take you to the manual setup for the router.
Once you set up your router make sure you change your password from admin ..
Hint: Use WPA Personal or WPA 2 Personal security to secure your wireless network. WEB security is junk and not very secure
Jul 21, 2010 | Linksys Wireless-G WRT54G Router
Installation cd missing for wireless router
You do not need the disk
While it is powered up look for the reset button on the back and put a pencil or other non-metallic onto the button and hold it in for 10 seconds
It will reset and set the username to "admin" and the password to "password" or "admin"
If this does not work do not put in a username but enter "admin" for the password
You can then use the setup wizard to connect the internet broadband
Jan 17, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Password forgotten
What you need to do here is to get the Wireless security from your Linksys router by accessing its setup page, Just type on the address bar of your working computer then that should be asking you for a username and password, just leave the user name blank and type admin for password. If you're already on the router setup page you will see there Wireless tab just go to it and after that go to Wireless security sub tab under wireless and you can find there the wireless key that you need..
If that wont work contact me back for further help....
Don't forget to rate the solution FIXYA thank you...............
Oct 20, 2008 | Linksys Wireless-G Broadband Router
Password Problems
Maybe you are getting LIMITED OR NO CONNECTIVITY. This happens when the wireless adapter is able to find a network but the pc cannot get an ip address. One of the reason for that is that your wireless network might be secured and you missed to enter the correct network key when you were asked by the computer. The wireless security is set on the wireless router, SO WHEN YOU SET THE PROFILE ON YOUR WIRELESS ADAPTER, YOU SHOULD ALREADY HAVE THE WIRELESS SETTINGS FROM YOUR WIRELESS ROUTER. THEY HAVE TO MATCH FOR YOU TO HAVE A COMPLETE CONNECTION.
Mar 10, 2008 | D-Link AirPlus G DWL-G122 802.11g/b...
Siemens SpeedStream 2624 (SS2624) Wireless Router Logo
168 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
