Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Canon ImageRunner 3300i
I am trying to get my new used copier to turn on, but I continue to get the error code E000732-0001. Can't find anything that would tell me what that is. Any help would be great. Thanks!
Tara
  • 2 more comments
  • Anonymous Mar 21, 2008
    Sam as above
  • scubaz Mar 28, 2008
    same problem here
  • Anonymous Apr 28, 2008
    el error e 000732-0001
  • efernandez74 Jul 02, 2008
    am trying to get my new used copier CANON IMAGE RUNNER 6570 to turn on, but I continue to get the error code E000732-0001. Can't find anything that would tell me what that is. Any help would be great. Thanks!
    New Friend:
What does the error code E000732-8888 mean. it comes to my canon IRC5185i Copier anytime i put it on.
Posted on Feb 21, 2014
Make sure all your cables are connected. i found the first part of the error "E000732" means a communication problem
Posted on May 02, 2008
I am not able to connect the canon 3300i to my computer my lan cable . i there any way to solve the problem .when i connect and run the drivers of the printer i am getting the the error message printer ...
after you connect them use cable LAN.
find the IP address on the copier, some way you find network system on display :
press * - network system - IP address. write it then you Ping on your computer, by run.
example. ping 162.198.100.3. t (type this alphabet t after IP address) and then press OK/enter.
after connected you can install the driver..
good luck...
but before see on your computer. is there any new device detected ?
if there is it. continue step above.
May 31, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Where is the waste toner receptacle located on the canon IR 3300i
Lower rear right portion has a small vertical panel held by one screw. The waste bottle is behind this panel.
Aug 13, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Error code E000001-0002
E001
0000 The main thermistor detects 250°C or higher.
0001 The main thermistor or the sub
thermistor detects overheating (hardware
circuit detection).
0002 The sub thermistor detects about 295°C or higher.
Main cause - The fixing film unit is faulty (i.e., the thermistor has a short circuit).
To clear the error, execute the following in service move:
COPIER>FUNCTION>CLEAR>ERR.
Jun 16, 2009 | Canon imageRUNNER 3300i Printer
Canon 3300i prints / process very slow
These machines can print slowly for a varity of reasons. First and foremost is using the incorrect driver. The correct driver can be downloaded here:
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2275&modelid=6349
Also slow printing can be a symtom of a hard drive about to fail (e602 codes).
Fastest printing speeds can be achieved using the following basic assumptions:
1) The copier is printing thru a standard cat5 cable; not thru the parallel port.
2) The network the copier is on is healthy and operating normally.
3) The network settings on the copier are configured correctly.
I am a Canon trained authorized tech on these machines and have been working in the field on the ImageRunner 3300 series since their release. I'm not sure if a ram upgrade is available but I haven't installed one in the six plus years of servicing this machine to fix a slow print problem.
Nov 09, 2008 | Canon imageRUNNER 3300i Printer
Canon ir 3300i
well..those scan settings are on the control software..did you install it?
www.canon.com will have some options.
http://tinyurl.com/6qcpgy
Aug 19, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Reset error codes for Canon imageRUNNER 3300i
We followed the instructions from your tech. on which buttons to press to get into the menu function and then followed the directions for clearing the error code. After that turned the printer off and back on and the error code reset and the printer worked like a champ.
Jul 02, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Connecting to Linksys as Router for Canon Image Runner 3300I
You can connect by using a hub. Then wire the hub to the machine and from hub to the stand alone pc. Still you have ot do some pc configuration to make the system running.
May 22, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
843 people viewed this question
old marine
old marine
