Hitachi 53uwx10ba no sound/picture flashing power light cricket sound
I have a Hitachi 53uwx10ba Ultra vision t.v. it was working fine until a loud pop sound then no picture no sound. The power light flashes and it makes a cricket sound from the back, any ideas?
Thanks,
Mark
  • 4 more comments
  • mlambert1 Mar 05, 2008
    Thanks,
    I took the back panel off and found that the problem is located on the "center" board. There are two lights flashing in time with the cricket sound. I have to leave town and won't be able to check anything until i get back next week.
    Thanks again!
  • lousgal Apr 04, 2008
    has good picture but no sound. plug in dvd player to front of tv then sound just went out
  • jnelson33 Apr 20, 2008
    I have the same problem. Can I fix this my self?
  • blkmax Jul 15, 2008
    Hi, My 53WUX10BA is experiencing the same issue with, no power/sound with Power light on. I had the convergence board replaced about a year ago. I will replace both relays, but cannot find E907. Is it on the power supply board, convergence board, center board or far left board when looking from the back of the unit? When the power is on there is one led DP23 on the center board witch is not on, could this be of any indication as to which relay/pico fuse to replace?
    I am a technician, but have no schematics for this unit and cannot get any as I am not Hitachi certified.
    Any help would be appreciated
  • matthewmirow Nov 30, 2008
    I have the same problem after doing manual adjustments instead of using magic focus. I over adjusted. red power light flashes, on main board 2 green lights flash and one red stays lit. dont forget the cricket sound too. lol Take off the bridge and pic and sound work but picture is all over the place. Any ideas?
  • garytammy May 02, 2009
    tv wont turn on red light beside power button stays on. opened back,, 3 green led lights light up,, 1 red light,, but one dp23 green led does not light up. does this indicate the problem. what does it mean
Hi there, i have the same problem, i was checking and moving the first board on right hand and works for two days, then i move the TV and happen again, same problem, and a just kick on the bottom of TV an works, and it's working for two weeks, i think may be it's a shot or lost contact in boards
Posted on Jun 14, 2010
    Genius:
  • 1,694 Answers
Possible shorted cap C702 ? Open E994 pico fuse.....check
carefully with ohmmeter...all fuses and let me know.....T.
Posted on Mar 05, 2008
My ultra vision stopped working the red light comes on showing power but the blue light will not come on and I get no picture or sound. Any ideas? Thanks
sounds like power supply board. easy fix..remove the back of TV take picture of the insides, and of the power supply board. jot down the part numbers off the board. do not remove till u get the replacement board. be careful back there even if it is unplugged u can get a shock. go to shopjimmy.com or amazon and look for a NEW board using the part # besure it is exact match..
Jan 25, 2015 | Hitachi UltraVision 42HDS52 42 in....
Hitachi 53uwx10ba service mode
are you using an HDMI cable? is it a cheap thin cable or heavy duty?
HDMI cables carry sound but it's possible you don't have it seated completely or it's a cheap cable. or your audio settings on your TV are not set to HDMI if that's the cable you're using. try running your audio setup on the TV Menu.
Dec 03, 2013 | Televison & Video
I have a Hitachi 53uwx10ba power light flashes and tv won't turn on
It is rare in this set but it indicates a short somewhere that is pulling voltage inside the set down---not a do it yourself repair unless you are a Technician with some basic equipment and a schematic diagram.
Have someone look at it from a repair shop or ?
Apr 14, 2012 | Hitachi Televison & Video
Hitachi ultra vision green and purple double vision picture about
Convergence is out, need convergence board repaired, usually bad stks, 392-110s
Jun 07, 2009 | Hitachi 60V500 60" Rear Projection...
Hitachi 53uwx10ba turns on & off when off red flashing light/clic
Same problem. Replaced both convergence ICs about 5 months ago. Worked fince since then and just recently no sound, no video, blinking red on front panel and clicking sound. I suspect that the ICs went bad again and blew a resistor or two. I used cheap Chinese ICs instead of the Sanyo ones and thing this is why. I'll be looking at it again and post solution.
Jan 21, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Power light flashes on Hitachi TV model #53UWX10BA
Hi
Can u tell me model no and company name so that i can help u clearly..
If u have warranty then u can claim it..
thank you
Oct 12, 2008 | Hitachi 53UDX10B 53" Rear Projection...
DP23 LED not lit on deflection board no picture on tv
Good Day, Gil;
Your problem is in deflection circuit (115+v) check these: FP05, DP15, Q777, QH01, TH01, T701, etc. BUT suspect C707 1k pfd, 2kv, and check all the pico fuses (brown) 2" to the right of cap. Good Luck, big IRISH.
Jul 19, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Turns off on own
Take to repair shop or replace (2) STK392-110s.
Oct 16, 2006 | Hitachi 50DX01B 50" Rear Projection...
Televison & Video Logo
898 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
