Fax machine I have a toshiba dp-12df. I have the a toner line down the middel when the fax or copy prints. What do I need to do to fix it???
    President:
  • 2,072 Answers
Ok , I want to clarify. You have a line on all printing? When you receive a fax, when you print and when you copy?
If so, you need to replace the cartridge with the drum.
If It only is when you fax out and make a copy, then open the scanner and clean the strip over the CCD assembly in the scanner.
What happens is that something, Whiteout, ink from a page windes up getting on the scanner glass and as the original passes over it, it scans as a line and shows up on the paper as a line.
Posted on Mar 05, 2008
I have a Toshiba Dp85F Fax machine and need to replace the toner cartridge...I do not know what model number I need to replace it with. Please advise
Ink, Toner & Accessories for DP-85F Printers, Copiers & Faxes Select from the list below Compatible or Original ink and toner cartridges that work with your DP-85F.
TOSHIBA TK-18 Compatible Black Laser Cartridge, TK-18
  • - Condition: Compatible
  • - Page Yield: 6000
  • - Color: Black
  • - Printer Technology: Laser Cartridge
  • - Item Number: TK18-70
- OEM Part#: TK-18, TK18
Item #: TK18-70
MSRP: $114.99
Price: $38.99
Toshiba DK-18 DP-80/DP-85 Drum Unit
  • - Page Yield: 20000
  • - Color: Black item-color-black.gif
  • - Printer Technology: Drum Unit
  • - Item Number: DK18-70
- OEM Part#: DK18, DK-18
Item #: DK18-70
MSRP: $114.99
Price: $39.99
Toshiba DP85F Toner Cartridge, Black
Toshiba TK18 Toner Cartridge, Toshiba TK-18 Fax Toner
$73.59
Nov 29, 2010 | Toshiba DP-85F Fax
Incoming faxes have black line running through the centre
If it is just from incoming faxes and not from anything you print/copy then it is the sender's fax machine that is dirty. If everything you do has that line, try cleaning the scanner glass and corona wire.
Jun 09, 2010 | Brother IntelliFax-2920 Fax
Receiving fax has vertical lines on paper.
Are the fax from the different fax numbers or the same if the same may be there fax machine have them clean there scanner, if from varioue fax numbers then check your toner/drum unit and print out some internal reports such toner/drom order repkacement orders or one touch numers or meter read forms or make a copy if able to copy with this machine is line gone? Also check your fuser unit the hot part. also check your scan glass
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 24, 2010 | Office Equipment & Supplies
Scanning and copy problem
My clarification request turned into a solution, I believe. Let me know?
Aug 07, 2009 | Toshiba DP-85F Fax
Can send faxes they can read fine but when i get faxes cant read them about a week ago paper jamed in the roller do i need to clean with what product
I assume you talking about a panasonic DP-190? Do not clean the drum you may gently wipe it down, realize the drum puts the image on the paper, nick it, grease from hands, ,etc will effect copy qualilty. Remove the toner cart. clean any toner spilled. Drum may need replacement, print a toner/drum resupply form to see if the machine prints them cleanly
May 08, 2009 | Office Equipment & Supplies
Black line down middle of confirmation copy
You need to remove the toner cartridge if fitted pull out the toner holder, making sure the opening is on the top, if not the toner will spill out, set this to one side and clean the toner holder thoroughly.
Mar 18, 2009 | Office Equipment & Supplies
Canon will not receive faxes or copy documents
see if you have fax line(conect a telefone in the line to see if you have tone) or if the cable is conected.
Nov 21, 2008 | Canon NP 7130 Black and White Copier
Gray line down middle of faxes/copies on panafax uf880
yes change a toner and clean the glass area under nearth the toner.
Oct 24, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
Clear vertical lines when printing that do not clear up by shaking toner
does it do it on copies and internal test as well???
1- check the thin strip of glass inside the machine and make sure it is clean, look at the toner are there any line on there that corresponds?? yes then replace.it could be coming from the drum or toner. I beleive the drum is a seperate piece from the toner
Aug 27, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Printing problems
There could be a couple reasons. One, it may be the person sending you the fax that has a problem with their machine. The easiest way to find out is, put a clean document in the feeder and make a copy. If the copy is clean then you know it is not a problem with your machine. The other possibility is that when Brother sells these new machines they only provide you with a starter drum and toner. Many times the drum may have defects and the machine does not detect these so you will not get a message telling you to replace it. If you do determine its your machine I would start by replaceing the drum unit first, then the toner.
Good luck
John
Jan 08, 2008 | Brother IntelliFax-2820 Laser Fax
69 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
