Replace Drum Motor
I have a Xerox Phaser 7760. It is reading replace Drum Motor. I have turned the machine off and back on again, but its still there. What can I do
Thanks
Les
    President:
  • 2,072 Answers
Do you have a specific numeric code? Like 09,400, or something like that?
I will be back in a few minutes. Let me know, I will be looking for an answer for you.
Posted on Mar 04, 2008
  • 1 more comment
  • Rick Kasper Mar 05, 2008
    there is technically no drum motor in the 7760. I am having a hard time finding anything to go with that.
    If you are having another code let me know please
    Ah huh , I found it. It was left out of the dodumentation LOL..
    As I suspected, a pretty serious problem here are the options. Not good.
    You could have a shorted or broken wire. Most likely a bad main processor or that motor assembly.
    Change Drum Motor. (PL1.1)
    Execute DC330 [004-003].
    Between MCU PWB J407-B8 (+) GND (-)
    Is the voltage +5VDC?
    Yes No
    Change MCU PWB (PL13.1)
    Drum Motor J210-8 (+) GND (-)
    Yes No
    Check for cut wires and bad connections between MCU PWB J407-B3 and Drum Motor J210-3
    Check for frame shorts between Drum Motor J210-3. And MCU PWB J407-B3 , and if there are no
    problems, change MCU PWB. (PL13.1)
    Check for cut wires and bad connections between Drum Motor J210-3. and MCU PWB
Tip
XEROX PHASER 7750 7760 FAN ERROR.
Hey guys this is a Xerox Phaser 7750 and 7760 fan error video tutorial.
In this video you will learn how to fix the error code 48 on the Xerox phaser 7750.
Also you will learn how to fix the error codes 010-391,010-392,010-398 that are related to the Xerox Phaser 7760.
This video shows how to remove covers.
All the wires that you need to disconnect from the machine to fix these errors.
There is also another video part two that shows you how to reinstall everything back
in it’s place. Step by step tutorial hope you enjoy.
http://www.youtube.com/watch?v=yMud-Md2xpc
on Dec 30, 2009 | Office Equipment & Supplies
Fault 004-350
Here is a link for the Phaser 7760 service manual:
Xerox Phaser 7760 Service Manual
004-350 Marking Device Fail (Controller Video)
Mar 23, 2014 | Xerox Phaser 7760 Laser Printer
Xerox phaser 7760 saying "black ATC sensor failure - code 009-380", i changed developer and xerox phaser 7760 saying "black ATC sensor failure - code 009-380", i changed developer and xerox phaser 776
When you have a sensor failure, you need to replace the black ATC sensor and recalibrate it. Another reason for sensor failure is you are not getting toner moved down to mix with the developer...the toner tube/auger spring could be clogged up or not functioning.
Also if you changed the developer housing when you changed the developer, you need to change the value to the new sensor # that comes with the housing.
Feb 16, 2014 | Xerox Phaser 7760DN Laser Printer
Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve imaging unit recognition problems, link below. http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB Usually this problem only occurs if the NVRAM has been reset or the engine board has been replaced without backing up the NVRAM. You can download the snippet to your printer through Centreware or by downloading the 'File Downloader' utility from the same page above.
Hope this helps.
Jan 09, 2011 | Xerox Phaser 7760DN Laser Printer
Phaser 7760 dirty printing
Dear User,
This is a common problem of all laser printers, don't worry i will give you solutions for this. If you can able to remove the DRUM set from the printer and check that any power leak or not, IF yes clean it well and insert into printer again take a printout , afterthat also coming like dirty. So please change the drum and put a NEW DRUM. Your drum capacity is crosed beyond the limit.
I hope that my suggession will helpful to you, if yes please rate this ...
Feb 27, 2010 | Xerox Phaser 7760/GX Laser Printer
I have xerox works center pro photo copier model 5225 it is given error code 042-325 please help me
That is a main motor speed fault. You can try turning the machine off and taking the drum unit out and putting it back in and powering the machine back up.
You can pull the main drive motor and see if it is just sticky on the shafts, if not, replace the main motor.
Dec 13, 2009 | Xerox Phaser 6180N Laser Printer
Xerox phaser 7760dx
This could possible be the magenta drum cartridge. also try cleaning the ROS assembly window below the drum cartridge.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Jun 10, 2009 | Xerox Phaser 7760/YDX Laser Printer
Printer lines
did you check the drum? it could be coming from the drum blade.
Jul 17, 2008 | Xerox Phaser 7760/YDX Laser Printer
Computers & Internet Logo
74 people viewed this question
Alun Cox
David Payne
David Payne
