Question about Jenn-Air JMC9158AA Convection Microwave Oven
Bulb The light bulb stopped functioning. How do I replace it  and which one do I need. The manual has no instructions
  • 770 Answers
Buy part # 8183592 if you dont have a parts place close you can order it online at www.apdepot.com $17.00 There you can see a exploded veiw of your unit and how to replace it
Posted on Mar 05, 2008
Controls, heating and turntable function normally, but there is an intermittent failure (approx 80 of the time) where the interior light and blower do not function when the microwave is operating .
follow this test and fix it; God bless you
1)
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
2)
  1. Exhaust fan motorIf your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. ThermostatAnother part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control boardIf your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Oct 31, 2013 | Jenn-Air JMV8100A 1000 Watts Microwave...
My light bulb has stopped working and will not work after I have replaced it with a new one
It could be either a separate door switch for the light that's gotten crufty (sometimes just cleaning them makes them serviceable) of the microwave that needs to be reset. Just check for tripped circuit breakers, since you've already unplugged the thing to swap the bulb (I expect.) Then check your bulb's continuity, then check the socket and switch functions if things aren't sorted.
Sep 10, 2011 | Whirlpool MH1141XM Microwave Oven
Changing microwave light bulb
Check the owner's manual to see if yours is a model which allows access to the lights without pulling it down from the wall.
Accessing the lights on some models will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
Many use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
You can find handy exploded views and order parts by model number here.
Oct 06, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
Jul 16, 2009 | Whirlpool GH4155XP Microwave Oven
I need a manual for Emerson Microwave mwg9111sl
When replacing the bulb in an Emerson, Microwave. Model mwg9111sl. Can you replace the bulb or the socket and bulb?
Jun 01, 2009 | Emerson MW8168B Microwave Oven
Replacing GE Spacemaker Light Bulb inside Microwave Oven...
Here is the GE download page for your manual. Page 35 of your  manual gives the light bulb replacment instructions.
http://genet.geappliances.com/DocSearch/Dispatcher
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
The interior light on my microwave convection oven doesn't light.
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
On an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Nov 20, 2008 | GE JVM1490 Convection/Microwave Oven
I have a panasonic microwave, model NN-GD566M. The bulb has gone but the microwave still functions ok, I cannot find the instruction manual and need to purchase the part, Can you help. I need the part...
You can find the instructions for this model here and here.
You should be able to find generic replacement bulbs from local appliance parts stores, home improvement stores, or via a local Panasonic-authorized servicer you can locate here.
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 26, 2008 | Microwave Ovens
LIght bulb burned out
I a Kitchen Aid Buit-in microwave (KEMC308KSS01) with the same problem - light went out. Can you send me the instructions on how to replace the bulb? Thank you! dlhamilton@comcast.net
Jan 23, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Replacement cooktop light bulbs
look inside for a removable panel for access to the lamps. consult your instruction manual.
Dec 28, 2007 | GE JVM1650 1000 Watts Microwave Oven
Jenn-Air JMC9158AA Convection Microwave Oven Logo
243 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
