Question about Pioneer GEX-P910XM Satellite Radio Receiver
Unit will not power up
I have 3 of these units and all of them had the positive and negative power wires swithed around by mistake. The inline fuse had blown, and replaced with new one, checked to see if we were getting power to the plug into the unit from both the red and yellow-red wire and was getting power, checked ground wire ,was ok. My question is ....Is their a fuse or part on the inside of the unit that could have blown? If so where is the part that needs to be replaced? I have opened the case and cannot fined anything that looks out of the ordinary....I have a voltage meter but where do I check?
  • TallTrucker Mar 05, 2008
    Thank you, Benimur and eagle338... I have looked at the units that I have and one of them their are someparts smoked and the other 2 cannot see anything visibly wrong, I guess I should get a schematic to see what I am looking at. I was thinking about trying to at least get one of them working out of the 3. You are probably right, they are older units and should't waste my time messing with them...PS.. I build radio boxes for truck drivers and used these units in those boxes with am/fm stereo, cb,xm all in a compact unit w/12volt battery.
    Brigadier General:
  • 6,966 Answers
Hi TallTrucker,
With the indulgence of eagle338.....
Most if not all 12VDC devices of this nature would have some sort of reverse protection circuitry. This could be a big diode wired/soldered immediately after the power wires coming into the unit.
Additionally, it would generally be divided into several sections.
1. Standard tuner section;
2. Satellite tuner section;
3. Logic circuitry; and
4. Amplifier circuitry.
The amplifier circuitry would be using straight 12 volts and the chance of the amplifier ICs going dead are very high being reverse powered. It may also be worth your while to check/replace the capacitors above 47uF/16V. Other than that, most discrete components in the amp circuit can withstand momentary reverse power.
All logic circuitry (and the digital tuners) would be using +5VDC. This is realized with the use of a regulator from the 12V line. This could either be a 3 terminal, a switching regulator or a zener diode/resistor combo. Both will go dead when reverse powered. There are also capacitors in this section similar to the amp.
There would also normally be a power limiting resistor somewhere along the different B+ line (0.47ohms or something lie that) which would open when components consume high current or as in your case reverse powered. In some instances, there would be inductors as well as resistors.
Since as described above, the component level repair would be relatively extensive, it may be to your advantage to replace the entire board (if ever available) as suggested by eagle338. Additionally, this would require in depth knowledge of electronic circuitry and components, use of a DVM and a soldering iron.
Though I have to say that I beg to differ on the board replacement. More often, the cost of replacement, the downtime and waiting time would not justify any further repairs. Perhaps you should consider replacing the entire unit to save you the trouble.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Mar 05, 2008
  • 4,889 Answers
I am afraid the entire circuit board is screwed this happens because you have shorted the device by interchanging the + and - terminals. You will need to replace it.. It has happened once with me too..
Posted on Mar 04, 2008
Had to replace fuse inline alternator how can I transfer the inline fuse to a different wire
the cable /fuse to alternator has nothing to do with the start and run function if the battery is charged up and in good condition ,sounds like the main battery cables have a bad contact/connection or battery is shot<follow battery cables and remove all points of connection in engine bay area clean contacts with sandpaper and resecure all connections 1 AT A TIME! to make sure none are swapped around by mistake ) on both earth cable/negative and the positive/power cables,make sure terminals on battery are clean and tight , try boosting/jump starting your battery with jumper cables connected from another cars battery positive to positive .........negative to negative and see if it starts ,i doubt the problem of starting up is the alternator unless battery is flat and not being charged by alternator ,by jump starting with another baterry will give you the answer once all baterry cables and connections are clean and secure
Jan 15, 2014 | 2006 Ford Focus
How do you connect the amp with the stereo
  • Choose where to put your new amp. If you are installing subwoofers it's usually best to put the amplifier in the trunk next to or attached to your subwoofer enclosure. If you are going to power your main car speakers with the amplifier then it may be better to put the amp under the passenger's seat.
  • 2
    Purchase the following wiring for the amp: A thick power cable (the thickness required depends on the total wattage of your amp, ask a sales rep or consult your amplifier's manual for the proper gauge) that will have to reach from your battery to the amp (the power cable should also have an inline fuse to protect the amplifier); 3 feet of ground cable of equal thickness as the power cable; an RCA signal cable to carry the left and right signals from your head unit to the amp; a "remote on" wire which can be any thin wire (20 to 24 gauge) that will also run from the head unit to the amp; speaker wire (if you are powering subwoofers you should only need about 3 feet of 12-gauge wire per sub, if you're going to power your main speakers you will need enough 16-gauge wire to reach each speaker from the amp, 12 feet per speaker is usually safe).
  • 3
    Gather the following tools: Screwdrivers, wire cutters, wire strippers, pliers, a utility knife, sandpaper, masking tape with a pen for labeling, 2 crimp-on o-ring ends for the power and ground cables. If you're hooking the amp to your speakers, you'll also need 2 crimp-on female spade connectors for each speaker.
  • 4
    Find a manual with instructions on taking off the dash of your car (not the whole dash--just the head unit, in order to hook wires to the back), and also to get at your car's speakers if you are hooking the amp to them.
    The Installation
  • 1
    Disconnect the ground (negative) cable from your battery. Never work on the electrical system of your car with this connected.
  • 2
    Attach the side with the fuse of the thick positive (+/red) power cable to the connector on the positive terminal of your battery; the o-ring can be sandwiched in the bolt on the connector that connects your car to the battery. Now put the fuse in the fuse holder.
  • 3
    Run the power cable through the firewall of your car (there is usually an opening on the driver's side) and to your amplifier. If your amp is in the back it is usually best to run this wire under the plastic molding that goes along the bottom edge of your car. Be careful where you run the wire because the power cables should never be near the signal or speaker wires.
  • 4
    Find a metal bolt or screw on the metal of your car near the amp to connect the ground cable to. This should be as close to the amp as possible, never more than 3 feet. Unscrew it and clean the metal surface with sandpaper. Attach the ground to it with the o-ring and screw it back down firmly.
  • 5
    Remove your head unit and run the signal and remote on wires from behind the head unit to your amp. Connect the RCA connectors and the remote on wire to the back of your head unit.
  • 6
    (If you are installing subwoofers and not running your normal speakers off the amplifier skip to step 7.) Run the 16-gauge wire from each one of your speakers to the amplifier. On the amp side use the masking tape to label each wire so you know which speaker it is. On the speaker end-strip a 1/4 inch off the ends of the wires and crimp on the female spade connectors with your pliers. Connect the spade connectors to your speakers making sure to match the positive (+/red or white) with the positive terminal and the negative (-/black) with the negative one.
  • 7
    Connect everything to your amplifier. Only strip off as much as you need off the end of each wire to make a solid connection, you don't want any exposed wire hanging out. If you have subs, attach them to the amp with the 12-gauge speaker wire.
  • 8
    Secure your amp to something. If it is in the back you can screw it directly to your subwoofer enclosure. If it is under a seat you may just want to get some straps that hold it down.
  • 9
    Reconnect your car's negative cable to the battery. Test your system and make sure everything works, going around to see that every speaker is on before you put everything back together
  • Feb 17, 2011 | Car Audio & Video
    This unit comes with a Four Conductor Cable to hook up power in. How are these four conductors hooked to power?
    Disconnect the battery. Connect the green wire to the Negative terminal.Put a 20a fuse inline on the black wire and connect to Negative terminal.Put a 20a fuse inline on the red wire and connect to Positive terminal.
    Put a 1a fuse on the yellow wire and connect to ignition switch - if you don't want to use the Ignition Sense feature, connect the yellow wire to Positive terminal.Re-connect the battery and test.
    Nov 11, 2010 | Motorola VC5090-MA0QM0GH6WR Wireless...
    Cb was hooked up backwords +-/-+ can it be fixed
    Some of the car electronics will put crowbar DIODE in the unit, the Cathode will be connected to the incoming positive, and the ANODE will be hooked up to the Neagative, the DIODE will not conduct because ti will be reverse bias, so when the positve and negative is hooked up wrong to the unit, the Diode will conduct (forward bias) with a lot of current and blow the fuse that is inline with the unit, you should be able to connect the Ohm meter to the positive wire and the negative wire of the CB (remove it from the car first), if it indicate anything lees than 100 Ohms, the protection DIODE is shorted out and protected your CB, you just need to locate that Diode.
    Nov 01, 2009 | Cobra 29 LTD CB Radio
    Fuel gauge stays on full
    Change the sending unit it is not working.
    Aug 21, 2009 | 2003 Nissan Altima
    Will not power on
    Try taping the ground wire directly to the negative battery terminal, and the positive and RMT wires to the positive battery terminal, if the unit still won't turn on, check for a fuse on the unit itself, otherwise it may be dead on arrival.  If it does work, check all your car fuses, also look for inline fuses on the stereo live wire harness.  Hope this helps
    Oct 29, 2008 | Car Audio & Video
    I have connected the power and other wires correctly and my pioneer radio will not turn on.
    Is there a fuse in the inline fuse holder on the positive (red) wire?
    Where have you connected the positive and negative wires?
    What colour wire have you connected to the accessories position of the ignition switch, or within the fuse box?
    Sep 16, 2008 | Pioneer Car Audio & Video
    2007 Ford Taurus
    If you check your head unit it should have a "remote wire" output at the wire dock.
    This is the wire that tells the amp to turn on every time you switch the head unit on to listen to music.
    Then you need to run a positive wire from your battery with an inline fuse to the amp. (Make sure you use thick wire, if you skimp and use thin rubbish wire it may catch on fire/heat up and will also result in a huge performance loss).
    You need a negative wire also the same thickness, that bolts directly to body somewhere.
    If you go to an auto sound shop they should be able to provide you with a amp kit for around $20 bucks. In my experience its far less hassle than messing around trying to make one up from scratch.
    Because they come with the sound cable wiring and all the electric wiring cable and all necessary plugs ect.
    Thats my advise anyway.
    Jules
    Aug 12, 2008 | 2006 Ford Taurus
    Philips fm92 cb radio
    Hi there soleman , it was common for Philips to fit fuse holders to both positive and negative wires on their radios , the red with black trace is neg the plain red is positive . Cheers T
    Dec 01, 2007 | Radio Communications
    Sony Headunit CDX-M8800
    see if the fuse on the radio is ok and if you realy have 12V power. see also in the radio the soldering point's of the conector of the power
    May 06, 2007 | Sony CDX-M8800 CD Player
    Pioneer GEX-P910XM Satellite Radio Receiver Logo
    103 people viewed this question
    Top Pioneer Audio Players & Recorders Experts
     Grubhead
    Grubhead
    John
    John
    Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
