Question about ASUS K8N4-E Deluxe Motherboard
Unable to use F6to load raid controllers
I am not an expert but am comp literate to a degree. The computer will boot sometimes with or without the XP disc. The shop I had build the system has went out of business (of course). I am using a SATA hard drive that has the XP OS on it. I also tried to update the bios using the ASUS update tool, but it states that the bios version doesn't match the information or something like that. Please help, I am pulling my hair out and the wife is holding a gun to my head. (Not sure if that is caused by the computer though) haha.
  • 14 more comments
  • nwflcpl2k Mar 05, 2008
    I just got this. I am able to chat now live if you would like.
    I don't have a floppy drive. Downloaded flash tool and updated bios from ASUS and burned them to cd seperately. The last guy that I was chatting with, went on a smoke break about 30 mins ago. He said I had to do it from windows because of the kind of board it is. Help please.
    I can get to bios update. don't see my bios version shown anywhere though. I burned 2 CD's, one with bin file of new BIOS only and the other with only the flash file itself.
    I will try that. Did I get crewed by the other guy? It said 19.95 for assisitance till issue resolved. He said he was going for smoke break and never came back.
    It said loading freedos kernel yadayada, gave me choice of media center or XP pro. Chose media center. Then gave choice of safe mode, safe mode with prompt and so on. Also start normally. Chose normally and it rebooted back to same. will try safe mode now.
    Actually I chose last known good configuration, but it rebooted. Said loading FreeDOS Fat Kernel...Press any key to boot from cdrom....did that. Ended up with bad or missing command interpreter: 2 - /P /E:256 and now I have a flashing dos prompt.
    I'm back. Are you there? I just want to resolve this issue and move on. If you could help it would be great. I'll go premium if you have the time and think you can get me through this. Maybe I just got a bad seed last night. I am no further along than I was last night.
    I am in Pensacola, Florida, USA. IF I can get to a dos prompt I will try that. I haven't seen a Dos prompt the pass few times. What is Yabadeyaba?
    I have tried booting from the CD a few times. I have changed the boot order a few times. Tried a few different configurations. I changed the battery on the mobo just in case. When I boot from the cd rom, the computer goes through setting up windows (a blank blue screen that says 'setting up windows' in the top left and a gray bar across the bottom of the screen showing the files it is loading). Then it says that it doesn't recognize any hard drives installed. I swapped out for another hard drive and got the same result. I will try selecting XP only this times instead of Media Center and see what happens.
    I hit F8 during the splash screen for ASUS during POST after I changed the boot priority back to cd rom. F8 brought me to a boot menu screen. It gives me a choice of a scsi-0: 05:05-0 SiI JBOD as a Hard Disk option and 1st Master: HP DVD Writer 640. Previously I only had the DVD option. Now this screen is not in the BIOS setup utility but is by itself with no other options. I believe there is a problem with the BIOS and/or the SATA/ Raid controllers. But I have been unsuccessful with using the setup cd that came with my ASUS K8N4E-Deluxe mobo. I now the SATA is enabled.
    I try and hit F6 during reboot to install SATA/ RAID controllers as it ask, but it doesn't allow me to do anything. The computer just keeps booting as if I never hit F6.
    I mistakingly hit F5 while trying to hit F6 and now I have a menu that states 'setup could not determine the type of computer I have. It gives me the option to select either- standard PC with C-step i486 or other.'
    I have been trying off and on for a few months to get this unit fixed for the wife. I had a local computer shop build the system and now they are out of business, of course. I tried the premium service last night and a guy started to help, but then exactly at 1 hour into it, he stated that he needed a smoke break and never returned. I have never seen the screen I have up now and not sure what to select. It says if I select other to have the support disc from the manufacturer ready. I have a Windows XP and ASUS disc.
  • nwflcpl2k Mar 06, 2008
    I'm on now. Thanx
    Yes, I can get into the Bios Setup Utility Screen.
  • Anonymous Aug 28, 2008
    CMOS PROBLEM
    Genius:
  • 1,019 Answers
Did you actually attempt a bios Flash, that failed ?
Have you also made sure that the device is set to recognised by the system bios ?
Mike @ Compurepair.
Posted @ 23.35 PM ( G.M.T )
Posted on Mar 04, 2008
  • 13 more comments
  • Mike Waldron Mar 05, 2008
    did you attempt to flash the bios with an update ?
    If so did it fail ?
    Mike.
    So the computers dead, will not boot at all even to the bios screen ?
    The majority of boards will accept flashing from a floppy drive, but if your flash was the wrong one, or corrupt this may be an unusable board.
    I,m going to try to find you a bios update.
    You,ll then have to create a bios Boot CD, which comprises several files.
    Mike @ compurepair.
    Looking at asus site,
    This is a crash-free Bios.
    You need to insert the motherboard Support Cd, And reboot the computer.
    According to them, this will reinstall all your drivers, and return the system to it,s default.
    If you have the motherboard support CD, And a working DVD Drive you should be able to recover It.
    Mike @ compurepair.
    Ah,
    Thats where your problem is.
    It,s not just the matter of burning files onto a disk, you have to create a Bios Boot Disk.
    This can comprise of 3 or 4 files The actual bios.Bin file A phlash.exe And others depending.
    you may be lucky, as i stated in the last post.
    You have a crash-free bios.
    Talk about Lucky.
    Mike @ compurepair.
    ASUS AI BIOS
    CrashFree BIOS2
    Whenever BIOS gets corrupted, ASUS CrashFree BIOS 2 allows users to reboot the computer and perform an smart auto-recovery procedure through the motherboard support CD.
    no problem, i was,nt aware this was a premium solution.
    Let me know when you back on later, if you can,t get help, i,ll talk you through.
    Mike @ Compurepair.
    Hi Buddy,
    I,m here for about 15-20 Minutes.
    If you can boot Into The Bios Screen Usually F2.
    Change the first boot drive To Read The CD Rom.
    Put Windows CD in The Drive and re-install windows over your existing System.
    You should be able to do the restoration CD too, if you get a prompt boot into safe mode, once you can get to windows, you should be able to repair the faults.
    I,m here for 10-15 minutes, try these solutions and tell me what you Have.
    Mike @ compurepair.
    I,m not sure where you Are UK-U.S.A et,c.
    But i have to go out shortly. If you follow the steps to get back to Yabadeyaba when prompted with a dos prompt. Type D:/ setup.exe if thats where your CD Drive is. With windows Cd in the drive this will start the Windows installation, if it does you,ll be asked To format the drive ( N ) No.
    keep existing file system intact ( Yes to this )
    This will re-install windows leaving your existing file system intact, replacing faulty-corrupt-missing files.
    Alternatively, where you got the option to boot to XP Or Media Player Boot To XP. this will also help restore your operating system.
    Hope this Helps Mike @ Compurepair.
    You mentioned it a few posts yabayada i think it was ?
    The main thing is to try to get the restoration disk to do it,s job.
    If you get into Bios setup, Ensure that You have SATA drives configured, usually at the bottom of page 1 or 2,they differ from manufacturer. i.e Pheonix-AMI et,c.
    Mike @ compurepair.
    Go for it,
    trial and error.
    Ensure SATA is selected in the bios F2 to enter setup.
    Mike @ Compurepair.
    I think you,ve just gotta keep at it, My only other Idea is that you may have a faulty SATA Drive, have you checked The DATA And Power leads from Motherboard to Drive ?
    Also if you have another IDE Drive Or Rxternal Hard-Disk you Could Try That.
    I,ve gotta go Buddy, My missus will Skin Me alive.
    Also if you have the side case off, see if you can feel any movement from the SATA Drive, by putting your hand on top.
    You can usually feel a hum.
    If you can,t resolve This, Go premium For $19.99 people will be queing up to help you solve It.
    I,d try yourself for a while Though, good for experience.
    Mike @ Compurepair.
  • Mike Waldron Mar 06, 2008
    I was,nt aware that you,d paid for premium assistance, usually experts are falling over themselves to get a solve, as they get a small percentage of the Earnings.
    If you had a guy on live, and he did,nt get a result for you.
    I,d e-mail fixya. And ask what happened to your premium Assistance. in the meantime, if i can catch you online, i,ll try and get you sorted out with this.
    mike @ compurepair.
    Hey Buddy,
    i,m back on, lets see if we can,t sort this Problem Out.
    I remember My First SATA Hard-drive was a pain in the Butt, to setup.
    It,s getting it configured in the Bios.
    Ok,
    Can we actually Get into the Bios Screen with F2 ?
    Mike.
    Okay thats a great Start, we might be able to get this to Work.
    do you have a page in the bios that gives you Drive Information ?
    should have CD-DVD Hard-drive SATA et,c.
    Mike.
    If you Have A SATA drive connected, it should be recognised in the bios setup. if you click or double click on the icon or drive name, it will give you more info.
    The Other Thing to Try, Is to Find The Pages To save And Exit To CMOS. And Select F9 Or F7 whichever applies.
    Restore Setup Or Optimized Defaults. Y For Yes.
    Save And Exit Y for Yes.
    Mike.
Acer aspire one starts to boot up stops at windows xp screen
Hi there !
I suggest you try to run your computer on safe mode by pressing F8 when booting up. Advance menu options will pop up and choose run on safe mode. When it load the Windows, try to figure out what you installed or you before your computer happens. I suggest that you download also windows registry cleaner to fix some errors in your computer that prevent you to go to windows screen when booting up on normal mode. Run the FULL SCAN and press the fix errors button.
I should somehow help your computer.
Feb 05, 2011 | Acer Aspire One Netbook 8.9" Notebook
Tip
How-to repair Windows XP, How to Perform an In-Place Upgrade
One of the best kept secrets of Windows XP is it's built in repair feature!
In previous versions of Windows, correcting an operating system error, or installing a new motherboard, usually meant formating and reinstalling, resulting in loss of all data. Don't worry; Windows XP repair feature won't delete your data, installed programs, personal information, or settings. It just repairs the operating system!
Why would I want to reinstall Windows XP?
1) Can't start Windows XP in safe mode.
2) You have problems caused by a recently installed system update (Windows Update, hotfix, Windows XP service pack, or Microsoft Internet Explorer update).
3) Your problems can't be solved with system restore, or you can't access system restore.
4) You've installed a new motherboard, or made other major hardware changes and need to reinstall Windows.
Let's get started!
Step 1: Rule out hardware issues. Windows Repair will only fix software problems. Hardware issues can also cause boot problems (i.e. bad hard drive, memory, CPU, or power supply).
Step 2: Backup. It's always a good idea to backup your important data before making changes to Windows XP. Relax, if you follow these instructions your data will be perfectly safe.
Step 3: Boot from your Windows XP CD. Insert the Windows XP CD into your computer's CD-ROM or DVD-ROM drive, and then restart your computer. When the "Press any key to boot from CD" message appears on the screen, press a key to start your computer from the Windows XP CD. Can't boot from your CD? Please see the note at the bottom of this page (Configuring Your Computer to Boot from CD).
Step 4: A blue screen will appear and begin loading Windows XP Setup from the CD.
Note: RAID/SCSI/Unsupported UDMA users:
You will be prompted to "press F6 to install any third party SCSI or RAID drivers". Most users will not have to press F6, but if you are running RAID, SCSI or unsupported UDMA controllers, then you will have to have your controller drivers on a floppy disk. If you are unsure whether you have RAID/SCSI, then simply let the CD load without pressing F6.
When completed loading files, you will be presented with the following "Windows Setup" screen, and your first option. Select "To set up Windows XP now, press ENTER". DO NOT select Recovery Console.
Note: The system repair function will remove any updates you have previously installed that are not included on the CD. Drivers will also be reverted to their original XP versions, as well as some settings (network & performance settings may sometimes be reset to their defaults). It may be necessary to reactivate your Windows XP as well. When finished, you will have to download all of the updates from Microsoft Windows Update, because they are all replaced during repair.
Let's get started!
When presented with the screen below. press the F8 key to continue
Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation, or install a fresh copy of Windows XP.
If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
Note: If you install a fresh copy, all data on that partition will be lost!
Your almost finished! Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts, and have your CD-KEY ready if needed.
Do you have more than one system, or lost your CD-KEY? Visit the keyfinder page to retrieve your CD-KEY.
Update: Due to the proliferation of the Blaster and Welchia Worm/Virus be aware that a Repair Install will leave your system vulnerable. You can get infected within seconds. Do not go on line until you have enabled XP's firewall first.
Remember to run Windows Update! (install critical updates first)
Many computers are not configured to boot from the CDROM. If you cannot boot from the CDROM, this is probably due to the boot order of your devices being incorrect. You can change this in the BIOS.
You enter the BIOS from the first screen you see when you turn your computer on. To enter your BIOS, most users here will press the DEL key.
Most Dell, Toshiba, Gateway, Sony & HP systems will press F2.
Compaq users will usually have to press F10.
IBM typically uses F1 or F2.
Other brands may have different keys to press to enter setup, F1, F2, Del, Tab and CTRL+S. If possible see the manual for your computer or motherboard. Also, the BIOS will usually display which button to press to "enter setup" during POST (if it flashes by too fast, press the Pause key).
When you enter the BIOS setup, you need to change the boot order. The CDROM should be setup before the Hard Drive. Each BIOS is different, but here is an example:
on Jun 18, 2010 | Computers & Internet
Hi, i have a MPC Netframe 3610 server with windows 2000 server installed. now i want to install windows xp but i get the folllowing error: no disk found after boot from cd. why?
You will need to use the F2 option during the initial loading process to load RAID drivers for whatever RAID controller your hard drives are connected to. You caould probably get around it by installing an internal IDE hard drive and loading the OS to that too
Feb 01, 2011 | MPC Computers Netframe 3610 Server
2 drives - raid 0 - both went bad at the same time ; so i was told. i'm trying to reformat both of these on another machine -- they spin up and they each have a green led on the bottom side that sometimes...
you will have to use an operating system of some sort to attempt to format the drives. Wether it's a linux distro, Windows XP CD etc. If you boot from the CD during the install process you will be prompted to format the drive\
Oct 27, 2009 | Maxtor DiamondMax Plus D740X (6L080J4) 80...
Gigabyte Ga-K8N Pro Windows XP Installation
Download "MEMTEST86+" from the Internet.
One version boots from a diskette;
another version boots from a CD-R (that you have created).
Either way, make MEMTEST do a "full" test of the RAM in your computer -- bad RAM can cause "unpredictable" crashes.
Sep 13, 2009 | Gigabyte GA-K8N PRO nVIDIA nFORCE3,...
Raid problem
Windows XP does not support SATA you need to load the SATA drivers from the motherboard manuf. You should have a cd for RAID/SATA drivers. When you boot off the XP CD it give you an option to load third party drivers watch at the bottom of the screen. When you see this message you can insert the CD that contains the drivers it is looking for the you should be able to load Windows XP.
I hope this help. Please rate.
Feb 18, 2009 | ASUS P5RD1-VM Motherboard
HD installed with XP in Giga MB,not booting up in the originalP3
it is impossible or else you reload the hd on the motherboard
Jan 21, 2009 | Computers & Internet
Dell 9150
This system has onboard RAID, sometimes it is simply because the RAID controller is in error, to get it out of error:
* Disconnect the power cable
* Hold power button for 15 seconds
* Release the power button
* Plug in power cable
* Start the computer
If this does not work, please provide information, is is Windows XP or Vista?
Dec 01, 2008 | Dell Dimension 8200 PC Desktop
Problem with new install xp
First of all, was there a reason that you wanted to reinstall windows? If you were having problems with the operating system and now upon reload the hard disk is not appearing it could mean that the disk or the system board itself is bad.
If you pull the XP disk out and just try to boot your computer up are you able to login and use your computer from the previous/original install of XP?
If so, then perhaps you're using a special hard drive controller that supports RAID. If you have a RAID controller you'll need to load the drivers of that controller on a Floppy disk. During the initial startup of the XP install it will give you the opportunity to click the F6 button on the keyboard to load additional device drivers. You want to click F6 when it prompts you at the bottom of the screen and wait for it to prompt you to put your floppy disk (with the RAID controller drivers) in the floppy drive.
Hope this helps. If you need more help just let me know.
MO
Jul 13, 2008 | HP Compaq Presario v3000z Notebook
Pci ide raid card problem
Could be a PSU problem. What wattage PSU do you have?
Jan 31, 2008 | Sabrent SBT-RDIT PCI IDE Silicon Image...
ASUS K8N4-E Deluxe Motherboard Logo
141 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
