Question about Kenmore 62802 Electric Dryer
More dryer problems!
We had an issue where we'd push the start button and it would beep and then nothing. My husband took off all the fuses and checked them. And put them back in and it worked. I did a load today and the same thing happened. It will turn on then suts off. Any ideas? Thermal fuse?
  • 156 Answers
If it goes off then restarts its depends on model if its even heat the even heat board in the top is bad and if it beeps few times it also needs a thermaster which is a black thing inside dryer with 2 wires going to it
Posted on Mar 05, 2008
Our dryer beeps when start button pushed but nothing happens. Can you describe where fuse is?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 10, 2010 | Kenmore Elite HE4 Electric Dryer
Pushed a button but dryer does not start, can not push any other
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 12, 2010 | Kenmore Elite HE4 Electric Dryer
Push the button nothing happens
check the wires again
you just might have a bad fuse
odd but it does happen
Oct 07, 2009 | Whirlpool LER4634J Electric Dryer
When I push start it beeps 3 times. Lights on the right work, lights on the far left don't light up.
Alright, pretty unconventional, but simple and Genius on my part!!! Not sure if we're talking about the same models, but I was cruising this site with the same problem.... K, so it's making three beeps right? Check inside the DRYER (maybe same issue w/ washer, I dunno), but there's a button on the top-inside.... DEPRESS THAT BUTTON, and while holding it down, START THE DRYER (HOLD TO START), if it starts working, this tip is for you!
1) on the opposite side, where the door depresses that same button on the dryer door... you ready for this... see step two ;)
2) SUPER GLUE A PENNY IN THAT INDENTATION PART, your problem is there's not enough connection, and the door is no longer holding that same button down...
3) TA DAH!! Since a repair guy could've charged ya like 50+ bucks, I'll take... emmm.. 25$, email me at Kumatrev@yahoo.com on where to send the check, or just shoot me an email to say thanks ;)
May 29, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Dryer won't start.
possibly the starter/hold relay or the timer itself. ensure the door is shut properly aswell.
Mar 13, 2009 | Dryers
Dryer does not work
Dryer just beeps, lights work, panel lights change, dryer just wont start. before this dryer worked but kept beeping thru the whole cycle. now nothing but lights.
Mar 13, 2009 | Whirlpool GEX9868J Electric Dryer
New HE5t steam dryer will not turn on
What was wrong with your dryer? I am having that same problem?
Dec 27, 2008 | Kenmore Dryers
Dryer just says beep beep beep everytime I push start
sounds like you may have a bad door switch(mach thinks door is open when it is not).open door and look on front panel that door pushes into.you should find a small button covered in a grey rubber boot.push on it and listen for a click,if u dont hear a click the switch is bad.if u do hear a click it could still be bad or you can have a open thermal fuse
Sep 29, 2008 | Whirlpool GEW9250 Electric Dryer
Kenmore dryer stopped working, start button does nothing
need the model # from the unit should be where the door closes to the CYE4000AWW is not a Kenmore Model
Jan 21, 2008 | Magic Chef CYE4000AWW Electric Dryer
Kenmore 62802 Electric Dryer Logo
53 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
