After unit is on for approx. 1 hour or so, picture starts to pull down at the top approx. 8-10'' and then snaps back to normal. After a few of these cycles, the unit will shut off.
Ur Convergence ICS is the cause is shorted about to dies.U know how to solders?Tries Tv repair World.com,Tvrepairkits.com to buy the convergece kit to repair it ur self.The shop will cost u $300 for parts and labors.
Remove the spark plug, this will relieve compression. Then try to pull the recoil rope. If the unit still does not rotate, the unit should be inspected by a dealer.
E1 = The air filters need cleaning (after 720 Hours use) It will shut down until you clean the filters & reset the E1 alarm code. To do this you need to: Pull the Air Con appliance lead out of the power outlet in the wall. Remove & Clean the air filters & then put the cleaned filters back in machine Before plugging back in you Push & Hold the Power button on the Unit THEN while holding the power button you PLUG the lead back into the wall. Keep Holding the power button until you hear the unit emit a beep (hold for approx 5 secs) Then disconnect the power supply lead again. Then Plug it back in again & turn on It should be cleared & working well. Good luck
After you've unplugged the power cord, pull up on the top a little and look for 2 metal snaps under the top lip approx 6" from the front
corners. Use a standard flat screwdriver to push against the snaps and release the top from the unit. Watch out, the front will come forward and the drum may fall out of place, so have an extra hand there when you do it. Good luck.
need to remove glove box(mounted withscrews from bottom edge)once glove box removed you will see basically in dead center of glove box opening a approx.1" wide plastic black strap going from top of heater box straight down and wraps towards ft of car. remove bolt from top this strap,it will then pull downnwards and unhook from heater box.this opens up slot in heater box that you see a white holder assy slid into slot .grab ahold of tab and pull outwards removing from heater box. this holder for filter.replace filter(pay attention to directionof flow arrows on filter)slide back into heater unit(has guides it slides into)and reinstall glovebox etc....good luck! Joel
sound slike something fell down there and is jamming the blower from turning. if the filter is ontop of the unit, remove the 2 phillips located under where the filter pulls out from. and the n remove all the screws on back panel youll see ( down the left side of unit ) the filter houosing, its secured by 3 5/16 screws toward the bottom portion of the housing, simply unscrerw and wiggle out, then remove the debris, and reassemble.
if the lint screen is located inside behind door, eitehr remove the bottom accesss panel or pop the top(with a screw driver approx 3 inches in from ither side of main top relaes the clips) the lid tips back revealing 2 screws holding front panel to the unit, after removing you will see the filter housing, still mounted by probalby 3-4 screws, remove the housing and retrieve the debris that has fallen down there
