Question about Olympus WS-100 Digital Voice Recorder
Recording Time I encountered a problem with the WS100 recorder after I downloaded and erased the files on it. The remaining time does not return to the freshly formatted time of 4:25:27. It appears that the recorder is not recognizing the newly freed space but is continuing for where the files left off. Is this a defect or is there a way I need to format the recorder?
  • 4 more comments
  • pdcstu1 Mar 21, 2008
    After taking the time to talk to Olympus tech support, they thought it was perfectly normally to have to reformat the recorders in order for it to return to its full memory state. Their response doesn't make sense to me but I guess it adds to my disappoint with the product and its unreliability.
  • Anonymous Mar 28, 2008
    I've had the same problem. My recorder now only has a max of 47 minutes recording time before I have to dump the audio. I tried reformatting, which is supposed to erase all memory, even that which may be hidden, but it didn't help.
  • carrief May 04, 2008
    I have erased all the files from the recorder, tried to reformat, and it still says Full even though there are no files on the recorder now.
  • RodSh Nov 21, 2008
    Likewise I removed all files but still only have 35 minutes recording available.
  • trudiC Feb 19, 2009
    I have no files on my WS-100 and when I go to record it tells me it is full, and I can't record.
    As I have an interview for work in half an hour, THIS ISN'T HELPING MY STRESS LEVELS...!!!
  • lupis08 Apr 15, 2009
    i have the same problem. is there any solution to get the full memory or have i to buy a new recorder??
Hi, This may help: I had same problem, but solved it by downloading files to my PC, then deleting them. I now have folders ready to go, with over 8 hours available on each of them. I sure hope this helps -- I've had to learn so much about this recorder by trial and error, and that's not good when it's used for business! Linda
Posted on Apr 22, 2008
I have one of these recorders, I actually have 4 or 5, since discontinued I believe, and one is stuck at 43 min remaining.
I think that problems start when you remove the battery while
the recorder is / was in the process of recording (or in play mode) I now press stop while recording before opening the battery case to switch a battery
Posted on Apr 11, 2008
How do I delete a recording off my Sony Sony - ICDBX140 - 4GB
  1. Slide the HOLD?POWER ON/OFF switch in the direction of "POWER ON/OFF" to turn on the IC recorder, or towards the center to release the IC recorder from the HOLD status. The stop mode window appears.
  2. Select the file you want to erase when the IC recorder is in the stop or playback mode.
  3. Erase a selected file. When the IC recorder is in the stop mode, press and hold ERASE.
    When the IC recorder is in the playback mode, press ERASE.
  4. Press ERASE. "ACCESS" appears in the display window and the selected file will be erased.
    When a file is erased, the remaining files will advance so that there will be no space between files.
Hint
  • To cancel erasing, press souni_stop.png(stop) in step 3.
  • To erase a part of a file, divide the file into two files first, and then proceed with steps 3 through 4.
Mar 10, 2015 | Sony Video Cameras
Why a low remain record time on zoom h1 handy recorder when .wav setting in use?
when you record in .wav format, the files ARE better quality, however, they are ALOT larger than a standard .mp3...if you can't tell the 'loss in quality', i would suggest to keep recording as .mp3...but if a .wav is preferred, then i would suggest upgrading the SD card. ..hope this helps.
May 23, 2014 | Music
Am I able to recover erased file on Olympus WS100 digital voice recorder
Sorry NO...once files are deleted they are gone...there is no"recycle bin".
Sep 16, 2010 | Olympus WS-100 Digital Voice Recorder
After transferring recording to computer the voice recorder remained in the pc mode and i have been unable to get it to return t the recording mode the recorder is too good to throw away please help...
If you have tried removing and re-installing batteries and that didnt work you maybe should try reformatting...this will erase all files on handheld tho'...instructions for reformatting are in your operators manual or you can download a manual from www.olympusamerica.com
Aug 26, 2010 | Olympus VN-3100PC Digital Voice Recorder
On my Olympus DS-2, although I have erased all my files the recorder shows that that there is little or no room for recording. This is the first time this has happened to me.
The amount of room available on the Olympus DS2 are determined by two things:
1. Avaiable Memory
2. Recording Mode
With that said, if you have formatted (erased) the files on the recorder and there is little recording room left, you will need to change your recording mode. I would recommend changing it to SP mode.
I hope this helps.
Feb 26, 2010 | Olympus DS-2 Digital Voice Recorder
PLEASE HELP!!!! I erased my class recording by
download a program that gets the remnants of that file and u should get it back simpleeeee......try to look before u delete next time...u sound like a damn blonde
Nov 03, 2009 | SanDisk Sansa E280 MP3 Player
Recording a greeting
You need to be in Tam fax mode firstly.
1, {#} {0} {0} {1}:= “TAM/FAX” (default)
2,
Press {RECORD} repeatedly to display “TAM GREETING”.
3,
Press {SET}. A long beep will sound.
Speak clearly about 20 cm ( 8 inches ) away from the microphone.
The display will show the remaining
recording time.
5 When finished recording, press {STOP}.
The unit will repeat your message.
To erase and start again
Tam/fax mode again.
2 Press {ERASE} repeatedly to display “TAM GREETING”.
3 Press {SET}.
To cancel erasing, press {STOP}.
4 Press {SET}.
should be good now.
Regards
Richard.
Apr 24, 2009 | Panasonic KX-FPG376 Plain Paper Thermal...
Remaining recording time VERY short for no apparent reason
check how many different folders you have set up. just because you erase all in one folder, there can be other folders.
Find the manual reset for reformatting the recorder.
Jan 25, 2009 | Olympus WS-110 Digital Voice Recorder
Olympus DS-30 recorder: memory is full but there are no files to delete
1.Press the FOLDER button to choose a folder.
Every time the FOLDER button is pressed, it cycles through folders and the List display will appear (+P20).
Press the + or button to choose the file you want to erase.
Press the ERASE button. The “Cancel” indicator flashes.
Press the + button to choose “Erase”.
5
Press the OK button. The display changes to “File Erase!” and erasing will start. “Erase Done” is displayed when the file is erased. File numbers will be reassigned automatically
Apr 04, 2008 | Olympus DS-30 Digital Voice Recorder
Erasing Files
when you copy the files to your computer the files are still in the ws-100, you have to erase them in the ws-100 buttons after that.
Feb 29, 2008 | Olympus WS-100 Digital Voice Recorder
Olympus WS-100 Digital Voice Recorder Logo
176 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
