Question about Tappan TGF363 Gas Kitchen Range
Gas burner does not work
One burner of my Tappan gas range does not work. How can I fix it?
  • oforhim Aug 05, 2008
    Same problem, My model is MGF334BGDD. where can I order a replacement burner?
  • k_tzen Sep 06, 2008
    Hi ,
    My gas range 2 out of 4 burner is not working, I hear sparking and smell gas, but no lighting .
    The other 2 in right hand side work fine.
  • 868 Answers
Replace it after youve made sure that no food or debris is in the way of the electric spark that lights the gas.
Posted on Jun 12, 2008
  • 1015 Answers
SOURCE: Oven will not heat
This can be caused by a weak/inop hot surface igniter or a defective gas control valve. First you will need to verify that the hot surface igniter is coming on(you should see it glow in the burner compartment). If it is not glowing then you will need to verify that the wiring harness has voltage to it when the oven thermostat is on. Also check the igniter for any cracks or damage and if found then replace the igniter. If it is glowing then one thing that you can try(be very careful doing this) is to give the gas control valve a light tap with something hard like a wrench when the oven is turned on,igniter is glowing but the burner is not on. You will need to remove the broiler/storage drawer at the bottom of the oven. Once you pull the drawer out you should see the gas control valve at the back of the range. Try turning on the oven and lightly tapping the valve housing after the igniter is fully on. This may loosen up any debris inside the control valve housing that might be causing the problem. If the oven burner comes on then try completely turning the oven on and back of several times. And when I say completely I mean turn it on after the igniter is not glowing and burner has shut off. This works about 30% of the time. If the burner control valve sticks again after trying this procedure then it could be the control valve and/or the hot surface igniter defective. The hot surface igniter would need to be disconnected from it's harness and tested with an OHM meter. Most igniters should have a 500 to 700 OHM reading. If you get a reading that is way off then the igniter is defective and replace it. If the igniter tests good then the gas control valve is suspect and replace it. Most appliance parts retailers will test your igniter for free. When the igniter is on it should glow very brightly. If it is dim then that is a sure sign it is bad.
Posted on Apr 01, 2010
  • 163 Answers
SOURCE: Tappan Gas Range
Most likely has "ON PILOTS" As opposed to (electronic ignition/ Ignitors).. Change the stove to a more efficient model and being gas do "NOT" Do it yourself Period!.(Please)..Install should be tested and approved..
Call a local professional specialized in LP/Natural Gas Appliances. Flex lines on older Stoves tended to break down causing leaks as well as older construction codes where Black pipe feeds and shut-off valves break down after time. Sorry for the Negative info but Ive seen some Slum-lord homes in my days doing service calls.. Keep it shut off until you can get it fixed professionally..
Posted on Jan 16, 2008
  • 150 Answers
SOURCE: tappan gas range oven makes a whisling sound
the gas pressure regulator can whistle sometimes. turn up the radio. (just kidding) I have had some new units that did this and replaced the regulator and it still did it! I was working as factory authorized service tech and my factory techline said it was a gas pressure thing. I was thinking it was the valve rather than regulator but tech guys said no. I don't know about that response but thats what I got.
Posted on May 09, 2008
docjohn174
  • 943 Answers
SOURCE: TAPPAN MILLENIUM GAS RANGE
hi thanks for the question so in your onen you are saying that the top broiler works but not the bake there is a igniter in the bottom of the oven ita an igniter same as the top replace it
Posted on Sep 16, 2008
huuum
  • 750 Answers
SOURCE: Tappan gas range burner ignition
Hello paultoledoWelcome to fixya.
I'm Huuum and happy to assist you,
You said, You got a 5-year old Tappan gas range. Two of the burners don't ignite, the other two and the oven are fine.
What do you need to do to fix the problem?
Sounds like a yes from where I'm sitting, your right on target, buying a new spark module will fix it.
That sounds like the spark modules.
I think you are correct!
Let me know if you need me!
Please remember to leave a solved rating!
Huum
Posted on Sep 24, 2008
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
I have a used Tappan gas range with 4 burners and a griddle in between the burners. everything works, but the oven temp varies about 40 degrees above and below the setpoint. it never seems to level out...
not normal
problem thermostat not lighting the gas or turning the gas off to maintain an even temp
temp variation should be around a 10 degree range
call a gas fitter to check out the oven controls , thermostat or thermocouple
Sep 19, 2017 | Tappan Kitchen Ranges
No gas going to oven
Hi blocked oven pilot , ffd not working oven burner blocked injector blocked
Feb 02, 2010 | Tappan 24 in. Freestanding Gas Range...
Tappan gas range electric pilots will not light
The gas line in your Tappan could be closed or
stucked up. Have it check.
Sep 23, 2009 | Tappan TGF320 Gas Kitchen Range
Tappan oven not gas flow or ignition
Right rear burner will not ignite without assistance (a match or lighter). What is the problem?
Feb 13, 2009 | Tappan TGF303BW Gas Range
Huum
Sep 24, 2008 | Tappan TGF657 Gas Kitchen Range
Tappan Gas Range Oven Will Not Light
probable displaced burner assembly, faulty flame failure device or blocked burner or jet. Regards Engineer
Jul 20, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan TGF363 Gas Kitchen Range Logo
160 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Craig Butler
Craig Butler
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
