Question about Creative Labs Nomad Jukebox Zen Xtra MP3 Player
Creative Nomad Zen Extra 40 Gb
I used the software to add about a thousand tracks today, but suddenly it stopped accepting uploads. I attempted to drag an mp3 file from another explorer window, as i did for the other thousand tracks that worked, into the music library, and it just showed the mouse pointer as a circle and slash.
There is almost 12 Gb free on the jukebox, and other than that, it all appears to be working fine. I have restarted the software, restarted my computer, restarted the jukebox, and changed the mp3 file properties every which way i could think of. The files i am attempting to play all work on winamp, and they didnt come from any crappy drm restricted files (some of them came from cassette, ripped by me).
I think the problem was related to the id3 tagging, but i wasnt able to conclusively determine that. I had to uninstall the nomad explorer, and reinstall it. That didnt stop it from happening again, but each time the same solution worked. Then the thing crapped on itself furthur. It would turn off then back on, and say it was rebuilding the library. Then it would turn itself off midway through that, and start over. I removed the battery, and put it back in. The thing made it all the way through the rebuild of the library, then just had a little icon on the display saying firmware problem. The solution was a firmware upgrade. I had to hold down the play button while sticking a paper clip in the reset. Then a menu came up and i selected reset OS. It deleted the OS, and re-upped one from the file i found at the creative website. The problem recurred at least once, and the solution was the same each time. It never lost any content while going through this rigamarole, but i did lose some hours fggin with it.
Posted on Mar 10, 2008
Ihave no disc for my zen extra 40 gb and can not connect it my computer what should i do please help thank you
www.mediamonkey.com
visit this site and download the mediamonkey software.It will sync your player with your music files as well as being an excellent free alternative to windows media player.
Apr 28, 2010 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Trying to recover nomad jukebox zen extra
Get an original Vista operating system disc..
then insert d CD and boot from the CD!
Apr 29, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Zen Xtra Error Message When Creating Playlist
The only solution I know of is to reformat the hard drive. It's pretty time-intensive, but it does work. I use Notmad to back up the playlists. Once restored, they all work, even the ones that had initially failed.
I've never had the problem on my 60GB Zen Xtra (non-upgraded hard drive), only with my 120GB, so my naive guess is that the problem may be caused by the machine somehow not handling the extra hard drive space properly.
Also, both times it's happened, I've seen a warning sign: I usually have a lot of stuff loaded into "selected music", and when I add another album or two it partially clears the selections. And it does so in a weird way: only a few selections remain visible, yet it keeps playing at least some of the now-invisible selections.
I'm starting to think it's time to switch players, and maybe get something I can put the Rockbox OS on.
Feb 02, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Nomad Zen Xtra 40 GB Jukebox
Download creative mediasource5 BUT ALSO the nomad plugin, then your computer will pick it up
Sep 12, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Zen Xtra 40 GB
Ok this is what I have found.....Try to run the Recovery Mode here is a link to Creative Labs website that will walk you through it... Just look for Jukebox its on the bottom...you can get the firmware from the same website under support and then just select the type of jukebox you have....that will be the second link...You will need to click on Zen and then look on the right side for Archived Products
http://support.creative.com/kb/ShowArticle.aspx?url=http://203.211.142.197:80/srvs/cgi-bin/webcgi.exe/,/?st=357,e=0000000000342903798,k=6058,sxi=1,varset=ws:http://us.creative.com,case=4794
http://support.creative.com/Products/product_list.aspx?catID=213&CatName=MP3+Players#
Good Luck and let me know if this helped
cbinny1
Aug 17, 2008 | Creative Labs Zen V MP3 Player
Creative Labs Nomad Zen Extra Jukebox 30 GB not working
Uninstall everything from your PC, reboot, reinstall driver and the Explorer (I do not use MediaSource, only the Explorer).
If it didn't work out follow these steps:
1. Uninstall Creative Media Source and all related software.
2. Install the driver. In the installation CD the driver is usually in \Drivers\English
3. Turn on the Nomad an connect it to the PC.
4. Install MediaSource(the program requires that you have the nomad connected while installing)
5. Install MediaSource plugin
6. Try transferring files.
If you?re still running into problem know that there are other programs capable of handling MediaSource?s functions, such as - Portable Audio Devices Power Toy , NomadSync, Real player, and there?s also a Zen plugin for the Winamp.
Jun 14, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Full Data not showing on the Nomad Zen Jukebox.
When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Mar 14, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative Nomad Jukebox 3 (40 Gb) Driver for Windows Vista
Me too ... sorry no soulution, i have tried a couple of fixes suggested for the zen here but they are not working, weird... had another vista machine recently as a loaner and managed to get it working... hmmmm
Jan 12, 2008 | Creative Labs Nomad Jukebox III MP3 Player
My creative nomad jukebox zen extra 30gb
means the software used to operate the unit is corrupt and you need to download and install a new version
http://us.creative.com/support/downloads/
Jan 01, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
'Library Full' Error when transferring files to Zen.
the zen uses other areas for data storage and stuff.
best to reformat and not use so many folders.
Oct 21, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative Labs Nomad Jukebox Zen Xtra MP3 Player Logo
267 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
