Question about iLO MP3 Player
ILO MP3 Player 1GB
Power on MP3, select music to be played with volume set a comfortable level. Next volume go to max, I am unable to power off player, I can not change volume, I can not select menu or different music. Only option is remove the battery. Not sure what to do.
Where can I purchase 1-GB iLo MP3 Player at? Walmart does not carry them anymore. Please help, Mike in Orlando Florida~
Posted on Mar 05, 2008
SOURCE:
The volume control is frozen on the lowest level.
The manual gives next steps to setup the volume:
1. Press Menu button to return to the Main Menu.
2. Move down to Settings and select it.
3. Select Volume.
4. Highlight the desired volume settings then press Select button.
Manual in pdf format for the Sansa Clip:
http://mp3support.sandisk.com/sansa/UserManual/CLIP/CLIP_UM_English.pdf
Dec 19, 2009 | SanDisk Sansa Clip MP3 Player
I need to unlock my volume control
Press menu button, select settings, select playback, select volume limit, turn volume to max and press select button. This should let you play music at max volume
Nov 01, 2009 | Apple iPod classic MP3 Player
Lost manuel for sylvania mp3 player smpk8854b
alright these are the controls
menu is select
the back button is the play button
if you wanna delete something use the fastforward and rewind buttons to go to explorer then select it
then press menu till you are in your music or voice folder or whatever u want to delete then press volume down and use the fastforward and rewind to select yes or no
If you wanna put it on hold press volume down and menu
and that should be it
Jul 09, 2009 | iLO MP3 Player
I have a sharper Image mp3 player cant figure out
With music (or whatever)playing hold down V button (left hand side of control circle)til volume adjustment screen comes up-a blinking speaker. Press PRE or NEXT button (top and bottom arrows) to adjust volume.
Mar 04, 2009 | Sharper Image 1612911 MP3 Player
Display "fried". No, literately, its fried.
May need replacing, but
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 26, 2008 | iLO (2 GB) MP3 Player
MP3 ilo
You might try this, but before you do see if there is a small "pin" hole around the outside of the case to re-set the operating system.
If not and/or the system won't reset, go to
http://uiss.max.io/downloads.html
and download the zip file, install it on your computer and run the RAVE set-up.
Mar 12, 2008 | iLO (2 GB) MP3 Player
It's blinking on the ilo screen
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Mar 09, 2008 | iLO (2 GB) MP3 Player
Ilo mp3 player
2)
Mar 05, 2008 | iLO (2 GB) MP3 Player
I was wondering if i could contact ilo for problems with my ilo mp3 player
I am planig to register NGO For civil rights need contact
Jun 20, 2007 | iLO MP3 Player
Problem with volume in player
Every mp3 player manual has a disclaimer that says not to play it at max volume - the only workaround is to get adjustable headphones, and keep player volume at less than max
Jun 18, 2007 | iLO (2 GB) MP3 Player
64 people viewed this question
Top iLO Audio Players & Recorders Experts
Ekse
Siul Oyaratgam
Rick
Rick
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
