Question about HP Photosmart 7850 InkJet Printer
Help my color is off line how do i put it back online, so my pictures can be clear
  • 47 Answers
Try aligning the cartridges...go to hp support center...find printer maintenence or the like...click align cartridges, or ssomething of the sort. otherwise, clean ink nozzles...same control panel as above.
hope this helps
unidentified geek
Posted on Apr 08, 2008
Hl72a650
color wheel issues replace light engine
Jul 07, 2013 | Televison & Video
Repair
To have a fair chance to advise or help I need to know the model number and brand of set(JVC)?
Apr 25, 2012 | JVC Televison & Video
Samsung ln46b630 started with verticle lines still have picture but it looks fading with lines on top of it started this 2 monthes ago cleared up then started back last week & now the the lines are...
screen ribbon needs resetting not an easy job to do if you not done them before as you need to take the screen out and remove the screen shield off to get to the ribbon, then put a foam or rubber spacer over the ribbon so that when you fit the shield case back on it just pushes on it slightly so it has good contact. and its best to do all the ribbons as this will help it not do the same to the reset.
Dec 24, 2017 | Samsung LN46B630 LCD TV
Picture suddenly has vertical colored lines with no clear picture
That happened to my new plasma TV 30 days after i bought it and the TV repair guy came an fixed it and i saw what he did and he told me that there are 3 circuit boards in back of TV and each one controls their areas, center circuit board was controlling the center screen of my TV which was where the lines were so he replaced it and the lines were gone. this board are usually on the bottom part of the TV and they look alike but they are not due to the connection location., i hoe this help
May 07, 2010 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Too much yellow does not adjust with normal drop screen adjustments. can i adjust the light beams.on my philips 50"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the green screen control on the Focus Block until retrace lines appear and gradually turn it back
Until the point where you can see the retrace line disappears, just before cutoff.
2. Turn the red screen control on the Focus Block until retrace lines appear and gradually turn it back
3. Turn the blue screen control on the Focus Block until retrace lines appear and gradually turn it back
until the point where you can see the retrace line disappears, just before cutoff.
4. If the screen still appears too bright after proper G-2 adjustment, you need to adjust the sub-bright adjustment in the service menu
control down until screen cut-off. (Service data Range is usually 21 to 25 in the Service menu, for Sony sets you first go to category "MCP2", & then adjustment item 01( "SBRT")= subright.
For electrical the focus, put on the screen a clear picture of your choice thru an input of the TV set from a DVD, then pause the playback of the DVD Look into each color and rock that color focus control back and forth (turn the control one way then the other way slowing down as the picture goes into the best focus. till the picture looks sharp do each color till they all look in focus. NOTE: it is best to look into each color tube to achieve the best electrical focus. For optical focus please follow the manual lens adjustment in the sets service manual
By Larry Dillon
Aug 27, 2009 | Philips 50P8341 50" Rear Projection...
Lines in images
Color lines in the LCD display is caused by certain type of light connections. If you get all the time when you turn on the camera then the LCD panel is bad, would need to be replaced. Black lines in printed printed pictures from your printer or the Kodak dock station printer? If that's the case, then the transfer rollers are dirty and would need to checked or replaced. Also drivers could do this also. Report the problem to Kodak Live Chat Online Tech Rep or called on the LAN line (phone).
Jun 25, 2008 | Kodak EasyShare M853 Digital Camera
Toshiba Theaterview TP48E60
Replacement of the board is never recommended, unless the board caught fire and is all burned up. If the convergence circuits quit working then you still see a picture, but the 3 colors just dont line up with each other. The picture shutting off, closing in and then popping back to full suggests a loose solder joint in the horizontal deflection circuits. This is something that cannot be adjusted in the service mode and the repair should be handled by a qualified tech.
Aug 07, 2007 | Toshiba 46H83 46" Rear Projection...
HP Photosmart 7850 InkJet Printer Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
