Question about Panasonic DMR-EH75VS DVD Recorder/VCR/HDD Recorder
Plays for a minute or two - then just shuts itself off
My DMR EH 75 V (just recently out of warranty) has mysteriously stopped functioning properly.  When attempting to view a DVD or something recorded on the HD, it will play for a minute or two and then just say "BYE" and shut down.  Is it trash time?
Thanks for any help.
Lloyd
  • 4 more comments
  • heb112 Jun 28, 2008
    Mine just started doign the same thing...I've had it for about 18 months, bought new but of course now out of warranty. Not quite sure what to do.
  • heb112 Sep 15, 2008
    Haneth, I think mine did that for a very short while before it completely went haywire. One day it would not record what it was supposed to (or just a few seconds/minutes), but then it would be fine for a few days. Hope yours doesn't progress the same way.
  • LloydH Sep 15, 2008
    I have figured out a workaround that works for me.  The problem seems to have something to do with the damned TV Guide feature, which has never worked for me (I have DirecTV).  I have found that by resetting the whole program - push and hold, (I think it's <<<< - check the manual) on the box itself - until it shuts off - restart and enter all the settings for the unit and the TV Guide thing.  It works for a while, but every so often it screws itself up and you have to do it all again.  It's worth it for now, 'cause I don't see anything out there on the market as capable and that I like as much as the EH75VS.
    Lloyd H
  • Anonymous Jan 24, 2009
    just recently my eh75v started tuning off after a couple of minutes...I thought is was a programmable remote sending the wrong codes...but using just the front panel of the box made no difference. I'll try the reset as suggested earlier and see how it goes.
    ok - so I previously posted as guest. no luck with the reset (channel up/down for 10-15 seconds). Firmware posting from panasonic site was not available (ftp site did not have the file). I called the panasonic support line, and they had no support/diagnosis for the issue. They offered to have me send it to their repair facility (it is out of warranty) for $130 (shipping included). I declined, to do a little more work on my own...
  • pasquale319 Mar 29, 2009
    I think I had a similar sympton, but not sure what caused the problem in the first place since 2-3 events occurred in the same timeframe. I have had a Panasonic DMR-EH75V since mid-2007. I love it. I just recently encountered the "plays for a minute or tow, then shuts itself off". The Panasonic service center were not aware of this sympton and could not help. This sympton would occur with my DVD as well as the hard-drive recordings. I couldn't run setup since my unit would go off before I could finish the setup. However, I then connected my unit to my old analog TV, and I was able to run setup. Then I switched my cables back to the LCD TV and everything seems to work fine.
    Not sure what contributed to the problem. Here are the 2-3 events that recently occurred. My new Samsung LCD TV went out (on/off/on/off) and the motherboard had to be replaced. At the same time, I could not set the time (as well as losing the TV Guide) - this was as a result of the switch from analog to digital (PBS will no longer provide the timing signal nor the TVGOS signal, but both the TV guide and the timing signal will get fixed in May). I also switched from the HDMI-HDMI calbe to the RCA cables, but that didn't appear to be a root cause. I could only guess that between the TV and the Panasonic unit, the Panasonic firmware got confused. But I'm just guessing.
Mine will intermittently record only the first minute or two of a tv show I have queued up to regularly record. It seems to happen anywhere from every show to every 5-10.
Posted on Sep 15, 2008
How do I stop my Panasonic DMR-EH75V DVD Recorder from automatically turnig itself off after 75 seconds?
It could be overheating.. Is it fairly consistent at 75 seconds? To test put the unit in the fridge for 30 minutes then quickly connect it up and test. If it is longer then 75 seconds then something is getting to hot. I've put hard drives (especially laptop ones) in the freezer if I need to copy off data but it clicks/stops working at room temp.
Aug 10, 2014 | Panasonic Diga DMR-EH75V DVD...
Can my Analog reciver Panasonic DMR-EH 75 v be converted to a digital reciever
I bought a set-top converter box from Dish Network, which will operate with the DMR-EH75V through the remote control cable that was provided with the recorder. It tunes in all the available digital channels and uses the RCA A/V cables to connect to IN1 on the back of the recorder. TVGOS is now provided through channel 2.1 (CBS) in our area and it also provides the time signal that keeps the recorder's clock updated. NOTE: ONLY the Dish Network boxes work with these functions. I've had occasional issues with the box after some period - a few weeks - it needs to be rebooted or reset to manual and then back to automatic (which causes it to reboot anyway.) Model no is DTV PAL PLUS.
Jan 06, 2011 | Panasonic Diga DMR-EH75V DVD...
I get a u61 error code. Manual says nothing wrong with unit and will reset itself-has been 2 days
Shut down power, unplug from wall power socket, wait a few minutes then plug in and try again. This is the reset process, to load codes into drams properly when the machine is no longer in standby mode.
Jun 27, 2010 | Panasonic DMR-ES35VS
No power at display!
You've probably destroyed your magnetron, and the magnetron thermostat.
This kind of abuse will not be covered under warranty.
It will likely run about $75 for a technician to visit the home, $75 to do the work, $75-90 for the magnetron, and about $15 for the thermostat.
You can locate a Maytag-authorized servicer at http://www.maytag.com
Apr 24, 2010 | Maytag MMV4205 Microwave Oven
DMR EH55+ a misdiagnosed problem
The DVD Drive is bad. Buy a used DMR-ES15, DMR-ES25, DMR-ES45, or DMR-ES46 with a good DVD drive and swap out your bad drive. And be sure not to record in the high speed mode in the future. Set your recorder to High Speed Mode Off. Then see about getting your money back from the shop that didn't know what they were doing.
Mar 25, 2009 | Panasonic DMR-EH55 DVD Recorder/HDD...
BLOW OUT
Check on your deflection board for open capacitors Green & Gold writing cp150 location number 2200uf 16 v and two 220uf 35 volts.
Sep 16, 2008 | RCA HD56W66 56" HDTV
Auto shut to work
This function is kind of confusing. It will not shut the player down while music is playing. It's just basically a battery-saving function. Say you leave your player on and not playing. After set amount of minutes it'll shut off to save battery life, but not if it's playing music. Odd function, eh?
(btw, this is what i've found to be the function and may not be 100% right.)
Aug 25, 2008 | SanDisk Sansa e260 MP3 Player
Lenovo laptop shutdown suddenly after working for a while
Hi James, replace the fan or If it's still under warranty have it serviced. Suggest you stop turning it on until the fan is replaced. It could be the fan cooling the CPU. You don't want it to fry.
The shut down process is normal when over heating is detected by the system.
lenovo link. http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-63446
Mike
Mar 24, 2008 | Computers & Internet
Unit shuts itself off within a few minutes.
. Try taking a can of compressed air and spray in the vents in the front and the back of the heater. The heater has a sensor that gets dusty and causes it to shutoff to prevent overheating.
The heater should function properly once the dust is blown off the sensor.
Mar 06, 2007 | Lasko 5365 Ceramic Compact Heater
Panasonic DMR-EH75VS DVD Recorder/VCR/HDD Recorder Logo
520 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
