Question about Baby Gear
Chevy wiring 1980 250 4-wheel drive
No headlights, no horn. New alternator that won't charge. Accessories all work with key on.
  • 2,039 Answers
On the starter you have the battery cable attache to the battery cable you have little wire there fuses holder gently pull on those wire one of them broken thanks for using fixya pierre
Posted on Mar 06, 2008
Headlight on 1988 Yamaha Virago 250 does not work
Hi, Anonymous if your headlight is not working, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn, chaffed, or broken wires in the light circuit.
3. Corroded, broken, or loose pins/sockets in wire connectors.
4. Faulty hi/lo beam switch.
5. Faulty ignition switch.
6. Fuse is good but no continuity on both sides.
7. Faulty wiring between battery positive and headlight bulb socket.
8. Weak charging alternator/generator.
9. Faulty voltage regulator/rectifier, overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://vfrworld.com/forums/showthread.php/13661-New-owner-headlight-doesn-t-work
http://www.beginnerbikers.org/showthread.php?35667-88-yamaha-xv250-battery-not-charging-headlight-horn-not-working
http://www.groussin.com/multi/XV250.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2005/LIT-11626-18-21_1000.pdf
May 27, 2012 | 1989 Yamaha Xv 250 Virago S
Phantom battery won't charge
Hello
Are you sure your battery charger is working correctly. Have you tried it on another battery? Possibly, there is a wiring problem, or your battery is the type that needs distilled water - Try another known good and charged battery with your scooter before purchasing a new one to ensure that the wiring is not faulty.
ilona
Aug 02, 2017 | Drive Medical Mini Phantom Three Wheel...
2001 Suburban Horn not working
Dealers charge approximately $75-90/hr. labor. The horn pad repair, labor-wise, can easily run 2 hrs labor plus parts. Unfortunately, the horn buttons in the pad are flimsy and break easily. This could result in more repairs later. An alternative fix, if you are not fussy about appearances, is to nount an external horn button on the dash within reach of the driver. This is legal for inspection puirposes in MOST states (check local laws). You can cut into the horn wire where it comes out of the steering column, or you can ****** it at the horn relay, whichever is more accessible. The horn button can be obtained from any auto oarts store, and will be a more permanent repair. Also, no airbag worries. While working with the wiring harness, avoid any YELLOW wires. These are normally airbag wiring.
Nov 23, 2011 | Chevrolet Suburban 2500 Cars & Trucks
Horn not working when you press on the streeing wheel but will work on key pad for a chevy pickup 2005 year 1500
Check the horn button on the steering wheel if it has continuity or just short out the wires on the switch connections. If there is only one wire on the horn switch, short it to earth to see if the horn works that way. That will indicate if the horn switch is faulty.
May 16, 2011 | 1999 Chevrolet Silverado 1500
1999 Buick Century, from bad to worse.
check connections and wiring at battery and alternator then check battery and alternator -battery may not be holding charge and is dead and or alternator is not putting out enough of a charge or not charging at all some auto stores will check ur battery and alternator for free
Nov 15, 2009 | 1999 Buick Century
Something is draining the battery on my 2000 Jeep Wrangler. We have a new battery, alternator checked okay, new starter. The jeep starts, lights come on, and then will die while driving. What could be...
Put a volt meter across the battery terminals while the vehicle is running. You should read no less than 12.5 volts at idle with no accessories running and no less than that with accessories all on. Normal volts should be around 13.5. Aside from slight fluctuations, the voltage reading should not steadily drop, regardless of how long it is running. I doubt if you have a system drain if it's shutting down while driving...the alternator would compensate for that. Some charging systems incorporate the voltage regulator into the computer. If the alternator checked good by itself but the tests I recommended show otherwise, likely your problem is with the computer.
If the engine does not need to be jump started after it shuts off, you may be looking entirely in the wrong place...but you didn't mention that part!!
Oct 21, 2009 | 2000 Jeep Wrangler
2005 sebring convertible- horn goes off by itself for 30 seconds
FIrst off the horn's ground works through the steering wheel,so the wire is bare or the end is broken and grounding in a place where it should not. You will have to check the wires for the horn from the fuse box up to the wheel.
your power feed to the headlights and the door locks has an open ( the power is not connected somewhere ) Perform a wiggle test turn on the headlights and lift the hood,find the power distribution box and begin to wiggle the wire harness.Sometimes the chrysler fuse box under the hood get loose inside the power distribution box,it will have to be broken down all the way to the heavy wires comming out of hte box,you can tighten these connections your self.
Aug 08, 2009 | 2006 Chrysler Sebring
1998 S10 Chevy Horn not working
You most likely need a new clock spring rotating contact under the steering wheel, it is a plastic ribbon with wire in it to connect the horn button and other accessories to the steering wheel while allowing the wheel to turn.
Sep 22, 2008 | 1997 Chevrolet S-10 Pickup
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
