Question about Foxconn 6150BK8MC-KRSH Motherboard
Monitor won't turn on
Just installed and the monitor won't turn on
  • Anonymous Mar 06, 2008
    Changed case before OK now fans turn OK monitor does not
  • Sergio Scalfaro
    Sergio Scalfaro May 11, 2010
    information of your pc please?
    Thanks
    Sergio
  • 3 Answers
I had this problem.. I had a graphics card and my monitor was plugged into it. it would load windows boot screen then would go black, if i switched monitor to the motherboard instead of my graphics card it would work. The solution was in the BIOS make sure it is set to run off your graphic card or motherboard depending what it is plugged into. hope this helps
Posted on Mar 28, 2008
Sergio
The problem that I encountered was the following;I had the PC function great untill I switch the case, which at that point it refused to turn on. I could tell that the motherboard was recieving power becuase all of the fans turned on. Very strange... Here is the configuaration.
1 GB of memory in slot 1
430 Watt power Supply
Hard Drive connected to SATA 1 on the motherboard
DVD ROM connected to main IDE slot
Posted on Mar 06, 2008
    Sergeant:
  • 300 Answers
Verify all of the power supply connections have been made. Also, verify the RAM is properly seated. You might also try moving the RAM to other slot(s).
Posted on Mar 04, 2008
I don't want to install catalytic convertor - How do I just cancel p0430 code?
the light won`t go out as the catalytic function is monitored by sensors and if the monitors don`t see efficiency within set range the light will go on. if you remove the bulb you won`t know if any other codes are being set and the light test when you turn on the key is part of the e-test it will fail and you will have to fix it anyways.
Aug 30, 2014 | Ford F-150 Cars & Trucks
Try lowering the resolution on TV and raising on PC. Your video card my not handle HD settings such as 1080 dpi or higher. Also use the best input available on your video card. It goes from VGA to DVI to HDMI.
Aug 31, 2012 | Packard Bell iMedia Computers & Internet
Notebook won't turn on
my nb500 netbook wont turn on i slamed it shut now wont turn on
Apr 23, 2012 | Toshiba NB500-12X
Monitor won't go on
What to you mean by Monitor won't go on? Are you saying the power on the monitor will not turn on? Are you saying the Monitor is on, but there is nothing showing on the screen? Also it would help if we know what kind of computer and what operating system.
Mar 22, 2012 | HP G60-235DX Notebook
Monitor won't go on
Mar 22, 2012 | HP Pavilion G60-235DX notebook
Vsonic flat screen monitor need blink codes
hi do you mean you are asking for the blinking codes on your viewsonic pc monitor?. usually lcd monitor for pc has no blinking codes, if your monitor just only a blinking indicator and won't turn on, you must check first the source from your pc if their is a signal to turn on the monitor. if just blinking only then won't turn on you must check the power supply of the monitor usually the main cause is bulging capacitor. just replace it with the same value and rating thanks for consulting the fixya good luck.
Feb 26, 2012 | Computers & Internet
When restarting my computer after a hard drive replacement the monitor does not turn on, it goes into "power saving mode" and won't turn on.
You should try this monitor with another PC to make sure it is not the PC problem since you replace the hard drive but you may have not installed all the drivers for your PC hardware.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
May 18, 2011 | LG Flatron L1750S 17" LCD Monitor
P25g motherboard, monitor wont turn over
i think you need to try replace you're ATX power Supply or you need to try remove the other 1 of you`re memory...Thanks
Apr 23, 2009 | PC Chips P25G Motherboard
COMPUTER WON,T YURN ON
first of all,is your power cable properly connected to your system unit.if it is not,connect it properly and turn the system unit on again
secondly,make sure your signal cable from the monitor to the system unit is properly connected
after following these instructions,reboot your computer again.
thank you for consulting fixya with your problems
Feb 14, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
My monitor will either stay on and wont' turn off (even if you click the green button)
your Mnotitor Panel Switches gone bad replace all the switches and your monitor will be ok.
Ashok
Jun 08, 2007 | HP Compaq FP5315 15" LCD Monitor
Foxconn 6150BK8MC-KRSH Motherboard Logo
90 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
