Question about Aloha Housewares (93645) Ceiling Fan
79757 lights I purchased 7 ceiling fans. Each ceiling fan has 4 lights on it. On 3 of the 7, there is one light that doesnt work at all. I have tried replacing light bulbs and that is not the problem. I still dont have lights. I dont know what else could be wrong with it. Please help!!
    Problem Solver:
  • 6 Answers
If anyone needs switches for ceiling fans that are hard to find, I can help. I have a source for them, nascarnbroncosfans@msn.com
Posted on Jan 07, 2013
    Novelist:
  • 145 Answers
It might not be the bulb but the socket (If you have incandescent sockets). Inside each socket there is a piece of metal that the bulb connects with. Check to see if it is flattened out. Turn the power off then get a flat head screwdriver and pry that piece of metal back outward. Turn the power back on and screw the bulb in slowly till the bulb lights.
Posted on Apr 28, 2010
Where can I purchase a Jin you e70469 ceiling fan switch.
ebay 14 bucks
Jin You E70469 Pull Chain Switch for 3 Speed Ceiling Fan 4 Wire 1 2 ...
https://www.ebay.com > ... > Lighting Parts & Accessories
item 2 ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire -ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire. ... item 3 OEM ZING EAR ZE-208S 3 SPEED CEILING FAN PULL CHAIN CONTROL SWITCH E-89885 DR73 -OEM ZING EAR ZE-208S 3 ...
Exhaust Ceiling Fan Switch 2 Speed Pull Chain Blower Jin You ...
https://www.ebay.com/itm/...Ceiling-Fan-Switch...Jin-You-E70469...-/132376583704 Replaces Jin You E70469, Santa, Gardner Bender GSW-33. The control module provides two speed setting for your fan. 2 Speed Pull Chain Switch. 3" (7mm) Brass Chain. Spark Electric Components LLC. Width 11/16" (18mm). ' eBay!
Jin you e70469 ceiling fan switch Google Search
Dec 12, 2017 | Dryers
Model 93645 ceiling fan. Where can I get lamp 79757 for replacement?
I don't recognize those numbers. What it the make of fan?
Jan 28, 2016 | Dryers
My ceiling fan with light is not working properly the light comes on but the fan doesnt
Sounds like it is possibly a wire came loose. There are usually 2 wires that connect to the black wire (hot lead) in the ceiling. One is black, the other blue (for the light) If this is not the case, there are other electrical 'glitches' that can cause the problem, and the fan needs to be replaced.
Jul 03, 2014 | Minka Aire Ceiling Fan
I have a harbor breeze ceiling fan on a dimmer
You have 3 options. You can connect the fan blue and the fan black to the red ceiling wire. Then you will need to control the fan and light with the strings. The wall switch will turn off everything. Option 2 is make sure that there is a switch wired to the black ceiling wire. If there is a switch I would check to make sure the switch is working. Option 3 is to purchase a remote control unit for both and leave the wall switch to shutoff the whole unit. Hope this helps.
Oct 11, 2013 | Speed Ceiling Fan 3-speed Switch By...
Hunter ceiling fan model 23530-300
the roll was rusted maybe .you can take apart it for checking .
ceiling light
May 01, 2012 | Hunter Ceiling Fan Remote Receiver...
I have 21 ceiling fans in my house.
Three suggestions (maybe not viable solutions):
1. Consider creating ceiling fan "groups". A group is a set of fans that is controlled by one remote.
Group: All (or some) in all vaulted ceilings.
Group: All hallways
Group: Outdoor celing fans
2.
Power OFF ceiling fans at the wall switch that are not used often. Those can have duplicate codes.
3.
If the remote controls are iR (infrared) rather than RF (Radio frequency), then the ceiling fans that are farthest apart or have more solid walls in between, can have the same codes and not be affected by the "wrong" remote.
Oct 01, 2009 | Sea Gull Lighting 1555-734 Three-Light...
Fan & lights doesnt work
If you can find the exact fan at Home Depot, purchase it and return the lemon that you have. I cannot find a hampton bay website. Home Depot apparently buys these directly from overseas manufacturers, so there is no "company" to contact for real support. I had no luck finding my capacitor C61 E185116. Stick with the big names like Hunter in the future. Believe it or not, I received a free trim ring for mine about five years after purchase because it kept falling onto the body. Now that is world-class support!
Jul 16, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Aloha Housewares (93645) Ceiling Fan Logo
208 people viewed this question
Top Aloha Housewares Dryers Experts
Steve
Cesar Quant
Cesar Quant
Craig Butler
Craig Butler
Are you an Aloha Housewares Dryer Expert? Answer questions, earn points and help others
