Car audio need caddy wiring diagram for a 95 deville concorse
  • 40 Answers
Zeus_s007- This is a pretty technical,request so i hope you understand my instructions. I hope the harness plug is present,this makes it easier.First of all i'll give you the wire colors,there are a couple the same color and we will start there.
tan-left front speaker-positive
gray-left front speaker-negative
light green-right front speaker-pos.
dark green-right front sreaker-neg.
brown-left rear speaker-pos.
yellow-left rear speaker-neg.
dark blue-right rear speaker-pos.
light blue-right rear speaker-neg.
orange-12volt constant-memory
black-ground
yellow- 12volt key switched-may be bigger than yellow speaker wire-we can check the wires,will explain later.
gray - dash dimmer
brown-dash dimmer
You don't need the last 2 mentioned,any others left over not needed.
The safest way to check the 2 brown,grey,and yellow is to use a AA battery, as a speaker tester.You take the colored wires for the speakers and touch the AA battery to them. For example you know the 2blue ones are right rear wires-so take the AA battery and touch one blue to the one end of the AA battery and the other end to the other blue wire, you will hear static on that speaker.This will let you know the 2 proper wires for the speaker,no static -wrong wire.you only have to do this for the grey,brown,and yellow wires.Well I hope I don't confuse you,if your not sure,let me know.Good luck, happy wiring.
cooltek Mar,5/08
Posted on Mar 05, 2008
1999 cadilac deville cooling fan wiring diagram
There are a couple of diagrams and a good discussion of this at this link: http://www.2carpros.com/questions/1999-cadillac-deville-cooling-fans-relays - Read in particular the info from expert "FactoryJack" about the 3rd comment down. Good luck!
Apr 26, 2014 | 1A Auto Parts 1999 Cadillac Deville Sedan...
Interior fuse box diagram
Why not try searching a Caddy dealership site and look for a '95 Deville manual online....? I have done that and always found the manuals I needed.good luck.Lori
Dec 19, 2012 | 1995 Cadillac DeVille
How do you get to the door speekers and the automatic door lock on a 95 caddi sedan deville need to fix the door lokc a nd speekers
You probably could but your gonna spend ALOT of money,what I would do is un install the cd player and check the wires.Undo everything you did back to the way it was before. Sounds to me like you have crossed wired or grounded something. If this fixes your problem take it to a car stereo place that installs radios and pay them to install your CD player.
Oct 05, 2012 | 1995 Cadillac DeVille
I need a wiring diagram for a 1960 caddy windsheild wipers
Here is the link to your 60' caddy wiring diagram.
http://www.auto-wiring-diagram.com/wp-content/uploads/2011/08/wiring-diagrams-of-1960-cadillac-all-series-part-2-e1313734688375.jpg
Jun 20, 2012 | Cadillac DeVille Cars & Trucks
3.8 amp draw on battery with ign switch off. Something in the 60 amp body fuse circuit. I need a schematic. 95 cad deville. Am questioning the capacitor across the brake switch.
go to autozone.com. register and enter your car. there are free repair guides available along with wiring diagrams. you might have to search under chassis electrical for wiring diagrams or they could be listed separately
Apr 17, 2010 | 1995 Cadillac DeVille
Firing diagram for 1990 caddy sedan deville front wheel 4.5?
To avoid confusion, remove and tag the spark plug wires one at a time, for replacement.
If a distributor is not keyed for installation with only one orientation, it could have been removed previously and rewired. The resultant wiring would hold the correct firing order, but could change the relative placement of the plug towers in relation to the engine. For this reason it is imperative that you label all wires before disconnecting any of them. Also, before removal, compare the current wiring with the accompanying illustrations. If the current wiring does not match, make notes in your book to reflect how your engine is wired.
4.5L and 4.9L EnginesEngine Firing Order: 1-8-4-3-6-5-7-2 Distributor Rotation: Counterclockwise
Hope helped with this (remember rated this help) Good luck.
Nov 10, 2009 | 1990 Cadillac SeVille
I need the stereo wiring diagram on a 2001 cadillac deville
2001 Cadillac Deville Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Oct 13, 2009 | 2001 Cadillac DeVille
No blower/fan at any time car running or not.
check fuse. if ok. replace blower motor.
Feb 24, 2009 | 1995 Cadillac DeVille
95 caddy heating and cooling preoblem
If you have no heat it could be cause by an air pocket in the cooling system and the bubbling sound could be the antifreeze boiling
Jan 12, 2009 | 1995 Cadillac DeVille
81 people viewed this question
 Grubhead
Grubhead
