Question about Canon PIXMA MP750 All-In-One InkJet Printer
Copying Stuck on LTR FINE, PHOTO PRO. Can't get back to regular copying. Don't want to copy everything in this mode. Any suggestions? VIK
    Problem Solver:
  • 6 Answers
Maybe you pushed the small button on the left "two sided"...I did and got the same reading...I pushed it again to return. I think that is what happened...
Posted on Apr 20, 2008
  • Thrivalista Jul 28, 2011
    Press the "Image Quality" button on the left, then the "-" (minus) or "<" (left) button below and to the left of the Menu button. This returned my printer's mode from Fine to Normal.
    Sorry I don't have a solution for the "Photo Pro" mode problem, but you might also be able to address that through a combination of the Exposure and Menu buttons.
I have a LG's MP3 with 1Gb memory. I don't know which model is but i have a S/N number> 683RUKC25133. I don't charge them for a time and its show the disc is full. I format disc and now they...
Hi njupadzija99
Thank you for your question at Fixya,
The solution to your problem is as follows :-
  1. Please ensure that you copy the MP3 Files back to your device after you format it.
  2. When you are done copying the files, restart the MP3 Player and check if the files are being read.
  3. If the files are not being read , then connect your Mp3 player to your computer and change the format mode while you format the device and then again load the mp3 files and then restart the player to check if the files are detected.
  4. To clarify , if you formatted your device using a NTSC format earlier , check formatting it in the fat32 mode and see if it works find after copying the files to the player.
Hope that helps ...:) In case you have any queries, feel free to contact me.
Sep 15, 2011 | LG Audio Players & Recorders
How do you enlarge on the HP309A SERIES
  1. Use the following guidelines to determine which setting to choose:
    • Copying an original to letter or A4 paper : Choose Fit to Page , or choose Full Page 91% to prevent unwanted cropping.
    • Copying a legal-size document to letter paper : Choose Legal > Ltr 72% .
    • Copying a photo to full-size paper : Choose Fill Entire Page .
    • Copying to a custom size : Choose Custom 100% , use the Up or Down arrow buttons (c01314741.gif ) to reduce or enlarge the size of the copy, and then press OK .
  2. On the LCD screen, choose Copy from the options (use the arrow buttons) and press OK .
  3. Press the Settings button (the button below the Home button) twice, to access the Copy Settings menu.
  4. Select Size and press OK to access the copy size options.
  5. In the Copy menu, use the arrow buttons to select the appropriate size settings. Press OK to continue.
  6. Press Start Copy Color or Start Copy Black .
Mar 05, 2011 | HP Photosmart Premium C309A All-In-One...
Printer paper jam
Do a printer check by copying on standalone. means placing a document inside the scanner. Load 10 sheets of regular paper into the feeder then press the start button to begin copying. Try 2 copies. If it gives you the same error, then there is already an issue with the gear inside the printer.
If your unit is not under warranty anymore, log on to support.epson.com. Click on help me find a service center to the right of the page. You will have to put in your zip code to find an epson certified servicer near to your area.
If your unit is not a year old yet, please call epson technical support.
If it copied successfully, it could be just the paper settings, or the type of paper that you are using is not supported or you might have to uninstall and re-install drivers.
May 06, 2009 | Epson Stylus RX580 InkJet Photo Printer
The printer is stuck in fine (photo print) mode - how do I get it back to normal tex printing?
go here for instructions:
http://www.canon.ca/product_reg.asp?lng=en&pid=315&pname=PIXMA+MP750&pr=0&shlink=http%3A%2F%2Fcanoncanada.custhelp.com%2Fcgi-bin%2Fcanoncanada.cfg%2Fphp%2Fenduser%2Fstd_alp.php%3Fp_li%3D%26p_page%3D1%26p_prods%3D15%2C288%26p_pv%3D2.288%26p_cats%3D0%26p_search_text%3D%26p_new_search%3D1%26p_search_type%3Ddflt%26p_sort_by%3Ddflt
Oct 14, 2008 | Canon PIXMA MP750 All-In-One InkJet...
Can't get back to regular copying mode from another setting
Good Evening Smarum:
For Canon printers and all printers, the perferences or changes that you need to make can be done by selecting the printer icon located in your control panel.
Once you've located the printer icon in your control panel, right click on the defaulted printer. (Indicated with a check mark.). A menu will appear. Then, by selecting Perferences and hitting Defaults and Apply, you should be able to take the printer back to it's original settings. If not, view the setting under the Effects tab and uncheck the pro selection.
If I can be of further assistance, please let me know.
And, remember, always include the type of Operating System when you submit your questions.
Have a wonderful evening.
Sep 30, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Macbook cdrom stuck in copy mode
hold down power button until your machine shuts off. then power back on. you should be fine. if the cd is stuck in the drive, restart the machine and hold down the mouse button while restarting - the cd should eject itself.
Sep 02, 2008 | Apple MacBook PC Notebook
Resetting to "normal" print
I am guessing that you do not have the Manual.
Try this site for a Manual:
http://support-au.canon.com.au/EN/search?canonsearch=1&lang=EN&category=All-in-One+Printers&series=All-in-One+Printers&model=PIXMA+MP780&menu=Manual
It should have the instructions you need.
Have you tried the Printers Help pages?
Good luck.
Apr 03, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Can't change image quality
The problem is that only "fine photo pro" is available when the paper selected is photo paper. Change source to the sheet feeder, hit the "Paper" button and then select normal paper. You'll then be able to change the quality to normal.
Sep 22, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon pixma mp780 Copying mode very slow
is this using it on its own[Stand alone mode] or through the computer?
May 13, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP750 All-In-One InkJet Printer Logo
74 people viewed this question
old marine
old marine
