I need to rredownload my system mechanic 7, can you help?
    Problem Solver:
  • 7 Answers
Hi!
I understand that you had System Mechanic 7 installed on your computer, but it has since been uninstalled or deleted, correct? Did you have the standard version or the professional version?
Either way, the site to re-download your System Mechanic software is located here:
http://www.iolo.com/customercare/kbarticle.aspx?id=KBA-01366
This site allows you to download any of their programs free of charge. However, you will still need your licensing information to reactivate the software. If you don't know your licensing information and need to find out what it is, go to this website and enter your email:
http://www.iolo.com/customercare/licensinginfo.aspx
If you did not register your email with Iolo or if your computer came with System Mechanic preinstalled, you will need to provide Iolo with some proof of purchase in order to obtain licensing information for your software.
Hope I helped!
~Kiro
Posted on Mar 05, 2008
I have a 03 Yamaha r1 that hesitates on acceleration, besides that runs great?
Hi, Shawn and the usual suspects are:
1. Throttle cables misaligned or misrouted.
2. Damaged or restricted fuel tank venting system.
3. Intake system air leak.
4. Vacuum piston malfunction.
5. Pinholes or torn diaphragm.
6. Accelerator pump leaking or no output.
7. Plugged bowl vent or overflow.
8. Fuel level in bowl too low.
9. Restricted fuel supply passages.
10. Plugged jets or passages.
11. Worn or damaged needle or needle jet.
12. The enrichner valve not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r1-forum.com/forums/4-mechanical-help/315996-2001-r1-hesitation.html
Experiencing some hesitation misfiring and partial throttle need advice
http://www.r6-forum.com/forums/57-garage-mechanical-help/146381-low-rpm-hesitation-acceleration-problem.html
http://www.journey.cz/moto/navody/Yamaha%20YZF-R1%2002%20Service%20Manual.pdf
Aug 15, 2016 | Yamaha Motorcycles
I just installed an update to my System Mechanic program and now when I try to open the program a window appears telling me i must restart my computer to fininsh the update. I have restarted twice and the...
You may do the update once more and see if you are getting the same message. If so, start the computer in the safe mode and disable automatic updates and restart
Any doubts you can get the help of a certified technician through the website:
www.thebestpcdoctor.com
Toll Free: 877 407 9229
Aug 21, 2011 | Iolo Technologies System Mechanic: Windows
Wen i turn on the Pontiac it runs good for like 7 seconds and thin it turns off i don't know why it dose that i need help?
Get a full systems check, it's probably a bad fuel pump. which means your engine isn't sucking in enough fuel to keep it continuously running, you probably have alot of build up as well, try system cleanser, put it in a full tank of gas and see if it can stay running long enough to remove some build up. Otherwise you have to go to a mechanic.
hope it helps
Nov 20, 2010 | 1996 Pontiac Grand Am
Cannot install on windows 7 pc
http://www.microsoft.com/windows/compatibility/windows-7/en-us/Search.aspx?type=Software&s=System%20Mechanic
Oct 23, 2010 | Iolo Technologies System Mechanic: Windows
Trying to install belkin wireless for windows 7 and its saying missing shortcut. How can i fix that?
You need iolo system mechanic(not the one with antivirus) just system mechanic from iolo.com.If this fails to fix your missing shortcut,try "tuneup utilities".You can get this at pc world or staples or office supply units.
Aug 09, 2010 | Belkin N1 Wireless USB 2.0 Network Adapter...
Installed system mechanic premium on computer with xp upgrated to windows 7 can not reinstall product
Windows 7 cannot be installed with an existing Operating system already installed it will cause this issue.
Windows 7 needs a clean formatted hard drive to be installed. The system also needs to be compatible with Windows 7.
Apr 01, 2010 | Iolo Technologies System Mechanic: Windows
I have a simple question.
System Mechanic 8 is compatible with Windows 7, Vista, XP and 2000. I am sorry to inform you that it is not compatible with Windows 98.
If you go to the page below and look under purchase now, you will see a windows logo and a list of all versions of windows System Mechanic is compatible with.
http://www.iolo.com/system-mechanic/standard/
Jun 19, 2009 | RTO IOLO System Mechanic Pro 08 Full...
I want to remove system Mechanic completely from my computer
Here is a solution. Be careful of using this
1. Open Registry Editor
2. Backup the registry by exporting it as a file.
3. Select HKey_Local_Machine
4 Search for instances of the string "Mechanic"
5. Delete the entry. Be careful. It should be pertaining to "System Mechanic".
6. Close Registry Editor
7. Open Windows Explorer and Search for "System Mechanic" and delete the same. It could be a folder.
That's it.
Apr 09, 2009 | Iolo Technologies System Mechanic: Windows
Cannot uninstall ''IOLO system mechanic pro 7''
   sounds awkward I would try burning all your important files to CDs or DVDs to keep them safe and then rolling back changes using system restore- start - all programs-- accessories -- system tools - system restore
from there hopefully you can restore your p.c. to a time before you installed all these programs you wish to remove. Alternatively if you have your Windows install disc (probably not) but if you do then you can install windows again and put your files but from CD/DVD storage. Alternatively you might have a "restore disc" which does a similar state and will restore your laptop to how you bought it.
However I van only advice these "solutions" when you get really desperate, starting over it may take days to get your system how it was before. 1st I would try "system restore" as not all of your documents are affected and you can easily undo the changes you make.
GOOD LUCK xD
Nov 17, 2008 | Microsoft Windows XP Professional
Sys Mechanic-7 Poor operation
system mechanic 7 is a heavy application. it uses lot of system resources ...ensure u have atleast 512 mb of RAM in your system and you do not use any other program while using system mechanic
Mar 08, 2008 | Computers & Internet
Computers & Internet Logo
146 people viewed this question
David Payne
David Payne
