Question about Hitachi 43UWX10B 43" Rear Projection Television
Takes hours to turn on & when it does turn on it does not switch over to video 1 vidio 2 it shows the same picture in every channel
  • 1234 jonjon Mar 04, 2008
    problem not solved yet
  • 1234 jonjon Mar 05, 2008
    changed convergence ic's
    Sergeant:
  • 261 Answers
Sorry jonjon, i think we got disconnected. Is your problem resolved yet? I think it could possibly be convergence ic's that are bad or at least have cold solder joints or fractured solder connections...I hope this helps you out. Thanks...Jay
Posted on Mar 04, 2008
  • Jay Henderson
    Jay Henderson Mar 05, 2008
    Sorry if we got cutoff, my computer crashed...Good ol windows. Gotta love it. Let me know if you need more help and we can continue...Thank you Jay
Why is my Remote showing relay fault
315Mhz remote relay switch kits - 2 channels - Seeed Studio
www.seeedstudio.com/.../315Mhz-remote-relay-switch-kits-2-channels-p...
This remote switch allows you to remotely control any 12 Volt DC device. ... to supply 3-5VDC to the "+12V" pin,(Caution: the 12v is an error silk screen on PCB, ... Is there a wiring diagram to show how you connect the sender to the GPIO pins?
Amazon.com: 1 Channel Wireless Controller (On/Off) 12V ...
www.amazon.com > ... > Lighting Accessories
Amazon.com, Inc.I wired this remote relay to a fuse block below the motorhome frame. ... Here's a (very) short video showing how the remote control works. I love it! It's very easy to ...
12v wireless 315 MHz remote control relay board 6-channel ...
? 4:36
https://www.youtube.com/watch?v=JBzL0MIno2w
Feb 2, 2013 - Uploaded by Julian Ilett
12v wireless 315 MHz remote control relay board 6-channel ... The relay board takes 12 volts in and there ...
Dec 03, 2015 | Cars & Trucks
How to change the channel my Sony Trinitron TV turns on to?
hit menu button on your remote, navigate to channel setup menu. on the sub-menu, set channel fix to your channel that you require. now when your tv powers up this will be the default channel. if this doesn't fix your issue then try cycling through video inputs tv/video button on your remote.
Nov 10, 2013 | Sony FD Trinitron WEGA KV-24FS120 24" TV
My screen on my nes is blurry how can i fix that
If your screen shows a blurry image it can be a few possible things (and only these things).
1. The first and most obivous problem is being on the wrong channel - for example, if you are on Channel 3, but the switch on the back of your system is set to channel 4, you'll see a VERY fuzzy picture; simple switch to the other channel and it will come in clear.
2. Now...assuming you are on the correct channel, does your television receive other pictures clearly (for example if you change to a normal broadcasting station and it is still blurry, then it is a problem with your TV and not your NES system). Another way to test is to simply switch TVs and see if the same picture problem occurs.
If 1 and 2 are not the problem, them we know the problem is with your NES system and this should be an easy fix.
If you are using an RF Switch, then it is most likely the pin on either end of the switch has become bent (or was bent and now is bent back) and will no longer give a clear picture. The easiest way to test this is find a set of AV cables (any av cables - these are the red, white, and yellow cables that often hook DVD players to television). Find a set and just take one of those ends and connect it to the side of the NES system into the circle that says VIDEO and take the other end of that same color and put it into your TV into the circle that says VIDEO (note that the colors don't always match up on the newer TVs, just make sure that if you are using the yellow end of the AV cable and plug it into the video on the NES that you plug the other yellow end of the av cable into whatever color on the TV says VIDEO! Then change your tv to the cannel for that AV slot (usually AV 1 or INPUT 1). Turn the nintendo back on and see if the picture comes through clearly - if it does, it means you had a bad RF switch and you can either get a new one, or just use AV cables instead!
One of the above problems IS the problem - I've repaired over 1000 NES systems and 95% of the time it's just a bad RF switch (so the AV cable test works best)
Jan 14, 2010 | Nintendo NES Console
My Sony Trinitron only turn on when After 5 and up hours..
1. Your TV has a weak picture tube, the beam current detection circuit muted the video, you may rejuvenate the CRT, or turn up screen control (located on the fly back transformer) a little it may help.
2. Other thing is that to check out is there any dry-out electrolytic capacitors in the main power supply circuit.
Jan 15, 2018 | Sony Televison & Video
Shows canceled?
Make sure u have signal on both tuners on the DVR ( check it in your set-up screen). both tuners should have the same siganl strength. Directv's DVRs, if installed correctly, give u the option of recording one channel and watch another, or recording 2 seperate channels( 2 tuners). If you are recording 2 seperate shows and u change the channel one of your recordings will cancel .
Sep 13, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
I have problem
i have the same.
no video, i only hear the sound.
during scan, active channels are detected.
need help.
Apr 25, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Hitachi 43UWX10B 43" Rear Projection Television Logo
19 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
