Question about Akai PTH5498 54" Rear Projection HDTV-Ready Television
Akai PTH5498 I am having trouble with the TV, the red light in the front stays on and now the TV wont power up at all. I have left it unplugged hoping to reset it. But nothing works. Never had a problem before this. Can anyone help??????
  • 53 Answers
A lot of people on this site have this problem, including me. Usually a problem in the convergence board, requiring fixing (not expensive, really) or replacement (about $80 DIY). In my case it was a coolant leak.
Posted on Mar 19, 2008
AKAI model PTH5498 turned it on in morning and it worked fine, then went to kitchen then heard a pop then a buzzing noise tv had no picture
Short on the power and deflection boards---with set unplugged take a careful look inside for burnt or blackened parts etc.
May 17, 2012 | Akai PTH5498 54" Rear Projection...
I have a pth5498 when u plug it in tv doesn't come on just makes clicking noise no tubes light up or anything just sound and front power light....
There could be many items that can cause that symptom. However I always assume convergence on any rear projection which can easily be checked by unplugging the convergence amp board and then plugging in the set and press power , if the set powers up turn it back off, and you will know the convergence ICs and associated resistors on that board have failed. Although its easier to replace the board unless you have good soldering skills. I am pasting a pic of the board which is suspended above the main chassis just mark the wires then unplug the set from the wall first, but then unplug the wires from that board and then try powering up the set.if you need further assistance , respond to this same post slinteriors_21.jpg
Aug 12, 2011 | Akai PTH5498 54" Rear Projection...
Tv died and wont turn back on
check all connections on the unit. check the power outlet and power cord.
unplug for a while the tv and put it back again on a differentg outlet.
hope this initial info will help.
Nov 05, 2008 | Akai LCT2715 27 in. LCD Television
Akai tv
The power supply most likely failed on your LCD.
How old is your LCD?
Jul 26, 2008 | Akai LCT3201TD 32 in. LCD Television
Akai PT5492 54"
HELLO IT SOUNDS LIKE YOU HAVE A BAD FLY TRANSFORMER. . THAT NEEDS TO REPLACED. "GOOD LUCK"
Jul 22, 2008 | Akai PTH5498 54" Rear Projection...
Akaia PTH5498
The STKs are common and if you have an experienced electronics tech around they can replace them for much less money but the tech must have advanced soldering and IC exchange experience.
The STK ics, two of them, can be purchased on line for around $20 to $40 each.
http://www.partstore.com/GetModel.aspx?MfgName=Toshiba&BrandName=Toshiba&ModelNu...
Partstore has two models available - one for around $40 and another for around $55.
The part number is STK392-110 and if you google you can find them for as little as $6/each but I don't recommend the cheap ones as they are not reliable.
It takes a good tech around 3 or 3 hours to take the old ones out and solder in the new ones. Also, it is likely one or two resistors are burnt and will need replacing as well.
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 27, 2007 | Akai PTH5498 54" Rear Projection...
TV will not turn on...
Convergence board failure. $300 repair
Sep 19, 2007 | Akai PTH5498 54" Rear Projection...
Timer continuously on.....tv won't turn on
I had a simliar problem and just left teh set plugged in overnight and the next afternoon I noticed that teh remote red LED was not on anymore and tehn when I used the remote the set turned on!
Aug 28, 2007 | Akai PTH5498 54" Rear Projection...
Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
133 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
