Question about Vacuums
Hi i have a miele
Hi
i have a miele s183..and would like to change the belt..i did it but now it makes a loud noise..is there a way for me to see how can i change the belt..is it normal for the belt to get hot after 30 seconds of running..
thank you in advance for your support...
saviz
    President:
  • 1,673 Answers
Sounds like you have a bad brush roll, it may not be turning freely. If the belt is getting hot means that it is slipping, so check the brush roll.
Posted on Mar 06, 2008
Changed belt on my eureka airspeed sweeper n since makes loud noise, really loud n vibrates
Sonja, Recheck belt installation, see if it is riding in proper groove or is twisted.
Press the helpful button and follow me on fixya for more tips and info.
Feb 11, 2016 | Eureka Vacuums
How do I stop Eureka Pet Express from making loud noise?
does it make the noise with belt disconected if not its the brush . it could be installed wrong check it.
Dec 03, 2014 | Eureka Pet Expert Vacuum Cleaner in Mystic...
Loud noise ,hot air and poor suction in Miele vacuum cleaner
Hello, this is Ava with Think Crucial.
To make your Miele work properly, a general maintenance will do the trick. Most of the time cleaning the filters, checking for blockages and clearing the passageways will eliminate the noise. Please refer to your User's Manual on how you can do this.
You can purchase a wide variety of high quality Miele replacement parts for your Miele Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=miele
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 11, 2013 | Miele Vacuums
How to take apart to replace power cord
In order to access the cord on the Miele S183 upright, you'll need to first remove the handle from the vacuum cleaner. There is a large screw that holds the handle in place that is located under neath of the lower cord wrap hook. Simply remove this screw, and slide the off the vacuum by pushing the handle towards the back of the machine.
Once you have the handle removed, now ope the bag door as if you were going to replace the vacuum bag. You'll see two screws directly above where the bag fits inside of the machine. These two screws will open up the switch and cord housing and give you access to the electrical cord.
You'll see that there are two screws that secure the cord as it comes into the vacuum from the back. Remove both of these screws so that the cord is no longer secured. I think the easiest way to replace this cord is to simply cut the cord (MAKE SURE THE VACUUM IS UNPLUGGED) so that there is about 4-5 inches of the cord jacket (rubber coating around the cord) remaining. You may now just pull this cord jacket off of the cord, along with the paper insulation so you have two bare wires of the old cord. Now take your new cord and push it into the back of the vacuum so that it comes through the switch housing. Instead of having to re-secure the cord with the two screws, I've found that if you tie a small knot in the cord, this works just as well at preventing the cord from pulling through the back of the vacuum.
Simply strip the wires that are left from the old cord, and simply wire nut the new cord after tying a knot (or re-securing it with the two screws), and reassemble the vacuum cleaner. Test the vacuum only after putting the switch housing cover back into place.
If you have any questions about how to do this repair, please feel free to use the clarification request form here on the Fixya repair page. If you found this helpful, please be so kind as to rate my repair as helpful by clicking on the 4 thumbs up icons in the top right hand corner of the repair. This is what keep Fixya's repair professionals continue leaving free repair advice on this site.
Here's a link to a blown up parts diagram to help you visualize how the vacuum comes apart.
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/miele-s183-upright-parts-diagram.gif
Feel free to check out our website for any Miele supplies that you need:
Miele Vacuum Bags, Filters & Belts
Thanks again for rating my repair,
Chris J.
GoVacuum
Apr 07, 2010 | Miele S183 Powerhouse Bagged Upright...
My Miele capricorn has started making an odd noise. It seems like something is blocking the engine. I've turned if off and on, and reset it and it still have the odd, almost loud barking noise. The power...
Greetings,
This is a major problem. The Miele vacuums motor should never make a loud noise, period. The way the motor is designed, it's quiet and should be quiet for the life of the motor. There are two motors on your Miele canister. One of the motors controls only the suction of the vacuum, while the other motor controls the power brush. Which one of your motors is making this horrible noise? You can tell this by removing the wands and power brush so that you just have the handle of the hose by itself. Now turn on the vacuum, do you still hear this noise? If yes, then this is a problem with your suction motor, and you need to bring this in to have an authorized Miele repair center take a look at it. The reason I say that is because you have a 7 year warranty on that suction motor, so if something is wrong with that motor, then this will be covered under Miele warranty. If it's the power brush motor that's causing the sound, this probably will not be covered unless the vacuum is under 1 year old. If it is the power brush, please just use the clarificaiton request here on Fixya and let me know, I'd be more then happy to try and walk you through diagnosing the power brush motor with you.
I hope this was helpful to you. If you did find this helpful, please be sure to click the thumbs up icon in the repair. I really appreciate it.
Chris J.
Mar 21, 2010 | Vacuums
Makes a loud noise like a grinding noise then smokes comes out and it smells like burning rubber? When I take the (rod) brush off with the belt then run the vacuum there is no more noise? Please help me...
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Nov 30, 2009 | Vacuums
Has started making a rhythmic noise, not too loud. Maybe a belt?
Excellent question and description.
Generally a belt with a broken tooth will rattle like a machine gun if defective. Simply lay the had upside down. You can also inspect for hair and thread wrapped around the end of the brush roll. If you remove the belt turn it inside out to roll between your fingers for inspection. Look for signs of fraying or cracking. be sure to check your tension when reinstalling, there should be a bit of slack but not enough to let the belt slip if you were to jam the brush with a hand or old sock
Nov 04, 2009 | Miele S334i Vacuum
Dyson Makes a loud noise like something is impeding the
I would try changing the belt. Even though the belt may look fine it can be stretched or worn and that can cause loud noises. You can get dyson belts here:
http://www.vacbelts.com/dyson.htm
Oct 28, 2009 | Dyson Vacuums
CHANGING THE BELT
Did you check the brush roll, the ends maybe aren't turning freely. May have to replace it, (Part # R98Z6064) I assume you put the correct belt on it (Part #S01Z6000). Are the sides ok where the brush roll sits in?
Mar 04, 2008 | Vacuums
Vacuums Logo
114 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
