Question about Toshiba Tecra M1 PC Laptops
Built in HDD pasword
I have toshiba tecra m1 and when i want to start it it can not start windows it shows a mesage HDD pasword before this mesage apears the hdd started to make a noise and when i restarted it the os asked me how do i want to start the windows (normal, last good configuration etc...) i choosed normal and it take a long time to start it so i restarted and the mesega came out ( built in HDD pasword)
  • 5 more comments
  • Darko Jovanovski Mar 04, 2008
    ok now what
    ok now what
    ok im there now it wants me to insert sistem disk in drive (press any key when ready)
    i put the cd on and its the same thing media test failure check cable insert sistem disc in drive
    you didnt tell me if i need to return hdd back because i was in bios i made what u told me and its the same thing same masege i wrote u
    ok my mistake now its ok the setup started can we write on a mesenger so it go faster
    i returned the hdd back and the same problem it wants a hdd pasword cant go in bios
I had same problem, is the hard disk...buy new one and end of the problem.
Posted on Sep 06, 2012
    Genius:
  • 1,019 Answers
i reckon i can help you sort this Problem Out.
I,ll give it My best Shot.
The First Thing To do Is To turn off the power, and remove the battery.
Then Remove the Hard-Drive, Should Be In A Drive-Bay Underneath.
Posted on Mar 04, 2008
  • 7 more comments
  • Mike Waldron Mar 04, 2008
    Ok,
    so now you have the hard-drive out yes.
    Put The Battery Back On, Plug In Mains Charger.
    Leave Hard-Drive out.
    Then Boot/Start The Laptop And Push F2 Key while Starting Up, This Will Take You To the bios Screen.
    Let Me Know, if you get there Ok.
    Mike.
    Ok,
    put windows xp disk or operating system didk in cd/dvd drive.
    I,m having a look for you now for the simple bootup keys.
    this is usually done with the disk i have, so i,m trying to work other ways round for you.
    Mike.
    Ok,
    heres what you need to do.
    you have to enter the bios screen, as soon as you power on push F2 Or fn/F2 And enter Bios Setup.
    Then when you get into Bios. You have to tell the Computer to Boot first From The CD Or Floppy Disk Drive.
    No Problem,
    Sorry turn off, put hard-drive back in, and restart with windows disk in drive.
    If you,re into the Bios we,ve got a great chance.
    Mike.
    I don,t have messenger setup, You Can e-mail me @ mickwaldron605@hotmail.com
    Mike.
  • Mike Waldron Mar 05, 2008
    No Problem,
    I have a way to work around This.
    I,ll e-mail you regarding the final proceedure.
    Mike @ Compurepair.
How to disable the tecra m1 power saver feature
Go into the control panel and select add and remove and look for the Toshiba Power saver utility and click remove. If you are running windows 7 go to my computer and select uninstall at top.
Jun 08, 2012 | Toshiba Tecra M1 PC Laptops
Toshiba Tecra M1 what are hdd format procedure?
Formatting a laptop is the same as doing it on a desktop computer.
If you are using the Windows installation CD then to get the laptop to boot up with the Windows CD you can change the BIOS boot startup device and make the CD the first boot device.
Apr 24, 2012 | Toshiba Tecra M1 PC Laptops
Is it possible that a cdrw/dvd of Toshiba Tecra M1 be replaced with a dvdrw?
Yes, it is possible to replace CD, DVD with DVD+RW on Tecra M1. Generally, it is possible to upgrade optical drive on almost all the laptops.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 27, 2011 | Toshiba Tecra M1 Notebook
Network adapter does not work after installing new HDD
Here is the link from where you can download your Network Adapter driver.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Product%20Support
1. Choose Category : Laptops
2. Choose Family    : Tecra
3. Choose Model : M1
it will land you to the driver download page.
Just select the Operating System and download the Network Adapter driver and get it install.
Your Network card should work now.
Jan 26, 2010 | Toshiba Tecra M1 Notebook
Toshiba Tecra M1 HDD failure
no you just put new hdd and run recovery
Dec 15, 2009 | Toshiba Tecra M1 PC Laptops
Ethernet controller driver&wireless driver for tecra m1 notebook
you install internet explore or install new operating system you chak you lan show ip address
Jan 27, 2009 | Toshiba Tecra M1 PC Laptops
BIOS is not appearing in Toshiba tecra laptop M1
You can enter BIOS by holding down F2 after power on. Hope this helps.
Oct 05, 2008 | Toshiba Tecra M1 PC Laptops
Answer to your question
You will need to get into the bios, and set the CD drive to boot before the hard drive. Since your in this uncompromising loop, remove the hard drive, then start the machine. It should go to the initial Toshiba screen and you will see the prompt on what to press to get to the bios, or utility set up. Once your in the bios, find the boot order and set the CD drive over the hdd. Then put the hdd back in, the recovery or operating system disc in the CD drive, and start the machine. It should now boot from the disc. At this point you will want to do a system repair. If the repair doesn't take, then reformat the hdd, and install a new operating system. If the hdd will not format or you have any issues during or after the install, then the hdd has failed and will need replaced. If you need any futher aststance, just ask.
Aug 28, 2008 | Toshiba Tecra M1 PC Laptops
HDD pasword
Put the password In.
this Will solve This Problem for You :)
Alternatively Install a new hard-drive and re-install Windows et,c.
Or send the hard-drive to be unlocked Or data recovered.
The only other Option, is To purchase A software tools Disk from me, And you,ll Probably unlock it That way.
mike @ compurepair.
Posted @ 22.49 PM ( G.M.T )
Mar 02, 2008 | Toshiba Tecra M1 PC Laptops
Toshiba Tecra M1 PC Laptops Logo
311 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
