Question about ViewSonic VX924 19" LCD Monitor
VIEWSONIC GT775 PROBLEM
I have a VIEWSONIC GT775 & the background went from white to red.
When I boot up, the background is white but after about 10 minutes it
goes to red.
Is there a way to remedy this or do I need a new monitor?
Thanks
John
email weldonet25@aol.com
  • JOHN951 Mar 08, 2008
    Thanks for reply Paul
    I was thinking this could also be a video
    driver in my HP Pavilion that needs to be looked at rather than replacing the monitor.
    Is this possible?
    John
  • 4,102 Answers
Hi no sorry their is nothing you can do it would cost to much to replace the screen you are better of replacing with a new one not alot of places do this sort of repair as it costs more than a new one this problem is not an eays fix it just costs to much to replace the lcd screen let me know if you need further assistance ok
Posted on Mar 08, 2008
  • paul proctor Mar 08, 2008
    It could be slight chance but more than likely the monitor you could try removing your video card and and putting it back in doing this usually cures any problem with the video card.
    Say if the monitor shorted out then this could cause damage to video card but usually the video card should have no problems unless its in dusty or damp environment.
    try removing all monitor leads then take case of computer then remove video card and refit remember to earth your body before touching video card to stop static damaging the chips.
    Give this a try are you sure the monitor leads are correct because this can cause the screen to display one colour but i assumed you all ready would have done this.
    Try switching the monitor on without the video lead plug into the computer then let me know what happens.
    Are you able to remove the video card yourself?
    Let me know then ill assist you further
Green screen on VGA with Viewsonic PJD5122
VGA is separated analog signals in Red, Blue, and Green. Under normal cases, you'd be able to change the cable, source, or input port and resolve the issue. Unfortunately, if the green tint persists with all input ports on the projector (The two blue ones are Input, the black one is output. There is a potential that attaching input to the black output port could have caused the damage), different sources, and different cables, then it's likely a problem with the projector hardware itself and would require warranty service or otherwise repair or replacement of the projector. If you have an alternate way the projector can be attached, then try that (Such as SVideo), otherwise there may not be any good solution in this case short of checking the guts of the system.
Mar 28, 2014 | ViewSonic Office Equipment & Supplies
No picture.. just white background. when powering up, no options at all... flickering white background to black when disconnected from pc
You need to open it up and inspect the capacitors for bulging top/seal, see pictures here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Post back what you see inside so we can guide you further.
Mar 16, 2010 | ViewSonic VX2235wm LCD Monitor
Screen is white when on.....
Try disconnecting your connection to your computer.
If you see a no signal message with a dark background, you have problems with your video card.
If you continue to recv. the white screen, you have input signal problems with the LCD monitor itself.
If you do recv. a no signal message witha dark background, try removing and reseating the video card.
Oct 24, 2009 | ViewSonic VX2235wm LCD Monitor
How do i, connect or plug in, my Playstation 2 into a viewsonic N2635w. and yes the Viewsonic is a TV.
Standard Audio Video or Component. Input on the back of TV. It should be for all intensive purposes "plug n play" Hope this helps. If you need more help, post a comment and I'll help some more
Jul 07, 2009 | ViewSonic N2635w 26 in. LCD Television
Same problem w yellow on viewsonic pj550
Yellow is the mixture of 100% red and 100% green. what you may have here is a blue LCD failure in the machine. Try this to check. Open up PAINT and double click one of the colors on the bottom. now click add custom color. then in the RGB section put 0 for red 0 for green and 255 for blue. ok out of everything and fill the background w/ the blue. it should be a VERY intense blue, if its white or or kinda blue, you have an LCD issue
Apr 13, 2009 | ViewSonic PJ550 Multimedia Projector
Viewsonic vx924 color problem
One of the background lights may have burned out.
Jan 28, 2018 | ViewSonic VX924 19" LCD Monitor
Wavy red lines or red pixelation, not sure what it is
Go to Vizio website and buy the extending warranty, you need to have your TV replaced since the problem is with the screen itself.
Dec 15, 2008 | Vizio L32 32 in. LCD HDTV
ViewSonic VX924 19" LCD Monitor Logo
81 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
