Toshiba TV with only a horizontal picture?
32 inch toshiba tv. Horizantal picture line only. Think it may be a verticle collapse. Does any one know if something else may cause problem?
    Scholar:
  • 133 Answers
You could have a simple loose connection on the vertical output IC . Sometimes you can tap the board and the picture will fill out . Or the IC could have failed . It will also take out the resistor that supplys the voltage to the vertical IC . If you take it apart to work on be careful as you can be shocked if you don't know what your doing . Most repair shops charge $50 to $80 to repair . Good luck
Posted on Mar 04, 2008
Picture goes to a single horizontal line.
Your problem is due to failure of the vertical scanning circuits in your TV. This is quite common and is caused by aging components. Generally drying out capacitors
You got to be careful not to leave it on too long when the picture collapses, it will burn a permanent line across the screen.
If you are an electronics expert you can fix it if you get a schematic. If not please don't attempt to reapir it yourself since there is high voltage in side the TV.
The problem may get worse with time.
Mar 13, 2010 | Toshiba 32D46 32" TV
My picture turns into a white line and comes back if you hit the front bottom of console?
I think you flyback transformer is going out. Eventually it won't come back when you hit it.
Oct 30, 2009 | Toshiba 32A33 32" TV
Horinzontal white line with sound
vertical collapse. usually not to expensive to fix.
Jun 02, 2009 | Toshiba 32A33 32" TV
No picture no sound
Did you mean the picture is collapsed only in the middle horizontally(white line appears on the middle part of the screen)?
If that is the case, maybe vertical IC failed or loose connection.
Apr 05, 2009 | Toshiba CF32H40 32" TV
CRT TV picture keeps getting horizontal line & loud cracking nois
the horizontal section is near collapse, the lines indicate a sort or leak. Soon, the set will go black. Shut off as repair will be cheaper now! Needs professional repair as High voltage section is dangerous.. Unplug to be safe!
Mar 13, 2009 | Toshiba CF27F30 TV
Toshiba 32" tv wont give sharp picture (other tv does)
try to replace filter capacitor from power supply and in horizontal section.
Jan 26, 2009 | Toshiba 36A50 36" TV
TV Toshiba CF32G50
I think you have a vertical problem. Turn up screen voltage to see if there is a tin horizontal line across screen. If so replace vertical output IC and the 100uf/35v capacitor in the vertical circuit.
Oct 31, 2008 | Toshiba CF32G50 32" TV
Toshiba 32A40 32" TV Problem
does any one can send me the schematic of TOSHIBA 32A40? I have a vertical problem and I need to locate the vertical IC or trancistor.
I only see a horizontal line on my Tv.
thanks.
teranco@hotmail.com
Jul 13, 2008 | Toshiba 32A40 32" TV
Toshiba CZ32V51 32" TV
that indication is that the verticle amplifier is fault,
chec the verticle IC
fusable resistors
capacitors eletrolitic
the problem will be over
May 06, 2008 | Toshiba CZ32V51 32" TV
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
