Question about Kenmore 44102 Front Load Washer
Kenmore 417 Washer - Brown marks
Our front load washer is leaving brown marks (some heavy, some faint)...have read that the culprit is a bearing leaking some lubricant...others claim mildew or build-up...any clue out how to resolve this problem - I will take the machine apart if need be!
  • 3 more comments
  • Washer1 Mar 04, 2008
    Thanks aborcass...have a few more details to share - seems that we use HE detergent at the lowest settings (one)...also, the drum started to make a rumbling noise at the same time the brown streaks started...ugh.
  • Washer1 Mar 05, 2008
    That is affirmative, there is play in the up/down tub area. Scale of 1-10, 10 being the most difficult, what would you rank the rear bearing part repair as...? Thanks for your support!
    THANK YOU! Appreciate your prompt support...very helpful. Have a great evening.
    Washer1 out.
  • Sounder6 Apr 18, 2008
    Same problem. My machine is a 417.40042990 model.
    I have a full load of white towels that seem ruined.... plus I am afraid to wash anything else.
    If it is bearing grease it sounds like a major repair.
  • ed essa Apr 19, 2008
    I have the same problem. For those who think its mildew or that the solution is a certain type of detergent, you need to see it. These are heavy grease streaks caused by something in the machine. I hope someone here has this repaired and can tell me how much it costs to get fixed. I am REALLY disappointed with Kenmore. This shouldn't have happen after 5 years. I have clothes that are ruined.
These machines are terrible. I just had a service person in and he told me that my machine (only six years old) has bearings that are done and they also caused the shocks to go. I went to Sears to talk to the sales person about my Kenmore machine and she said she has never heard of this problem. Meanwhile, friends have also had similar issues - my clothes are ruined and Sears just tried to sell me a replacement machine. I don't know if I will go with another front loader - my parents have had the same washing machine for over 25 years - I guess they are not supposed to last more than 5 or 6 years now.
Posted on Apr 30, 2008
    President:
  • Kenmore Master
  • 2,651 Answers
Dont start pulling machine apart just yet. check your detergent first, you NEED to be using an HE detergent liquid better then powder, if fabric softener is being used thin it out a little(cheaper fabric softeners have a hard time breaking down.did you switch deterent recently??? there is a new product just hit the market AFFRESH tabs (available in home depot and best buy) sure itll be in supermarkets soon. Its designed to clean ou tresidual detergent pockets building up inside all frontloading machines
Posted on Mar 04, 2008
  • Ron Coons
    Ron Coons Mar 05, 2008
    rumbling noise?? like you can reach inside and lift the inner tub up and down a little play in the tub area??? sounds like a job for a pro. check for possible extended warr on rear bearing parts anyway
  • Ron Coons
    ummm give a solid 8. but not something you would do yourself, without a part warr, probalby cost prohibitive repair, with a part warr, an authorized servicer will have to perform the work.(even then labor cost be be prohibitive
Hi I've a front loading model 970-C42074-00 that is ruining my cloths, leaving grease marks on everything. Could the cause of this be bad bearings in the drum? I have tried increasing water temperature,...
woo stop adding more detergant . you get a build up over time you should only be using about 2 tblps no mor half that if you have a softner . ok chexk the door seal behind the gasket at the tub is there a gray slime on the plastic tub could be brown
Jun 03, 2010 | Kenmore HE2 Plus Front Load Washer
Brown marks on clothes. I have put the machine on a boil wash with nothing in it. washed all pars of machine and it is still happing, Please help
Does the drum sound noisy when it spins if it does then I would suspect the bearings are badly worn and the grease from the bearing is getting inside the drum.
Hope this helps.
May 16, 2010 | Zanussi FJD1266W Front Load Washer
Kenmore 80 Series washer leaves brown grease marks
Remove the agitator and check the shaft seal underneath the plastic drive block at the top of the shaft. Move the shaft in different directions to check the condition of the top bearing. If none or very slight, replace the seal at the top of the shaft supporting post. Clean any grease that is outside of the seal when you are done. Be sure to not damage the seal surface on the shaft when removing/replacing the seal and pre-grease the new seal's inner lip before installing.
Nov 15, 2009 | Kenmore 22422 Top Load Washer
Brown spots on clothes
Brown spots indicates a bearing is breaking up, the spots are the grease from the bearing and as the seal breaks down due to the bearings going off centre, the grease gets in the drum.
Get the bearings replaced if affordable.
Jul 02, 2009 | Frigidaire ATF6000ES Front Load Washer
Brown streaks on clothes
do you have the matching dryer on the earlier models they didn't use a seal on the drum and once the paint rubbed off they left brown rusty looking marks on the clothes
Jun 29, 2009 | Frigidaire ATF6000ES Front Load Washer
My Kenmore heavy duty tumble washer is leaving a light brown stain on white or light clothes. It is likely staining dark clothes but of course they are too dark to see a light stain. It is definitely...
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 06, 2009 | Kenmore 44102 Front Load Washer
Kenmore Calypso Washer is leaving dark brown stains on clothes
hi is the machine noisy on spin cycle if so ur bearings have gone
May 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Iam getting brown spots on white shorts after washing with Kenmore front loading washing machine
If it's gunk or build up the marks should wash away. In this case run a long cycle using "affresh" or "washer fresh" with an empty load and use the hottest water available to help rinse the gunk out.
If the marks do not wash away, it could be grease due to a bearing failure. Listen for loud growling or grinding either by spinning the drum by hand or putting it into a spin cycle. If this is the case, the rear tub assembly (contains bearing) will need to be replaced. Not much can be done about the ruined clothes :(
Jan 18, 2009 | Kenmore 44102 Front Load Washer
Dryer Squeals
my sears kenmore 417 stacking get things caught every time in the dryer and leaves some brown stuff on all my clothes.
How can I keep things from getting caught??
Jul 13, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer is leaving brown streaks on cotton clothes
The 417 dryers have two seals on the front panel, the top seal has drum glides which wear down over time. Because the drum rests on those glides, when it wears down it leaves a gap between the drum and the seal, clothes will drag in that gap and come out with rust and/or seal adhesive stains. Try replacing the top and lower seals, this works most of the time...sometimes though, if left unattended long enough, the lack of support from the front glides causes too much strain on the rear drum bearing, and even after replacing the seals clothes may still catch, although the brown spotting will stop for awhile. You can feel the gap if you run your hand along the inside of the drum at the seal point.
Dec 29, 2007 | Kenmore 73952 Gas Dryer
Kenmore 44102 Front Load Washer Logo
452 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
