Question about Maytag Atlantis MDE6400AY Electric Dryer
GRINDING NOISE - Maytag Atlantis MDE6400AY Electric Dryer
  • borttennis Jul 21, 2008
    Kenmore Oasis model 110.67072600, ser MT1603681 makes loud grinding noise. Opened back and found an inch long, inch diameter, piece of metal (cylindrical), on the bottom of the dryer. Lots of black dust all around it (metal). Still runs and dries clothes, for now. A little help would be great since I had to just replace the control board a couple months ago.
  • Ron Coons
    Ron Coons May 11, 2010
    manufacture??, model number???. grinding noise while operating?? grinding noise and no tumbe??? need to be a little more specific with problem
I have a grinding high pitch sound. Where could that be coming from.And how do I fix it.
Posted on Sep 27, 2008
    Problem Solver:
  • 3 Answers
Definitely need more info. However, probable causes:
1. Broken/worn drive belt - replace belt.
2. Loose piece of debris between the inner drum and outer shell. - remove any alien/non-standard part/s found.
Both require access to the back/top of the unit. Standard tools may be required.
CAUTION: Ensure unit is unplugged before opening any cover. Most appliances are mass produced. As such be aware, units tend to have sharp edges inside.
Posted on Mar 05, 2008
Grinding noise before spin cycle
Good Morning John,
I see that you are hearing a grinding noise before the spin cycle in your Frigidaire washer, model# GLET1031CS0. A certain amount of "grinding" or gear sounds are normal in a heavy-duty washer. If you notice that the grinding sound appears to be getting louder, I suggest contacting either the manufacturer or your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Mar 16, 2014 | Frigidaire Washing Machines
Grinding noise
"Swing plate assembly" (RM1-0043-020CN) need to replace to avoid grinding noise. ..Note: Only professionals can perform this activity..
Jan 23, 2013 | HP LaserJet M4345 MultiFunction Printer
2006 chevy cobalt transaxle noise , i blocked car up remove both front wheels started engine, engaged transmission to drive, listened to noise sounded a bit like a grumbling/grinding noise., no fluid leaks...
WORN FRONT BRAKE PADS WILL MAKE GRINDING NOISE IF PAD WORN DOWN TO RIVETS RUBBING AGAINST BRAKE ROTOR WILL MAKE GRINDING NOISE, IF BRAKE PADS OKAY WORN DAMAGE DRIVE SPROCKET SUPPORT BEARING .
Oct 25, 2011 | 2006 Chevrolet Cobalt
When i get on the gas i hear a grinding noise
is it a grinding noise, or vibration noise, as sometimes the heat shields can produce a vibration noise that can be misheard as a grinding noise......does this grinding noise go away as you brake ????...do you hear it more whn you go left or right ???
Dec 20, 2010 | 1997 Jeep Grand Cherokee
Xerox 6360dn, Tray 2 makes loud grinding noise when printing. Tray 1 is as quiet as a mouse. Replaced tray 2 with a known good tray and it still makes grinding noise.
In my experience, it was the registration roller causing the grinding noise. See http://my.brainshark.com/Phaser-6300-6350-6360-Grinding-Noise-795590408 for troubleshooting video.
Oct 18, 2010 | Xerox Phaser 6360DN Printer
52 grinding noise from under car . not sure if it
Hi, When a grinding noise is detected first locate the area of the car it is being generated from. Most grinding noises will be being generated while driving, if you are having a hard time detecting the location of the grinding sound, have a helper ride along in the rear seat to give a new perspective on the origin of the grinding noise. A grinding noise can be generated by many things from worn out brake pads to axle bearing failure. Once a grinding sound has been detected action must be prompt. Grinding in most cases is telling you something has failed or is failing. It can be as a result of worn out brake pads or shoes, check your engine and transmission mount, check for axle bearing failure, check your power steering system for leak...
Take care
Jul 23, 2010 | 2002 Jaguar X-Type
2000 windstar has grinding noise when running about 45 to 50 mph and let off acc -- gets a grinding noise up front
BAD WHEEL BEARINGS OR FRONT BRAKE SHOES WORN UNTIL FRONT SHOES GRINDING ON BRAKE ROTORS CAUSING GRINDING NOISE.
Mar 07, 2010 | 1998 Ford Windstar
HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
May 29, 2009 | HP Office Equipment & Supplies
97 blazer makes a grinding noise, I put it in 4 wheel and it stops making the grinding noise, I change the wheel bearing, and the u joints. Please help.
mine did the samething you have check if there is any transmission fluid in your transfer case. because i didn't and i put more in and the grinding went away.
Dec 04, 2008 | 1997 Chevrolet Blazer
Maytag Atlantis MDE6400AY Electric Dryer Logo
130 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
