Question about Dishwashers
Indecit dishwasher not circulating water
Water left in bottom of dishwasher. When starting up again water drained away but then stopped, dishwasher flashed lights 1 and 3.Tried again but now dishwasher seams to run through cycle with small amount of water which it heats and drains but does not circulate.
Checked that the motor was not seized by inserting slotted screwdriver through hole at back of machine to engage in slotted end of motor to spin up water circulating motor. Motor was not seized, so that was not the problem. Then took bottom off machine and on inspection found that the start capacitor which is bolted to side of motor was bulging and discoloured wher the terminals are. Replaced Start capacitor ( Less than £10.00) and machine motor started up. Machine behaved irratically at first, flashing lights etc.but got it to reset by switching on and off a couple of times, ran machine through cycle, now working ok.
Posted on Mar 15, 2008
Smeg Dishwasher not circulating water
Sound like the thermostat doesn't know what the water temperature is set at.
It could be the wash pump. Check to see that the float on the bottom of the DW is unstuck by gently picking it up and setting it down { It is shaped like a mushroom and controls the water level in the bottom of the DW }. Did it move freely?
Dec 29, 2013 | Dishwashers
Miele dishwasher model G858 water will not circulate and the intake / drain code flashing? Does anyone know what needs to be replaced?
when you start a cycle, your machine should drain for 30 sec, fill with water, and then the circulation pump should come on. your water level should be up to the handle on the filter in the bottom. if you drain, and fill to the handle and then the intake drain error comes on, your circulation pump is stuck. if it does not fill to the handle, you may have a problem with the inlet valve.
Jun 02, 2012 | Miele 24 in. G858SCVi Plus Built-In...
F14 code Miele Dishwasher
This fault is low pump pressure. more than likely you have some foreign particles jammed in the circulation pump. you would have to remove the unit, tip it on its side and remove the bottom plate and remove the circulation pump and clear the blockage. the unit will start and stop and not work until the pump is clear.
Aug 14, 2010 | Miele Premier-Plus Built-in Dishwasher
E1 error code on my kenwood dishwasher [kwd243a
Hi
The E1error code indicates a water inlet error.
To access test mode: press and hold Normal+Eco, and press Power. Release buttons. Then press Start(display n:01).Press Start again (display shows water level frequency-not important). Press Start again-(display n:03-motor will be running). Press Start again (display n:04-drain pump will run). Press Start again (display n:05-inlet valve will come on and machine should fill with water). You have now tested major components are working-if you keep pressing start you will scroll thru and test other functions, like heater, dispensor etc, but not needed for your fault.
If Machine didn't fill with water in test mode, you probably have a faulty inlet valve (test resistence should be approx 3.7-4 k ohm).
If inlet valve has tested OK ie machine filled with water in test mode then:
Disconnect from power.
Remove side panels (need to remove top, and bottom front panel to then be able to remove sides)
- Check no water in base of machine-water in base will indicate machine has leaked and activated the safety device which shuts off inlet valve.
- If OK, you probably have a faulty flow meter(measures water intake). Located left hand side of machine, large plastic compartment, which has a sensor at the bottom with 3 wires (red,white,black) that go up to control board. Replace entire flow meter assy-relatively inexpensive part.
- If you still have problem, then control board is faulty, it is much more likely to be flow meter .
Thanks for contacting fixya.com
Sep 10, 2009 | Dishwashers
Water remains at the bottom of the dishwasher
some dishwashers have water left after the final rinse. it is important to keep the motor seals wet between loads. My filter is always immersed. If we go away for two weeks, I put 2 litres of water into the tub and let it soak 24 hr so that I never start it with dry seals.
Jul 22, 2009 | Siemens 24 in. SE64A630GB Built-In...
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Water still in the bottom of the dishwasher
If there is no air gap (silver cap) located on your sink next to your faucet, you could have a clog in the drain line or at the drain port at the motor/pump assembly. Also, check to see if the drain hose (under sink) has a loop in it before it goes to the disposal or pipe. If there is no loop, water could be backing up into the tub.
Sep 28, 2007 | GE GSD5320DBB Dishwasher
Dishwasher does not complete cycle
It could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Sep 09, 2007 | Miele 24 in. G638 Plus Free-standing...
Dishwashers Logo
374 people viewed this question
Top Dishwashers Experts
