Hotpoint Aquarius WD420 washing machine won't spin and drain
The machine freezes midway through every washing programme, just before the drain and spin. The On/ Off button flashes quickly and the Reduce Creases and Time Saver flash slowly. Initially I turned the power off at the mains and left it some time before turning back on. Then I drained and set on a final spin. This no longer works. I'm so frustrated! This machine is just over a year old.
  • OllyDT Mar 18, 2008
    The exact same thing has just happened to me.  I have had mine fixed once before, but being mid-term I can't get my shirts for work washed.  Its an inconvenience.  I have the same sequence of lights flashing and a funny burning smell, like burning dust.  Have turned the machine off at mains, got some washing in there that is just sitting in water, good job it is a coloured wash...doh!!!
  • ramsay32 Jan 08, 2009
    did you get it fixed ? what was it mine is doing the same right now
    insti_1@msn.com
    please let me know
    many thanks
Same thing happened to me called engineer over flow pipe was blocked hope this helps anyone with this problem
Posted on Mar 13, 2010
My Hotpoint Aquarius WD420 does not wash properly. It doesn't seem to take in any hot water and the drum does not turn, it just sways from side to side and does not move on from wash to rinse and spin....
For those problems, you have multiple issues and need a service engineer. It may be just the hot water intake solenoid, but may also be a problem with the logic board or both.
Nov 13, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
Machine does not empty and light flashes
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 11, 2011 | Hotpoint Ariston Aquarius WD420 Front Load...
Where is the filter on a Hotpoint Aquarius wd420 washer dryer?
it is located at the back of the machine...are you encountering problems with this machine? check this link i will give you, this a forum/comments which the owners encountered different problems with this machine..
http://www.unbeatable.co.uk/p_rupr/Hotpoint-Aquarius-WD420-Front-Load-All-in-One-Washer--Dryer-Reviews/22394331.html
Nov 13, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Machine very noisy when it spins. Missing bra
If you cannot here it catching, then leave well alone, if it is still catching, then you could to try to locate it by removing the lower rear cover of washer, remove the large black hose on bottom of drum, and see if you can locate it from the bottom of the drum.
Hope this helps.
Jan 16, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
My hotpoint wd420 is leaking water from out the dispensor and door on a rinse/spin cycle.
You ne to get yure rubber seals checked and changed it sounds like they have perished
Nov 27, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Does machine have a filter
The filter is to be found at the rear of the washer.
Remove lower rear panel of washer, remove large black hose fastened to bottom of tub.
Watch out for water running out.
Remove plastic`filter inside hose and clean.
Refit filter and hose.
Dirty washing can somtimes be attributed to washing at too low a temperature, so make sure you have selected right temp for washing.
Please leave a fixya rating for my solution.Thanks.
Feb 08, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint WD420 Washer/Dryer - Not completing cycle
I WOULD FIRST CHECK THE COLD WATER VALVES ONE COULD BE INTERMITTEN
Jun 25, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
852 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
