Question about Microsoft Windows XP Home Edition
Slow running laptop
I have windows XP configured on my home PC. my laptop runs very slowly then it used to ; is it safe to uninstall programs like zone alaram which may be causing the slown running
  • Microsoft Master
  • 19,396 Answers
If you remove ZA you can always use windows firewall, it is more basic but it will protect the same. check if you also need to do a defrag. Wipe out all useless application that start in outomatic (be careful on this). You find some in start menu/all programs/startup. Things in this folder start in automatic.
Other applications like real for example may be configured one by one from same application options menu. If you are not really skilled I suggest you not to touch the registry directly with reged, you can damage windows.
Posted on Mar 04, 2008
  • 818 Answers
I think that you have some virus or worm su your computer. please check it. i suggest nod32 antivirus v.3.0 work very well.
Sergio
Ihave an acer laptop,,,.,., i was installed w7 on my laptop,,that time my laptop work slowly,,, and also the black spots on monitor screen,,
See whether you laptop have the minimum system requirment to install Windows7, windows 7 needs more graphics support than others os.
May 09, 2011 | Computers & Internet
Tip
For All XP user Don't Use IE 7.0 & higher version
Applicable for all window XP (all edition, all PCs and Laptops)
If you are getting trouble after the updates of internet explorer..
Then I would suggest you to Roll Back it to the original Internet Explorer (i.e Internet Explorer version 6.0)
Which come up with Installation of Win Xp with Service Pack 2.
Bad Effect due to IE 7.0 or higher version:
Screen hang up, internet freezes abruptly, prominent windows crashes anytime.
So to stop these problems, better to run with lower and safe version of IE:
To remove Internet Explorer 7 from your PC use the following methods
Method 1: Use "Add or Remove Programs" to uninstall Internet Explorer 7
Step 1: Use "Add or Remove Programs" to uninstall Internet Explorer 7
a. Click Start, and then click Run.
b In the Open box, type appwiz.cpl, and then click OK.
c. In the list of programs, click Windows Internet Explorer 7, and then click Remove.
d. Follow the wizard instructions to uninstall Internet Explorer 7. Also remove if any updates under this entry found.
If you cannot uninstall Internet Explorer 7 by using this method, try Method 2.
Method 2: Use Spuninst.exe to uninstall Internet Explorer 7
Run Spuninst.exe to uninstall Internet Explorer 7
b. In the Open box, type %windir%\ie7\spuninst\spuninst.exe, and then click OK.
c. Follow the wizard instructions to uninstall Internet Explorer 7.
After you uninstall Internet Explorer 7, double-click the Internet Explorer icon to verify that Internet Explorer 6 is restored.
This will bring up you to run Internet explorer as it come up with the installation kit, which is safe and reliable.
Have Nice Surfing!!
Ellin
on Oct 14, 2008 | Microsoft Windows XP Home Edition
My computer is running so slow need help please
Registry Fragmentation Registry is accessed by almostall the installed programs and your operating system itself. Why is computerslow and freezing has to do with the fragmented registry data. You have todownload a PC Optimizer software that includes Registry Defragmenter tool suchas Reginout to perform system maintenance tasks. b> Too Many Programs areInstalled Installing too many programs makeyour computer slow and freezing. You have to uninstall the unwanted programs. 1. Click Start ' Control Panel.
2. Click Programs ' Uninstall a Program.
3. Select a program to remove.
4. Click Uninstall button.
5. Follow the wizard.
6. Reboot the computer after completion. b> Insufficient RAM Sometimes computer runs slow andstarts freezing due to an insufficient RAM. You have to install additional RAMsif required. b> Lack of Proper Configurations You will feel that your computeris slow and freezing if you haven't set Windows for best performance. 1. Right click My Computer.
2. Select Properties.
3. Click Advanced System Settings.
4. Click Advanced tab.
5. Click Settings button under Performance frame.
6. Select the option Adjust for best performance.
7. Click Apply ' OK ' OK. b> Junk Registry Keys Storing junk entries in theregistry makes your computer slow and freezing. You have to delete such junkentries using a Registry Cleaner and PC Optimizer software.
Feb 25, 2011 | Microsoft Windows XP Professional SP2
Hallo my aspireone 532h-2ds working slowly i already reinstall window but its stil slow
Run System In Safe Mode:
To identify the root cause of theproblem, first of all restart your system, press and hold F8 key. Do thefollowing once you are on the desktop. 1. Right click on Computer.
2. Select Manage.
3. Click on Event Viewer in computer management.
4. Double click on Application.
5. Check for the errors.
6. Similarly double click on System and check for the errors.
7. Search for the solution to this problem. Now you are able to easily diagnosewhy Windows laptop starts up very slow. b> Limit your Startup list: A long list of programs in startupcan adversely affect the performance of your PC. There are some programsrunning in the background without knowledge of user that causes Windows laptopto start slower. To solve the problem, follow the steps given below. 1. Click on Start button.
2. Type "msconfig" in search option.
3. Double click on the file.
4. Click on Startup.
5. Uncheck all unwanted programs.
6. Close system configuration utility.
7. You are done. b> Uninstall unwanted program: Sometimes Windows laptop starts upvery slow due to unwanted programs hogging your memory. To fix this problem,below are some steps. 1. Click on Start button on thetaskbar.
2. Go to Control Panel.
3. Double click on Add or Remove Programs.
4. In the list of programs, select the program that you no longer needed.
5. Click on Remove button.
6. Repeat step 4 for all unwanted programs.
7. You are done. b> Scan System for Viruses: Windows laptop may start slower due to any virus onyour computer. To solve this problem you should scan your system with somepowerful antivirus program. b> Run Disk Clean Up: Running disk clean up utility isalso helpful to resolve slow Windows start up. To run disk clean up utility,here are the steps given: 1. Click on Start button.
2. Go to All Programs.
3. Click on Accessories.
4. Now click on System tools.
5. Click on Disk clean up. b> Defrag hard disk: 1. Click on Start button.
2. Go to Command Prompt.
3. Type "chkdsk" and press Enter. b> Defrag Registry: You mayuse some safe program such as McAfee secured RegInOut to fix registry relatedissues.
Jan 19, 2011 | Acer Aspire One PC Notebook
Pc runs very slow
If under 256mb ram with windows xp, get some more ram.
Uninstall unwanted programs, remove un needed programs from the startup folder.
There is a complete guide here to clean your computer
http://www.fixya.com/support/r5272277-secure_clean_computers
Jul 20, 2010 | Toshiba Satellite A105 Notebook
Have Averatec 3200 series laptop,windows xp.Recently running slow,saying virtual mem too low,so brought to shop to upgread w/1 gb card.Shop installed.Then at home couldnt connect to firefox or internet...
Sounds like Malware/Adware. Try to start in safe mode by pressing F8 at startup. Them start uninstalling unneeded programs. Then install and run cleanup programs. You can use this website as a guide http://csdsolutionsllc.com/cleanup.htm Hope this helps.
Jul 14, 2010 | Averatec 3200 Notebook
Wifes brand new dell inspiron suddenly running very slowly after only a month and a half.
Scan Pc for virus and spywares, read my tips on face book on how to optmized your pc. .........metropcstech
Mar 03, 2010 | Dell Inspiron 1720 Notebook
My asus eee pc 4g is running very slow, looking for some things that i can do to help myself out
ur laptop dont have big hdd so u can only install a little program, now u go to control panel , uninstall/install program to remove the soft u not use.
Jan 15, 2010 | ASUS Eee 4G Notebook
Uninstall XP Professional
If the computer was upgraded, then go into START | CONTROL PANEL | ADD/REMOVE Programs, see if uninstall Windows XP Pro is there. If it is you can uninstall it and not loose anything and the computer will reveert back to the operating system that was on there, before th upgrade.
Sometimes it is there, sometimes not.
If that doesn't work, then go to START | CONTROL PANEL | ADD/REMOVE Programs | windows components, and take out any uneeded components. Also check your system tray (bottom right by the clock) and see if there are eny programs there that you can close or better still uninstall as they eat memory and slow down your system.
Jan 08, 2009 | Microsoft Windows XP Professional for PC
Compaq presario notebook v5000 windows XP slow start up
This probably won't help much, but it will clean up things.
Also after logging in to windows
  1. Start
  2. Run
  3. type in msconfig
  4. click OK
  5. click startup
  6. click disable all
  7. click apply
  8. click ok
  9. restart
  10. click on the do not show this again when it boots up and displays configuration has been changed.
Apr 13, 2008 | Compaq Presario 2170US Notebook
Microsoft Windows XP Home Edition Logo
46 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
