Replacement or instruction needed to fix T.V. Convergence
We have a philips magnavox t.v. model number 55pp9401 and the convergence is askew. What part do we to fix the converence.
Thank you.
  • 8,617 Answers
The conversion amp ICs. Let me know if you need more info.
Posted on Mar 05, 2008
We no longer have the remote for model 55pp9401 and we have a convergence problem what can we do
Here's the Philips support URL for your TV:
PDF download of your Owners' manual:
Here's what Philips FAQ says about your convergence procedure:
Question How do I adjust convergence (align colors)? Answer Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
Press the INTELLISENSE button on the remote (under the flap). During the convergence process DO NOT press the INTELLISENSE button again and DO NOT move the Projection TV.
So, I think you're going to need to order a replacement remote.
search "replacement remote" at
May 13, 2011 | Philips 55PP9401 55" Rear Projection...
My phillips 55pp9401 looks orange and purple , heres a picture of what it looks like, i tried the intellisense and it does nothing.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
Apr 07, 2010 | Philips 55PP9401 55" Rear Projection...
Intellisense button
If the model number on the set is 55PP9401/55 you have an interesting set----this model says Philips but was made by Hitachi---they made them for Philips for one year while Philips was gearing up to produce their own sets---very good set and is better than the Philips sets that came after it.
It uses (if it is this model) two STK-392-110 CONVERGENCE IC's----both need to be replaced and the set adjusted---no need for an original remote---with the set engaged in the convergence adjustment mode( there is a micro switch on the front of the main circuit board) A HITACHI REMOTE CAN THEN BE USED TO ADJUST THE CONVERGENCE. Hope this was helpful.
Aug 11, 2009 | Philips 55PP9401 55" Rear Projection...
Can't adjust blue vertical convergance.
blue vertical is defective convergence amplifier Stk ic and need to replace
Jul 08, 2009 | Philips 55PP9401 55" Rear Projection...
60pp9202/17f color problem
Common problem. Your convergence chips and resistors need to be replaced. Check with the site for parts and replacement instructions.
Dec 11, 2008 | Philips 55PP9401 55" Rear Projection...
I have a phillups projection tv and it totaly kaput
u lost convergence witch is no big deal with magnavox what i would do first is change the convergence ic that should sole your deal
Sep 22, 2008 | Philips 55PP9401 55" Rear Projection...
Convergence Ics need to be replaced
Okay that model uses two ICs they are STK392-120 also I would recomend getting at least four of the 6.8 ohm 1watt resistors as that model will usually have a couple of the convergence resistors go open when the ICs fail. You can get replacement ICs at the following link they do provide free instaltion instructions as well as free on line instant messageing with their technicians to help with testing resistors or any other help you need and the support is unlimited and always free for all their customers. Heres the link.
May 28, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips 52inch - Dual picture with red background Model No. 55PP9401 Serial No. 65136479
sounds like the convergence ICs number STK392-120 need to replace both of them. You can get replacements at the following link and they provide free instalation instructions with pictures so you can do the repair yourself.
May 26, 2008 | Philips Televison & Video
55pp9401 convergence problem
try aligning them using the yoke control rings.
sometimes the alignment is so far out that you have to adjust the magnet rings instead.
Feb 25, 2008 | Philips 55PP9401 55" Rear Projection...
You probably have a problem with your convergence board. Try resetting the convergence manually on your TV - go to Philips website for instructions on doing this if you have lost the Quick Start Guide. If the manual convergence fails, then your convergence board needs to repaired or replaced.
Dec 24, 2007 | Philips 55PP9401 55" Rear Projection...
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
