Question about Lexmark X1240 All-In-One InkJet Printer
X1240 faxing AIO exe has encountered a problem and needs to close, appeared when I tried to fax on my freshly installed printer. help
  • rurug Mar 11, 2008
    ok i tried everything am at the point of throwing it out the window, i uninstalled, reinstalled, downloaded the driver, when i try to use it, it says MICROSOFT VISUAL C++RUNTIME ERROR
    i contacted hp, they couldn't help me,
    then when i thought it was ok, it said AIOC exe stopped working.pleze help me
    Genius:
  • 2,035 Answers
What you will see
During installation of the printer software:
a runtime C++ error might occur
the file lx..coms.exe might be quarantined.
Proposed solution
Update your antivirus software/definitions. Please refer to the documentation that came with the antivirus software for the applicable instructions.
CAUTION! Simply turning off the security could cause exposure to actual security threats.
Still have questions?
Please contact Lexmark Technical Support for additional assistance. NOTE: When calling for support, you will need to know your printer model type and serial number.
Please call from near the printer and computer in case the technician asks you to perform a task involving one of these devices.
Posted on Mar 16, 2008
My HP Laserjet 3050 used to print automatically after each fax sent a call report showing that the page(s) had sent. For some reason, after a service call, now it doesn't do that any more and I have...
Hi Dear
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
Jun 01, 2011 | HP LaserJet 3050 All-In-One Printer
I bought this x1240 second hand. it prints and copies well. how do i get it to fax
You will need to connect your Lexmark X1240 printer to a computer that is hooked up to a fax modem. Open the top cover. Place your document you want to fax facedown on the glass. Make sure the upper left corner of the front of the item aligns with the arrow. Close the top cover. Open the Lexmark All-In-One Center. From the Creative Tasks section of the All-In-One Main Page, click Fax an image. Follow the instructions on the computer screen. I hope this information has been helpful. Thanks.
Dec 28, 2010 | Lexmark X1240 All-In-One InkJet Printer
I can not get the printer to stop printing ...what do i do?
Hi please turn off the printer and restart it after five minutes if you still have the problem please uninstall and reinstall the drivers for your printer.
Jun 13, 2010 | HP Office Equipment & Supplies
I have a similiar problem with my Dell AIO Printer 962
reinstall the printer and fax cd that came with your computer
Jul 10, 2009 | Dell 962 Photo All-In-One InkJet Printer
What is Error 2200 when I try to fax something?
Error 2200 is a scanner stall error.. there are a couple things for you to try to fix it:
Power off the AIO and remove the power supply(Power Cord) from the back of the unit.
Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Open the top cover of the AIO.
Using the carrier belt, move the cartridge carrier to the middle of the unit.
Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
IF THE ERROR MESSAGE DID NOT COME BACK....
Power off the AIO and remove the power supply from the back of the unit.
INSERT THE COLOR CARTRIDGE ONLY,
Close the top cover, reinsert the power supply, and power on the AIO.
IF THE ERROR MESSAGE RETURNS.. GET A DIFFERENT COLOR CARTRIDGE AND REPEAT THIS PROCESS....
IF THE ERROR MESSAGE IS GONE,
Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
Power back up as in previous steps...
NO ERROR? SHOULD BE GOOD TO GO..
ERROR?? TRY DIFFERENT BLACK
If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
Jun 29, 2009 | Lexmark X7170 All-In-One InkJet Printer
How to install printer ?
Just go to Control Panel...........
Printers Folder...........
There u will see a Chk mark on Lexmark Fax X1240........
And u will see another icon which says Lexmark X1200 Series just right click on Lexmark X1200 Series not the Fax and Click on Set As Default Printer...............
After u do this U can go ahead Print............
Good Luck
Feb 16, 2009 | Lexmark X1240 All-In-One InkJet Printer
Fax
Hello, the Lexmark x1240 has what is called PC fax. the AIO is not an actual fax machine, but it does have the capability of using you computers internal modem to send a fax. this feature ison the installation CD.
hope this helps
Jul 07, 2008 | Lexmark X1240 All-In-One InkJet Printer
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
Fax Confirmation Sheet
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
Lexmark X1240 All-In-One InkJet Printer Logo
63 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
