Question about Samsung Phone PDCSLCD12B
BUttons are not working
There are two buttons that are not working on the switchboard. I recently changed the extensions around by using the 170 code and now two off the buttons are dead buttons. Are there any suggestions? Thanks.
    Problem Solver:
  • 16 Answers
You need to go into programming use mmc 722 . Type the ext # you are having a problem with and the press the btn that is not working. If it says none , you have to program it for what you want it to do. (i.e. ds for direct stn select)
Posted on Mar 06, 2008
How do i set ring on Flexible Buttons.....
Perhaps you are trying to set up speed dialing.
Right?
Jul 22, 2013 | Panasonic KX-DT343 White 24 Button 3-Line...
Hi I am working at the Switchboard. I have a Panasonic KX-T7730 that is seven years old. Every office has an extension code and a name. I want to change the display names of the extensions as it still...
This has to be done on Ext 101, or whichever phone is the programming phone. Press program *#1234. Then enter in 004. Press Speakerphone. It should be asking for a jack number. You can press speakerphone again to go to the first ext. Spell out the name using the keypad (2 is A, B and C and so on). When done press the autodial/store button. Then you can press speakerphone to go to the next phone. To get out of programming just pick up and hang up your phone or press the program button.
Aug 30, 2011 | Panasonic KX-T7730 Corded Phone
I have various incoming lines into my idcs28d switchboard - how do i program the switchboard to name each incoming line so that we can see the name allocated to each incoming line when the switchboard...
if you follow the the video I have posted you should be able to tag inbound DDIs, the phone used is the new 14 btn samsung handset, the soft buttons an a 12 btn handset are down the side but apart from that the softkeys are the same. go to http://www.abbeytelecom.com for more of these.
Apr 19, 2011 | Samsung DCS 12 Corded Phone
Hoi have got speed dial on the main switchboard, so how do i do speed dial from other extensions
There is system and personal speed dials. System is programmed from the main phone and is dialed by using the AUTODIAL button and dialing a 2 or 3 digit code, depending on which system the 7730 is connected to. The other is PERSONAL speed dial, programmed on the 12 buttons on the right side of the phone. Those are programmed at each phone by using PROGRAM pressing the button and dialing an access code (usually 9) and the number then STORE.
Carl
Oct 23, 2010 | Panasonic KX-T7730 Corded Phone
Switchboard PABX purchase
If you need 8x30, you start with a minimum of TDA-100. It grows to 96 ports and you would start with 8 lines and 32 digital ports.
Your phones become KXT-7633's, not the 7731's. On this side of the pond, it costs about $20 more per phone, but you gain the use of 12 extra buttons, 3 line display, and more features.
Your Panasonic TDA/TDE dealer can guide you.
Carl
Jan 15, 2009 | Panasonic KX-T7730 Corded Phone
The incorrect name being displayed when you use a preset number
The side buttons is programmed as extensions
To change the extension names follow these steps :
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ).
3. Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change.
4. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered.
5. Press PROGRAM to exit program mode and you are done.
Jan 12, 2009 | Panasonic KX-T7730 Corded Phone
Programming extensions
By default a TDA user has access to the first 9 programs in the Basic Programming (000-009). It lets you set things like date and time, speed calls, extension name, number and PIN code, and operator extensions.
Access to the programming is from an allowed phone by PROG **1234. You may have to consult your installer/dealer to find out which phone does that, but generally it's the operator.
Carl
Sep 09, 2008 | Panasonic KX-T7633 Corded Phone
Dial code features for setting up extions buttons.
Look around for a little red book about 4x6 inches. It has all of the feature access codes for a partner phone.
Feature buttons for intercom are programmed by FEAT 00
Press button to program
Press Intercom and dial ext
End by pressing FEAT 00
Carl
Sep 05, 2008 | Lucent PARTNER18 Corded Phone
Internal autodial
It sounds like you have a problem with your phone, possibly a stuck button. Have the phone repaired and/or refurbished.
Sep 27, 2007 | NorStar M7324 Corded Phone
Lands Phones Logo
91 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Vladimir Frolov
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
